Originally Posted by Fried_man7
Question on your 4runner 5th gen king set ups. What’s the difference between the stage 1 and 2? Included UCAs? And different coil around the front coil overs? What would you suggest? I have non kdss. I will primary be highway and Boston city roads and will go off rod on trails with no Baja or rock crawling in the near future. Tried to PM but I may have screwed that up.
Our Fulfillment Team created 2 bundles to help make the ordering process a little easier.
Stage 1 Kit is your normal Coilovers and Rear Shocks.
Stage 1A Kit is you normal Coilovers w/Adjusters and Rear Shocks w/Adjusters
Since these are typically build to order, Upgrading to Extending Travel and/or Upgrading Coil
from 550 to 600, 650 or 700lb is at No Extra Cost.
Upgrading the front coil to 600 or 650lb are both great options for 5th Gen at stock weight.
To see these kits -
Click Here
There are so many great options for UCA's and Rear Coils that we currently deactivated the
Stage 2 and Stage 3 Kits.
We are working on updating the Stage 2 Kit to better fit the most popular build right now;
Part #25001-278 (Extended Travel, w/650 Upgrade)
Part #25001-279 (Extended Travel)
Part #96504 (Total Chaos UCA's)
Part #52700 (ICON 2" Rear Coil)
This is a great build and option you will be happy with as well.
Remember to use Promo Code "T4R" for added savings on most brands.
_
