Thread Tools Rating: Thread Rating: 3 votes, 2.67 average. Display Modes
Old 08-11-2021, 12:19 AM #76
4Reak Show's Avatar
4Reak Show's Avatar
Redarc brake controller install
Originally Posted by jmcelroy View Post
You make a good point. I had not considered the energizing voltage (pull-in) threshold to make the relay function. I looked it up and it seems pull-in is usually around 8-9VDC for these 12V relays so not a great candidate. I was going to test last night . . . but real life got in the way.
Can't find any documentation to support but can we assume that brake controller output on blue wire is between 3VDC and 12VDC depending on mode and pedal force applied?
Anyone got facts here?
I looked up a 6V relay and it may have the right specs to work for this use case.
Nominal Voltage: 6 VDC
Operate Voltage: 3.9 VDC MAX
Release Voltage: 0.6 VDC Min
Operate Time: 8 mSEC Max
Release Time: 8 mSEC Max
Temp Range: Operating -40 C to +85 C
Contact Arrangement: 1 Form C (SPDT)
Contact Material: AgSnO Silver Tin Oxide
Contact Millvolt Drop: 200mv @ 35A
Max Make Current: 90A/30A @ 16 VDC
Max Break Current: 40A/30A @ 16 VDC Resistive
Max Continuous Current: 40A/30A @ 23 C, 35A/25A @ 85C
Initial Breakdown Current: 500V RMS Contact to Coil
Expected Life: 100.000 Operation 40A 14 VDC Resistive on Normally Open Contact
SPDT(31.6x26.5x50.8)mm Plug-In
I hear you on this being a tow vehicle wiring problem and not a controller issue. I don't know enough about it to weigh in but it seems reasonable. Given that the pinouts for all of the tow controllers I've looked up only have brake pedal signal as input and trailer connector (blue wire) as output, it seems even more reasonable.
Guess I'm gonna not gonna have override lights on my camper.
Thanks for your research on this.
Jason
Yeah it’s big bummer that Toyota computer logic can’t see passed it.
To answer your question on brake controller operation, they have inertia sensors so really the pedal application input is just on or off. The force with which the pedal is applied is calculated via the inertia sensor in the brake controller. The settings I would guess range from 0 volts to charging voltage (13-14volts?) In my trailer set up I run Redarc at about 4 on the dial so what’s that like 40% give or take of max? So on light brake application (less extreme inertia/momentum shift present) the brake controller is going to apply UP TO that 40% mark. So even less than the 5 or so volts.
But all we’re concerned with is manual override which does the full value of which you have it set. So the 40% in my case during manual override. During normal braking the brake lights operate just fine remember. We’re ONLY concerned with manual override having the issues.
Therefore it’s unlikely to ever be much less than the 5 or so volts for most folks with these 4runners. But it could be higher I would guess.
Meaning even further, your 6 volt relay idea would probably work just fine.
The idea I came up with used a seperate feed line off of the back-feed principle through the trigger line stated earlier since we know the brake input is a 12v feed we could use for a relay
I say “magic box” because on a trailer the turn/brake is the same light but on the 4runner they’re seperate. Somewhere they combine. On my 95 4Runner there’s a magic box you buy to install between tail lights and trailer plug that combines it all.
Basically you mimmick the feed source to the plug instead of the output source. Still need 3 diodes and a relay and run of wire to and from the 7 way plug and brake controller. Pain in the ass regardless.
Old 06-28-2022, 09:57 AM #77
Scuba6's Avatar
Scuba6 Scuba6 is offline
Scuba6 is on a distinguished road
Scuba6's Avatar
TPSI-002 REDARC Tow-Pro Switch Insert Panel
Thanks for all the great info in this thread. I'm looking at installing one of these as I prep for a likely RV purchase.
Can anyone confirm that the TPSI-002 switch insert panel fits a 2011 LE?
The Redarc site shows it as fitting 2014 and later, but the sizing seems to be right for my 2011. I'm hoping to confirm before purchase.
EDIT: It does fit.
Thanks.
2011 Mag Grey Limited Probably not as modded out as yours
War Eagle!
Scuba6 is offline   Reply With QuoteReply With Quote
Old 06-28-2022, 10:24 AM #78
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
I suppose this is where Diode Dynamics got their “tail as turn” product idea.
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 11-18-2022, 08:21 PM #79
SeedyBear SeedyBear is offline
SeedyBear is on a distinguished road
I installed the Redarc today. Took about 1.5 hours because I'm uppity about nice wiring and plumbing.
Used the TPH-021 harness that plugged directly into the port above the parking brake area. Used the vehicle specific knock-out plug to mount the dial nicely. Good piece of kit, both.
Rather than mount the box on the side panel near the accelerator as many in this thread have done, I mounted it vertically against a module in the left side of the dash at about the height of the steering column. Right above the parking brake pivot point. Used GoPro/3M mounting tape. Fits nicely, short wire run to both the dial and the towing port.
Everything tested out fine once done. The trailer plug tester (LED) I used does *not* trick the tow controller into thinking the trailer is attached so I hooked up to our camper. All good with one exception noted earlier in this thread: No brake lights at the truck or the camper when using the tow module brake override. Can't say I care much about this but maybe I'll get bored in the future and setup a diode and relay between the electric brakes and brake lights on the camper.
I had been using the Curt Echo for the last year but I find it tedious. The brake application curve (voltage curve) is horrible, intermittently being weaker than expected or too strong. Bluetooth connectivity can be spotty. It protrudes too far downward given the orientation of the 4Runner 7-pin jack too. Think I'll sell it on to someone else.
Reading this thread was helpful. Thanks all for your contributions.
Jason
Hi, I just installed the Redarc Tow Pro Elite using the TPH-021 harness and I'm now seeing a warning on the dash of my 2022 4Runner. I've double checked and can't find anything that got disconnected during the install. I also tried disconnecting the Redarc and I still get the warning light. Adding to the challenge is that I don't see any information or description about this warning indicator anywhere in the manual and can't find it on the web. This is a 2022 4Runner. Any ideas / suggestions?
Thanks, Christian
Redarc brake controller install-dash-warning-jpg
SeedyBear is offline   Reply With QuoteReply With Quote
Old 11-18-2022, 08:51 PM #80
NB17Limited's Avatar
NB17Limited NB17Limited is offline
NB17Limited will become famous soon enough NB17Limited will become famous soon enough
Thanks, Christian
Unplug the brake controller and see if it goes away. If it doesn’t, then correlation does not equal causation
NB17Limited is offline   Reply With QuoteReply With Quote
Old 11-18-2022, 09:10 PM #81
Tried disconnecting the brake controller and I'm still seeing the warning. So, having the brake controller connected may not be causing the warning light, but did the process of connecting it trigger the warning. I'm trying to figure out if this just a "something changed" warning or warning of a problem. Is there a master warning reset?
Old 11-19-2022, 03:05 PM #82
Have you tried opening and closing the hood? I didn’t look closely at your original picture. That looks to be the hood ajar warning.
Old 11-19-2022, 08:11 PM #83
Yep, that was it. It had popped when I was working on the panel and not closed completely. I was so sure I'd hosed up something with the electrical, I didn't look at the simple stuff. Thanks for the suggestion.
Old 01-14-2023, 10:47 AM #84
Matt831 Matt831 is offline
Matt831 will become famous soon enough
Hello,
Was wondering if someone could guide me with the additional ground wire. I have a RedArc Tow Pro Elite and the Tekonsha 3041-P harness that plugs into an older Tekonsha Controller.
If I cut off the Tekonsha plug, and splice each color together on the RedArc, shouldI just tap into the white wire somewhere and run the white wire and eyelet to the ground again?
Thank you,
Matt
Matt831 is offline   Reply With QuoteReply With Quote
Old 01-15-2023, 12:55 PM #85
4Reak Show's Avatar
4Reak Show's Avatar
Originally Posted by Matt831 View Post
Hello,
Thank you,
Matt
Yes.
Old 01-17-2023, 10:53 AM #86
Humble Leader's Avatar
Hello,
Thank you,
Matt
you could splice, or just order the redarc harness, makes it easier and not really that $$$
Toyota suitable Tow-Pro Brake Controller Harness (TPH-021)
Old 09-24-2023, 05:32 PM #87
spottyj's Avatar
spottyj spottyj is offline
spottyj is on a distinguished road
spottyj's Avatar
Thanks, Christian
SeedyBear
Outside of the hood open issue! - how has your Redarc Tow Pro Elite using the TPH-021 harness been working?
Any codes/lights/ABS issues?
Running lights work?
Does the trailer lights work when manually activating the trailer brakes?
Did you just plug the TPH-021 from the RedArc Controller into the 4Runner?
Any extra splicing?
TIA
spottyj is offline   Reply With QuoteReply With Quote
Old 09-26-2023, 02:31 PM #88
Originally Posted by spottyj View Post
SeedyBear
Any extra splicing?
TIA
it's plug and play. I have that harness. no splicing
Anyone ever install a trailer brake controller? Qyota 3rd gen T4Rs 1 10-07-2012 08:46 PM
Brake Controller Help stiner0931 4th Gen T4Rs 1 05-08-2011 10:55 PM
Which brake controller does everyone use? gkatmar General Discussions 5 09-08-2008 04:04 PM
Brake Controller salrosa 3rd gen T4Rs 6 10-25-2007 08:06 PM
Best place to install a brake controller? darkmark Engines / Suspension / Wheels / Tires / Audio / Accessories 14 08-29-2006 03:45 PM
