Old 04-21-2018, 07:42 PM #1
ScarfaceT4R's Avatar
ScarfaceT4R ScarfaceT4R is offline
Real Name: Christoph
ScarfaceT4R will become famous soon enough
Rear Sway Bar Bushing Bracket Install
I haven’t seen a lot of info within one thread regarding the details of swapping out our 5th Gen T4R’s rear sway bar brackets/bushing that attach to the rear axel. Probably because our 5th Gen’s are too new to need the bushings replaced, but besides this being a Hyper-Flex polyurethane product that is advertised to last much longer & provide less body roll than OEM rubber bushings – maybe you just happened to ruin your stock setup like I did…womp, womp…So here ya go!
As you can see here, one of my OEM brackets was bent to heck during the install of a OME trim packer on my driver side (bent bracket pictured below in the back – you know, the one all bowed up an what not). I tried bending it back & everything I could to get it fixed but I gave up – the thing is pretty resilient!
After numerous searching for the size of a 5th Gen rear sway bar, I was finally able to download the spec sheet for a 2013 TR4 SR5.
https://www.google.com/url?sa=t&rct=...g4Dl4X6rZM_gvI
The sheet lists the diameter of the rear sway bar at 0.787” or 1.18” w/ KDSS. I am not KDSS equipped. Now for math. 0.787” = 19.9898mm. I have seen people on this forum state that their bushings they ordered from Energy Suspension were 19mm, and if you do the vehicle specific product search on the website, they will also recommend a 19mm (0.74”) bushing. Why they recommend a bushing that is 0.74” when the specs for our 5th Gen’s state that our bars are 0.787”, I don’t know??
So given our 0.787” sway bars equal dang near 20mm, that’s what I went with. I went with part number 9.5124R which is a 20mm (0.78”) non-greasable universal bushing. I chose the non-greasable one because it was cheaper to have the option without the little nipple that you can run a grease gun up to. You still need to grease it with the included grease (& I bought the 3 grease pack for future use). You have options of red or black bushings. I chose red because Toyota.
As you can see here, the OEM black bushing has a 20 on it. Not too sure it means 20mm, but I’m kind of guessing that’s what it stands for. While researching bushing sizes, the Energy Suspension site has a really good 6 or 7 methods for determining the size of your sway bar. They state that just because your spec sheet may read one size, or someone else’s sway bar is one size, that may not mean yours is that size. They say that they have noticed that some model of cars may have 7 or 8 different size sway bars.
You will want to jack up the rear via the rear diff & place jack stands below the rear axle. You don’t want to set the truck down on the frame with the jack stands because you want the suspension to be compressed for this install as to prevent binding of the bushings when lowering the 4Runner back onto earth. Raising up by the rear axle will also allow the sway bar to remain parallel to the ground, which is what you want. Remove wheels for easy access. You will need a 9/16 socket for 3 of the bolts & a 9/16 wrench for the upper bolt on the driver side, due to the gas tank making it difficult to fit the socket & socket wrench behind.
Like I said, I went with the 20mm bushing (unlike the 19mm that a few people suggested), & I wish I went with 21mm. I test fitted this one without applying the grease (if you apply the grease you cannot exchange/return them), and by just hand tightening it around the sway bar it looks like it could be a tad short on the circumference of the sway bar. I figured once I tightened everything down it could squeeze the bushing tight to be a perfect fit, so I went ahead and applied grease to the inside of the bushing and around the outside that sits inside the bracket as instructed. This grease, entitled ‘Formula 5 Prelube’, seems like it will last forever on this bushing – although I know that cannot happen over time. But this stuff really sticks well & seems very well made. I suggest rubber gloves as this stuff is very hard to get off of your hands.
After you unscrew the OEM bolts, save them as you will need to reuse them on the new brackets. The new brackets also came with new washers but I just used the old washers that I had on the bolts before as they seem a little beefier. Installing the new bushing & bracket was a breeze & I really don’t have too much advise on the actual process of that besides just try not to get that grease on your hands or tools.
After I tightened the brackets up the gap size of the bushing nearly disappeared :reckon:
After throwing the wheels back on & lowering the car I think it looks very nice! Can’t wait to drive it around and inspect it after a few road trips. Next will prob be the end link bushings in red poly, along with the front sway bar bushings.
Hope this helped!
Happy wrenching!
Rear Sway Bar Bushing Bracket Install-2-jpeg  Rear Sway Bar Bushing Bracket Install-5-jpeg  Rear Sway Bar Bushing Bracket Install-4-jpeg  Rear Sway Bar Bushing Bracket Install-3-jpeg  Rear Sway Bar Bushing Bracket Install-6-jpeg  Rear Sway Bar Bushing Bracket Install-1-jpeg  Rear Sway Bar Bushing Bracket Install-7-jpeg  Rear Sway Bar Bushing Bracket Install-9-jpeg
3" lift up front courtesy of 5100 Billys & Toytec HD coils + top hat spacers, 5160 Billys in rear w/ Toytec Superflex 2" coils, front Wheelers bumpstops/2" rear Toytec bumpstop drop, TRD Pro skid, Icon UCA's, Pelfreybilt sliders, HID's & LED's galore, full MBRP Catback, K&N CAI, Fuel Tactic 17x9's -12mm , 285/70/17 Cooper STT Pros, Total Chaos BMC kit, etc..etc..blah, blah
ScarfaceT4R is offline   Reply With QuoteReply With Quote
Old 01-03-2019, 02:34 PM #2
jahdai42's Avatar
jahdai42 jahdai42 is offline
jahdai42 is on a distinguished road
jahdai42's Avatar
Did you do the front bushings? How do they feel?
2016 Trail,
jahdai42 is offline   Reply With QuoteReply With Quote
Old 01-03-2019, 02:43 PM #3
I haven't done the fronts yet but I plan on it. The only reason I did the rears is because I bent the sway bar bracket so much when installing my rear springs. I want to do the front now so they match the rears, but as far as performance wise, I couldn't tell ya the difference. With the lift though, you can see the fronts very well, so installing these red ones would just be extra eye candy IMO.
Old 01-18-2019, 10:04 AM #4
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
I ordered 21mm bushing, I'll see how it goes
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 04-30-2019, 02:02 PM #5
How did the 21mm bushing install work out for you?
Old 04-30-2019, 02:27 PM #6
Akkording's Avatar
Akkording's Avatar
I didn't install them my buddy said to use the 19/20 whatever the stock size was. I still have them in the garage if you want them I'll send them to you just cover shipping
Old 04-30-2019, 03:00 PM #7
Oh ok gotcha! I'm still rocking the 20mm rears. So far so good. Was just curious as to how the 21mm fitment was. Thanks!
Old 04-30-2019, 03:33 PM #8
Akkording's Avatar
Akkording's Avatar
Old 06-16-2019, 03:15 PM #9
BudRunner BudRunner is offline
BudRunner is on a distinguished road
Checked with calipers. Front is 30mm and rear is 20mm. This is a 2019 SR5 4x4.
Ordered those sizes of Prothane's off Amazon. Will check back to report on fit after I install. Thanks
BudRunner is offline   Reply With QuoteReply With Quote
Old 10-09-2020, 05:46 PM #10
Jono.ful's Avatar
Jono.ful Jono.ful is offline
Jono.ful will become famous soon enough Jono.ful will become famous soon enough
Jono.ful's Avatar
you guys still run sway bars?
wow, crazy.
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Jono.ful is offline   Reply With QuoteReply With Quote
Old 10-09-2020, 09:02 PM #11
TRUSTYAXE's Avatar
TRUSTYAXE TRUSTYAXE is offline
TRUSTYAXE will become famous soon enough TRUSTYAXE will become famous soon enough
TRUSTYAXE's Avatar
wow, crazy.
I've read about this a bit, talk to me, you removed the sway bars? For more travel?
I was born in Thunder bay so be nice
2015 TRDPRO SUPER WHITE ~ ROOF RACK DELETE ~ REAR SEAT DELETE ~ LED ANYTIME FOGS ~ DRL DISABLE ~ DOMETIC CFX-28 ~ BORLA CAT BACK ~ SPRINT BOOSTER V2 ~ aFe MOMENTUM GT INTAKE ~ OTHER JUNK N STUFF
TRUSTYAXE is offline   Reply With QuoteReply With Quote
Old 10-09-2020, 09:05 PM #12
TRUSTYAXE's Avatar
TRUSTYAXE's Avatar
Originally Posted by beedee View Post
How did they workout for you? I have a 2018 SR5 4x4, figured I might as well upgrade if its worth it.
Excellent write up by the OP, some mods work for one but not others. To me Poly = squeaking, and grease guns and annoyance. But that's just me, body roll was reduced for sure, but I'm smoother over bumps now so its a trade off.
Old 10-10-2020, 12:27 AM #13
Jono.ful's Avatar
Jono.ful's Avatar
Yes.
Eventually you get to a point with ET/LT where the stock sway bars become a limiting factor in suspension travel. You do absolutely get more body roll, but a good suspension setup will mitigate most of it.
Old 03-09-2021, 05:57 PM #14
garc1809 garc1809 is offline
garc1809 is on a distinguished road
Question how did the 31mm front bushing and 20mm bushing worked out for you? I just measure my and getting same As you.
garc1809 is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 08:45 AM #15
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Do you get any squeaking from the poly? considering switching myself.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
4runner , bar , bracket , bushing , sway
Solution: Sway bar bushing bracket with broken nut JeratBP 4th Gen T4Rs 13 10-05-2022 08:17 AM
Sway bar bushing install - Broken frame thread insert Will816 4th Gen T4Rs 22 06-03-2021 08:27 PM
Successful Front & Rear Sway Bushing Install treverd 3rd gen T4Rs 1 07-22-2016 04:53 PM
Sway Bar / Bushing Bracket Questions mattr 5th gen T4Rs 7 09-27-2015 06:25 PM
Rear Sway Bar Bushing/Bracket Volley 3rd gen T4Rs 8 04-11-2012 12:04 PM
