Real Name: Nick
Real Name: Nick
Installed OEM Audio Plus and have no sound after install.
Any idea what the cause could be? I went through and verified all connections were correct.
Edit: So I just connected the original 6pin and 10 pin connections at the head unit and now have sound... (these were initially plugged into the amp/sub wiring harness). Is it safe to assume that the wiring harness for the amp/sub is bad... Or could it be the fuse? I don't have any spare fuses to test it at the moment...
2016 Trail Premium Mag Gray w/KDSS, TRD Pro Wheels wrapped with Cooper STT Pro 285/70R17, Fox Shocks 2.5" remote resi with DCS adjuster F/R, SPC UCA's, Pelfreybilt bumper, 15% Ceramic Window Tint, Shrockworks sliders, TRD Pro Intake, Baja Designs sitting on Rago Ditch Brackets and Ecotechne Rack, Rago MSPs in Cargo area, Baja Designs LEDs
