Thread Tools Rating: Thread Rating: 28 votes, 3.57 average. Display Modes
Old 04-15-2021, 10:22 AM #2236
kouki_monster kouki_monster is offline
kouki_monster is on a distinguished road
Originally Posted by 14runnerdog View Post
How many using this Eibach kit are installing new UCA's? I've probably read over 400 posts on the topic with 50% saying keep OEM's and 50% saying you have to have for proper alignment.
Eibach Pro-Truck Lift System (Stage 1) for 2010+ 4Runner (E80-82-071-01-22)
Thanks in Advance!
Kinda looks like you answered your own question? lol
I wouldn't install this kit without aftermarket UCA's. But others feel differently. You make the choice.
"DYNO4" Midnight Venture : Falken . C4 Fabrication . TRD
kouki_monster is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 01:21 PM #2237
Curious, did anyone else notice this when installing their front Eibach shocks? I checked my shock part number and it is the correct one.
I just got off the phone with Eibach, I am awaiting a call-back. I spoke with an employee (non-tech) that has a 4Runner, and he seemed to think this was not normal, but we are holding off on judgement until I speak with the tech that actually designed this and wrote the install instructions. We shall see. Honestly, I did not notice if this happened on the passenger side, or not.. so I'll have to go check that one again if this is indeed abnormal. Ughhhh, I have literally already removed, installed, removed, installed, removed, installed, removed and installed the passenger side suspension.. yes.. that many times. Looks like here we go again!!
EDIT: Eibach returned my call and said that "2mm of additional clearance/wiggle room is normal in that location, and the play is normal. Once the lower eye bolt is tightened, everything will be snug and good to go." I suppose that's that! A little unnerving that I am getting different answers from different people, but what can I do, other than trust Eibach? The lower mount did seem to tighten up against the bushings as I tightened it but that just seemed weird to me. At this point, it's all installed and I hope it's right.
Old 04-15-2021, 02:03 PM #2238
chops84 chops84 is offline
chops84 is on a distinguished road
Originally Posted by 20h4Runner View Post
Attachment 379014
I’m on the 1st perch but I’m looking to move it up to the 2nd perch to minimize rubbing I’m experiencing.
Your ride is HOT. Nice work.
chops84 is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 02:40 AM #2239
Blue109's Avatar
Blue109 Blue109 is offline
Blue109 has a spectacular aura about Blue109 has a spectacular aura about Blue109 has a spectacular aura about
Blue109's Avatar
100% not normal. Where is the wiggle happening? Is it the shaft wiggling in the top hat? If so, you probably didn't get the top nut tightened down enough. You needed to crank that spring compressor down a little tighter and get a few more turns on it. Maybe take a few more pics of the top mounting area?
If you're gonna scream, scream with me. Moments like this never last.
Raptor lights. eBay PRO grill. Pedal Commander. Plasti dip valence. Very limited edition overlanding stickers and headliner patches.
Blue109 is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 02:44 AM #2240
Blue109's Avatar
Blue109's Avatar
Thanks in Advance!
It certainly won't hurt to add some nice UCAs. Dialing in more caster can help with bigger tire fitment and overall handling. With that said, Eibach designed the kit to work with stock arms. I'm running stock arms and 285s with perfect alignment and no issues. It is not needed.
Old 04-16-2021, 07:49 AM #2241
edizzle edizzle is offline
edizzle is on a distinguished road
can the speedo be calibrated if i go to bigger tires? thinking of doing this eibach kit with 285s. but i would like accurate speed
edizzle is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 08:30 AM #2242
wcslv wcslv is offline
wcslv is on a distinguished road
I thought I read somewhere on this forum, that the 285s bring the speedo inline with a gps and that 4Runner speedo is incorrect with the stock tire size.
2019 T4R TRD PRO
wcslv is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 09:17 AM #2243
Drobs Drobs is offline
Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light
I concur that in fact is the case. My Speedo now matches my gps for my 285 tires.
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
Drobs is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 09:58 AM #2244
Thank you for your reply.
According to Eibach, it is normal. So I'm at a bit of a loss. I'm gonna go with it, and hope for the best. It doesn't seem that many here actually install their own parts so not a lot of feedback from the community. Eh.
For the record, this recording was done with the top mount unbolted and dropped. Only the lower shock mount bolt was inserted, not tightened, which is when I noticed the play and took the video. The top was completely free and able to move as you'd expect.
Old 04-16-2021, 12:12 PM #2245
Blue109's Avatar
Blue109's Avatar
Your video is short so it's hard to really see what's going on, but if the bottom bolt is in and the top hat is seated in the upper mounts, it doesn't seem like it should be able to do that. The first time I assembled mine, they acted like that and I realized the shaft/bushing was moving in the top hat. I put the compressor back on it and was able to tighten the top nut down some more and it was rock solid after that. As far as your original issue with the bushings, I'm not sure why it would be a big deal. I used KYB tops and the KYB bushing was the same thickness as the Eibach bushing. It was larger diameter and fit the top better than the Eibach bushing. I know the eibach is poly, and probably higher quality than the KYB, but I can't see it making a real difference. Fitment was exactly the same for both. I think you would have been fine running it how wheelers sent it to you.
Old 04-16-2021, 12:47 PM #2246
Yes, in the video, the top hat is not seated. The lower shock mount is installed in the "box," with the bolt inserted, but not tightened. The lower UCA is still dropped down per install steps, so the top mount is below its mounting location and able to move freely.
I agree it may have been "fine" with what Wheeler's did, but I am one to follow the manufacturers recommendations and requirements in order to maximize my enjoyment and reliability of the product. IMO, Wheeler's should also be on that train. Alas...
Cheers
Old 04-16-2021, 01:33 PM #2247
Now I am worried that Wheeler's Off-Road sent me the wrong shocks. Since I ordered these assembled from Wheeler's, they sent them in a generic brown box. Eibach only puts the entire shock's part number on their box, which Wheeler's did not send me.
EDIT: I annoyed Eibach again. I can tell they are tired of hearing from at this point; I can't blame them.
David informed me that the number on the shock body is also unique, even though it's not the part number you find online, etc. when purchasing.
My shock body's part number matches up with the shock part number for the 2010+ 4Runner/FJ so I believe I am good to go! Some here on this forum seem to think that the play is not ok.. but if I can't trust Eibach, what can I do? So I am choosing to trust Eibach and assume that everyone that is running these shocks has the play, and just didn't notice it when installing, or knew it was OK.
Cheers
Old 04-16-2021, 03:20 PM #2248
Alright, after spending all my dang time on this, here's the deal.
Eibach still uses pre-2010 Toyota bushings on their 2010+ products, even though Toyota changed the bushing size in 2010. That's why the play is there. It's the wrong bushing. Eibach claims that this doesn't matter and is OK. Obviously Toyota disagrees.
I'm pretty disappointed in Eibach, to say the least. Perhaps it doesn't matter practically, but I'm pretty sure that both their top mount lower bushing as well as this lower eyelet bushing are incorrect, and for whatever reason, they don't feel the need to change it. I guess it doesn't really matter in the end if everyone is happy with their suspension. I really, really hope that this does not cause issue with my 4Runner down the road. I am trying to decide how to proceed at this point.
With 150 pages of this thread, I cannot believe I am the first to notice this.
Eibach Fits Incorrect Lower Bushings in their 5G Pro-Truck Sport Shocks.. Thoughts?
Old 04-16-2021, 06:39 PM #2249
Blue109's Avatar
Blue109's Avatar
Honestly, I used the lower bushings that came with the KYB tops. It fit snug so I ignored Eibach lol. I suppose that could be the reason I didn't have the rattle. I think I used the Eibach upper bushing but it was the same size as the KYB one.
Old 04-23-2021, 02:53 PM #2250
mark@eibach's Avatar
mark@eibach mark@eibach is offline
mark@eibach will become famous soon enough
Thank you for the kudos on the customer service. We all try to be as helpful as possible on the phones! That being said, depending on your questions someone who thought they're being helpful may inadvertently give some variance in response. The first person you spoke with is not a technician, nor is he on the engineering team. I am not a technician nor am I on the engineering team, but I DID stay at a Holiday Inn Express once.
After speaking with the engineering team and reviewing previous development installations with consideration of production tolerances, the mounting bolt can be safely torqued to the manufacturer's specified 118ft-lbs without play in the bushing, which we have found warrants the use of this OEM Toyota bushing over the past 8 years.
2014 TRD OR, DCSB: Eibach / Magnuson / Nitto / WARN / ARB / Hella / Fifteen52 / Dirt King / Pelfreybilt / Autometer / Pelican / Switchpros
mark@eibach is offline   Reply With QuoteReply With Quote
Anyone running Eibach Pro-Truck Shocks with lift? DeepSea 5th gen T4Rs 9 05-07-2019 10:39 AM
Eibach Pro-Truck Sport Shock Review (4th Gen) Rannd 4th Gen T4Rs 13 09-14-2018 12:24 AM
Eibach Pro-Truck Shocks, any experience with them? rich045 4th Gen T4Rs 18 06-23-2018 02:59 AM
Eibach Pro-Truck Sport Shocks (Leveling Kit) OC4X4 5th gen T4Rs 6 07-09-2017 01:12 AM
Rear lift options with toytec/eibach front lift cma1188 3rd gen T4Rs 3 10-06-2013 01:40 PM
