Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Old 03-28-2018, 06:43 PM #1
transistor's Avatar
transistor transistor is offline
transistor is on a distinguished road
transistor's Avatar
Seeking rear coil recommendations for my situation
I'm looking to lift my rear end by 0.5"-1" over the stock height, but I'm planning on adding about 400lbs of permanent equipment to the trunk, which is making things a bit more difficult. I was originally planning on installing spacers, but after seeing the rear sag an inch with only 200lbs of tires in my trunk, I figured I'd need too big of spacers to achieve the 0.5"-1" lift over stock after all that weight is added. So, which rear coils would work the best?
Is that something the RCC2.0 - ToyTec "Superflex" could take care of? They advertise 2" lift, but I'm guessing 400lbs would negate that completely? How accurate is the 2" figure anyway?
The heavy duty superflex version is advertised at 2.5" with a 200lbs load, but consider its higher spring rate, I think there would still be about 2" of lift at 400lbs.
Another option I see is the OME medium duty, which advertises a 2.5"-3" lift. Anyone know what the approximate spring rate of the medium duty OMEs are?
transistor is offline   Reply With QuoteReply With Quote
Old 03-28-2018, 08:37 PM #2
3wbdriver's Avatar
3wbdriver 3wbdriver is offline
Real Name: CJ
3wbdriver will become famous soon enough
3wbdriver's Avatar
Real Name: CJ
I'm in that boat now with the Superflex +10 springs. I have a pair Of Dobinsons 2" medium duty springs sitting here waiting for a wrench day. I have a 175 pound rear bumper, 80 pound cargo slide tray, and roughly 50-75 pound trunk with assorted recovery/off road gear in there. The rear is actually riding at almost factory height with that load (325+ pounds?). Unloaded it was stilted up at 2 1/2". The ride is fine and well planted, but I want my 2" lift back. Hence the Dobinsons which are recommended for 200-400 pounds constant weight. Your problem is ONLY wanting 1" of lift. You pretty much can't get that with anything but spacers. I might recommend airbags to help with the additional weight, but that won't help you with the lift department. You might look at Dobinsons long list of springs in their thread and see if they have anything that might fit your needs. They certainly seem to have a broader variety of spring options than most of the others.
2014 Trail Edition -
Build Thread
2015 Epic in my own mind trip
3wbdriver is offline   Reply With QuoteReply With Quote
Old 03-29-2018, 12:53 AM #3
transistor's Avatar
transistor's Avatar
Hmmm, considering you're near stock ride height at 325lbs, I could maybe install those superflex +10 springs and a 1" spacer to get the height I'm looking for with 400lbs. Besides the ride height, are you happy with the performance of the superflex +10 springs with all that weight?
I checked out the Dobinson thread and it looks like there aren't really any additional options for my scenario
Old 03-29-2018, 05:10 AM #4
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
Have a look at the Wheeler's coils.. minor lift options with some added coil rates should help you get close.
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 03-29-2018, 09:32 AM #5
Jhalko's Avatar
Jhalko Jhalko is offline
Real Name: Halko
Jhalko has a spectacular aura about Jhalko has a spectacular aura about
Jhalko's Avatar
Real Name: Halko
I would agree with CJ here. I’m running 250-300lbs more than stock and with the toytec HD rear springs I got just over 2” of lift. When I had springs just 10% stiffer it wasn’t enough for that weight. Given your desire for low lift you might research the low rise Dobinsons springs with a set of airbags. That way you get a little lift and the load carrying you desire. Just an idea.
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
Jhalko is offline   Reply With QuoteReply With Quote
Old 03-29-2018, 11:29 AM #6
samwhich's Avatar
samwhich samwhich is offline
samwhich has a spectacular aura about samwhich has a spectacular aura about
samwhich's Avatar
I have 5100s in front set at 2.5 and the RCC2.0 in back and love them. Netted a hair over 2" of lift. I also have a swing out carrier on back which is only 50 extra pounds or so with the added weight of a full sized spare (I removed my factory spare underneath)
I thought about getting the HDs but after talking with ToyTec they said it would ride like garbage unless you had a constant 200lb or more rear load at all times back there to get the spring rate to what it should be. So yes...if I were you I could go with the HDs over the the normal Superflexes.
Seeking rear coil recommendations for my situation-290601d1521919818-post-your-lifted-pix-here-lifted-jpg
| - 2016 Turd Bro - |
SSO Slimline / x20 | Dobinsons 314/327 - Airlift 1000 | Gobi Stealth Rack W/ Ladder | Dobinsons Snorkel | All Pro Sliders | Shrockworks Rear Bumper | 285 BFG KO2
samwhich is offline   Reply With QuoteReply With Quote
Question about rear weight and which rear coil to choose (tried searching) jeredcollins 3rd gen T4Rs 1 02-26-2018 10:24 PM
Can rear axel seals fix themselves? Unique situation... Jason B 3rd gen T4Rs 24 10-21-2016 01:50 PM
3rd gen stock coil springs, front and rear, no sag, plus rear sway bar STRRAYNGE For Sale: T4R Items 2 08-20-2012 01:29 PM
KYB Front coil over recommendations? Blueman2 3rd gen T4Rs 0 09-21-2010 10:39 AM
Rear Window doesn't go down and Wheel lock key situation. Gene4running Classic T4Rs 4 12-28-2009 06:54 PM
