Originally Posted by Runnin4MO
Mark, can you verify what clip to put the fronts on to get almost 3" WITH an added 220# bumper and 90# full roof rack? We're getting conflicting info from Eibach support.
Thanks!
This is rough, but if you take the 220 / 2 you get load per corner. Then take the 90 / 4 you get 22.5 roof rack per corner. SO your total added weight to each front spring is 132.5.
If your spring is 650lbin. it takes 650lb to compress the spring 1 inch. Now divide 650 by 132.5 and you get 0.2, so approximately 1/4" compression at the spring. I don't have the motion ratio in front of me though, so its hard to say what that looks like at the fender well.
