Thread Tools Rating: Thread Rating: 5 votes, 3.40 average. Display Modes
Old 04-28-2018, 06:45 PM #1
Louisiana Overland's Avatar
Louisiana Overland Louisiana Overland is offline
Louisiana Overland is a jewel in the rough Louisiana Overland is a jewel in the rough Louisiana Overland is a jewel in the rough
Fridge Install Help
I am planning to install a donetic 50 cfx fridge in the cargo area. Can anyone recommend a wire size and outlet to install for power? Or...is the factory socket wired large enough and can it be modified to always be "on"?
Louisiana Overland is offline   Reply With QuoteReply With Quote
Old 04-28-2018, 07:22 PM #2
TowMeOut's Avatar
TowMeOut TowMeOut is offline
TowMeOut is on a distinguished road
TowMeOut's Avatar
ARB has about the best pre-packaged wiring kit for fridges. It comes with a socket that can be used as a regular cigarette lighter plug or there's a slight modification that makes it a locking plug. I'd guess your fridge comes with that type of plug.
The stock wiring will run it and I've seen a few threads on modifying it to constant on. However, the wiring is small so there's a lot of voltage drop between the battery and rear cargo area. You're much better off in the long run to just run a dedicated line.
https://www.4wd.com/p/arb-12-24v-dc-...hoCBq4QAvD_BwE
I went overkill and skipped the kit/plug and just ran 8awg from the battery to the rear with an anderson connector. These are non-gender specific yet polarized plugs that basically can't vibrate loose. I went with the bigger wire assuming I might add some additional lights and such in the rear in the future and would need a ready source of constant 12V power. Up front it's fused near the battery.
Find yourself a good youtube video or thread on running the wire. On my 4th gen the main harness runs along the floor under the driver's side door sills. Not sure if it's the same on the 5th gen. This is the most straightforward place to go then you don't have to mess with the carpet and such. There are a few unused rubber grommets in the firewall to get you through to the engine compartment and battery. About any car audio shop can help you out with the process too.
Good luck
06 Sport 4x4
185K and counting
Bilsteins, FJ/Tacoma springs
Nitto Terra Grapplers
TowMeOut is offline   Reply With QuoteReply With Quote
Old 04-28-2018, 11:10 PM #3
e60ral e60ral is offline
Banned
e60ral will become famous soon enough
Banned
run 8ga and install a locking marine type outlet (or swap it all to anderson)
search for 8ga zip cord or zip wire, ex:
https://www.dxengineering.com/parts/dxe-pw-8
or any place near you that installs car stereos will probably sell you some by the foot
e60ral is offline   Reply With QuoteReply With Quote
Old 04-29-2018, 01:17 AM #4
Good luck
Great tips. I just finished an audio upgrade project. The specified wire size for the amp was 4 gauge. I opted for a 2 gauge dual amp wiring kit even though I only utilize a single amp. So....I already have an always on 12v fuse block available on the unused side of the distribution block. This is located under the drivers seat.
Thanks for the replies.
Old 04-29-2018, 09:26 AM #5
mjohns2 mjohns2 is offline
mjohns2 is on a distinguished road
I went with a 10 Gauge
GS Power's 10 Gauge Ga, 2 Rolls of 100 Feet (total of 200 ft) Car Audio Video Power Primary Remote Turn on Hook up Trailer CCA Wire
mjohns2 is offline   Reply With QuoteReply With Quote
Old 04-29-2018, 09:27 AM #6
Jhalko's Avatar
Jhalko Jhalko is offline
Real Name: Halko
Jhalko has a spectacular aura about Jhalko has a spectacular aura about
Jhalko's Avatar
Real Name: Halko
I’d recommend running your own wire, it’s not that hard. I know a few have used factory wiring but may not be as efficient. I’d also strongly recommend the locking style 12v.
Pics of mine here
Jhalko's 2011 Limited build/travel thread
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
Jhalko is offline   Reply With QuoteReply With Quote
5th Gen ARB Fridge Install Cypher 5th gen T4Rs 38 10-19-2021 02:50 PM
Snomaster Fridge / Blue Sea Panel Install AutoRotate 5th gen T4Rs 2 09-16-2017 02:14 PM
Fridge Slides / Tilt Fridge Slide - Any Interest? kags1969 Group Buys 5 04-24-2017 08:00 PM
ARB fridge wiring loom install help Toycdn 5th gen T4Rs 14 07-27-2016 02:55 PM
Indel-B Portable Fridge/Freezer from Truck Fridge Khjphoto General Discussions 2 02-29-2016 08:09 PM
