Originally Posted by Uneeq
These are not the new rigid LED fogs on the 2019 TRD Pro. Those aren't available for purchase from dealers yet unless you have a 2019 TRD Pro VIN.
You are correct, these are not from Rigid, these are Toyota parts (PT413-42191, PT413-42190) listed to fit the following:
Toyota 4Runner 4.0L V6 AT 2019
Toyota C-HR 2.0L CVT 2019
Toyota Highlander 3.5L V6 4WD AT LE 2018
Toyota Highlander 3.5L V6 4WD AT LE Plus 2018
Toyota Highlander 3.5L V6 4WD AT LIMITED 2018
Toyota Highlander 3.5L V6 4WD AT Limited Platinum 2018
Toyota Highlander 3.5L V6 4WD AT SE 2018
Toyota Highlander 3.5L V6 4WD AT XLE 2018
Toyota Highlander 3.5L V6 AT LE 2018
Toyota Highlander 3.5L V6 AT LE Plus 2018
Toyota Highlander 3.5L V6 AT LIMITED 2018
Toyota Highlander 3.5L V6 AT Limited Platinum 2018
Toyota Highlander 3.5L V6 AT SE 2018
Toyota Highlander 3.5L V6 AT XLE 2018
Toyota Highlander Hybrid 4WD LIMITED 2018
Toyota Highlander Hybrid 4WD Limited Platinum 2018
Toyota Highlander Hybrid 4WD XLE 2018
Toyota Tundra 4.6L V8 AT CREW MAX SR-5 2018
Toyota Tundra 4.6L V8 AT Double Cab SR-5 2018
Toyota Tundra 5.7L V8 AT Crew Max Limited 2018, 2019
Toyota Tundra 5.7L V8 AT Crew Max Platinum 2018, 2019
Toyota Tundra 5.7L V8 AT CREW MAX SR-5 2018, 2019
Toyota Tundra 5.7L V8 AT Double Cab Limited 2018, 2019
Toyota Tundra 5.7L V8 AT Double Cab SR-5 2018, 2019
Toyota Tundra 5.7L V8 FFV AT Crew Max Limited 2018
Toyota Tundra 5.7L V8 FFV AT Crew Max Platinum 2018
Toyota Tundra 5.7L V8 FFV AT CREW MAX SR-5 2018
Toyota Tundra 5.7L V8 FFV AT Double Cab Limited 2018
Toyota Tundra 5.7L V8 FFV AT Double Cab SR-5 2018
I would have tried these had I not already purchased the made in Japan individual ones posted by OP.
