08-30-2018, 01:07 AM
#46
Following
08-30-2018, 07:09 AM
#47
I like these
Sent from my P00A using Tapatalk
09-01-2018, 02:29 PM
#48
Real Name: J. Schmidt
Ride height
Those Radflos and custom lower links look great! How is the ride-height with the Radflo custom shocks? Is it taller, or does it offer more clearance than a 3" OME lift?
09-01-2018, 10:06 PM
#49
Shocks don't affect ride height
09-02-2018, 07:04 PM
#50
Originally Posted by sschaefer3
Are the Radflos available with out a res?
Thanks in advance
2016 TEP, KDSS, ALPRO Apex Sliders, Focal IS690TOY, Old Red's Accessory Meter Display Mod , Rear Differential Breather Mod, Radium Fuel Surge Tank, URD Supercharger , Ironman FCP shocks
09-02-2018, 10:14 PM
#51
Thanks in advance
sounds like it'll pull a bit less travel without the res. The res helps save room in the actual shock for more compression I believe.
09-02-2018, 10:25 PM
#52
Yep. Above the top of the travel of the piston needs to be room for an internal floating piston which separates the shock oil from the nitrogen, and space for the nitrogen. With a remote reservoir, the shaft can compress further into the shock body as the piston and nitrogen are in the reservoir.
09-03-2018, 03:22 PM
#53
Thanks in advance
No they have to have the reservoir to maintain the stock compressed length and add additional down travel.
09-03-2018, 03:23 PM
#54
Great photo showing what goes on inside.
09-14-2018, 06:32 PM
#55
I have found a fork lift.
09-21-2018, 02:39 PM
#56
Here they are !!!
09-22-2018, 09:38 AM
#57
Looks awesome....idk though wife might need more travel going to the safeway by us. The entrance is very overlandy
09-22-2018, 10:40 AM
#58
Got my bar installed last night. Easy install but Toyota really cranked the bolt at the frame attachment.
09-22-2018, 12:23 PM
#59
Look Great! On those bolts you want to loosen the head of the bolt with the washer, the nut has feet that dig into the steel. If you un-did the nut, that would make it much more difficult. All the rear link parts on these, 3rd gen, 4th gen and FJ's are all like this. Loosen the end with the washer, the other end has feet that dig in. Axle side only has the head.
09-22-2018, 12:28 PM
#60
Yes, I noticed that after I pulled it off. By Instinct I went for the nut side. A little leverage got it loose.
