Old 12-29-2018, 12:58 AM #1
DreamsOfDirt's Avatar
DreamsOfDirt DreamsOfDirt is offline
DreamsOfDirt will become famous soon enough DreamsOfDirt will become famous soon enough
Sound Deadening Project Write Up
In this thread I'll share my experience in self installing sound deadening. Hopefully someone else can learn from my mistakes.
I decided to add sound deadening to my 2018 ORP for two reasons: improved audio quality and reduced road noise. My primary focus in the doors and tailgate, but I expect I'll end up doing the floor too in order to abate the road noise.
After research on this forum, google, and Youtube, I decided to utilize Soundskins brand sound deadening - at least for the doors. As you might imagine there are seemingly endless options from the classic Dynamat to more non-traditional materials like Frost King Duct wrap (I believe Antman did a mod with something similar to the latter). In the end I selected SoundSkins given it combines the foil and butyl of Dynamat extreme with acoustic foam for an all in one product.
I had a full eight hours to myself, surely enough time to knock out the doors and tailgate - nope. I ended the day with only one door done. Some of this was natural learning curve. Some of it was a couple trips to the hardware store. Finally, some of this was due to some OCD tendencies. I knocked out the second door (outer and inner skin) in 3 hours. I'm confident I will do the third door in even less time.
Here's what I learned from that first debacle of a day (in order importance):
1. Using a large single sheet of sound deadening material on the inner skin (metal that the trim panel hooks to) looks cool but is a giant, time consuming, pain to accurately cut. You'll end up needing two pieces anyway if using the SoundSkins Pro roll due to the 4runner door size. Listening to the online videos, it seems simple enough: make a template/tracing on paper or semi-transparent tape, and then cut the sound deadening material to match. Per online suggestions I tried using carpet protection sheeting (tape) - too sticky to get laid out without crinkles / make a good trace. If you had a second person to help you layout the tape tie might work better. I also tried wax paper with some success, but still had some issues with alignment. When I moved to the passenger door I used several pieces on the interior skin, it doesn't look as nice as a full sheet, but it looks pretty good AND is infinitely easier to work with and quicker. Below I've posted a picture of the completed passenger door - two larger pieces to cover the two larger holes in the door panel. several small pieces to fill in around bolts, speaker, etc. If I have one piece of advice, it's to use multiple pieces.
2. Look carefully at your door and the backside of the trim panel prior to starting to apply material to the inside skin. I made a mistake on the first door of covering a couple of holes for trim clips and I went way to high up on the door with material (1/2 inch from the window). This resulted in me pulling off material to get the door panel back on and really pissing me off because it looked like crap after all my work to use one larger sheet on the driver side.
3. Watch videos online. The Taco Tunes guys have some great videos including one on taking off the trim panel. With their video and one door of practice I was down to 9 minutes to remove the panel off the second door. Sound Skins videos were somewhat helpful, but I found that when putting material inside of the door their cardboard method of sizing pieces was more cumbersome than just measuring with a small tape measure. Finally, Car Audio Fabrication has several great videos and links to products used. I appreciated the tip to try to use carpet protection film instead of the pricey Tesa tape to make a template/tracing, even though it didn't work for me. One good tip from them was to use leather punches to make perfectly round holes in the material for bolts/wires. My local Ace hardware guy actually found a cheaper way - take a metal tube (he gave me copper) of the diameter you want (I chose 1"), and sharpen one end of the tube (he did it for me in the back).
Taco Tunes:
https://www.youtube.com/watch?v=0AB4...cxCy7xCidVhEXf
Sound skins official video:
https://www.youtube.com/watch?v=5PZx189lR2k
Car Audio Fabrication:
https://www.youtube.com/watch?v=oIzkhrkTZwk
4. The adhesive Toyota uses to hold the factory plastic sheeting on over the holes is the devil. In a perfect world, all the material should be taken off, but after far too much time trying I just left some on there and sound deadened over it. Not ideal, but I'm expecting / hoping it won't cause major issues.
5. The piece of styrofoam held in place with two bolts inside the door is also adhered with foam tape to the outer skin. It can be removed by working it back and forth and pulling it back towards yourself/up. Removing the foam adhesive is also a pain, but not as bad as the devil adhesive above.
6. When cutting pieces for the outer skin (inside the door), I found it easiest to do five pieces: two pieces going from the bottom of the door up to the cylindrical support bar (meet in the middle of the door), two pieces above the support bar, but in this case I ran pieces the entire width of the door, about 10" high. for the top strip I stopped at the edge of the door handle assembly. Finally, one piece wrapped around the support bar.
7. Others have suggested wearing long sleeves and gloves to protect against cuts from sheet metal. The shirt was somewhat helpful, but I didn't like the gloves. Going forward I'm going to wrap a strip of fabric around my wrist and then wrap it in duct tape. I cut both my wrists as I was trying to place the material in the bottom interior of the door. the space is tight and I cut them when turning my hands. My fingers survived unscathed.
8. Suggested tools: Snap off knife or utility knife (I preferred snap off knife, although I used both) (required), socket set (required), Phillips screwdriver (or drill with Phillips bit) (required), small flat head screw driver (required), seam roller - wooden or plastic (I recommend ordering online in advance. Home Depot does not carry them and I ended up getting a plastic one from Ace in a pinch) (required), panel tools, sharpie, small tape measure (smaller size is easier to manipulate with one hand inside of the door), cardboard or plywood to cut material on, rubbing alcohol or degreaser to clean metal, rags, scissors (useful if you need to cut material once it's applied and you need to peel it back), 1" leather punch or copper pipe for making clean holes, stool to sit on, old blanket to set your door panel on once removed, and Tupperware to keep all door hardware in while you work.
9. When prying off the small square access point on the trim to access the screw, use your screwdriver and put it in the corner, not the middle. It will pop off easier. You can see in the pic below I scratched the trim panel a bit when I tried to put the screw driver in the middle. Still pissed at myself for that one.
10. Make sure all clips are in the trim panel (not in the door) before trying to re-install the trim panel onto the door.
That's it for now - more to come as I move to other doors (hopefully next week), and eventually onto the floor.
Sound Deadening Project Write Up-img_4068-jpg  Sound Deadening Project Write Up-img_4077-jpg  Sound Deadening Project Write Up-img_4078-jpg  Sound Deadening Project Write Up-img_4083-jpg  Sound Deadening Project Write Up-img_4065-jpg
2018 TRDORP w/KDSS, Cooper AT/3s, Rago cross bars, TRDP Black wheels, front grille, black valances, Kenwood Excelon DNX996, working on the rest...
DreamsOfDirt is offline   Reply With QuoteReply With Quote
Old 12-29-2018, 02:53 AM #2
GOJI4RA's Avatar
GOJI4RA GOJI4RA is offline
GOJI4RA is on a distinguished road
GOJI4RA's Avatar
Awesome job man! Nice to have a few pointers before I attempt the same task!Sound Deadening Project Write Up
Sent from my SM-N960U using Tapatalk
GOJI4RA is offline   Reply With QuoteReply With Quote
Old 12-29-2018, 07:03 AM #3
KEVIN C.'s Avatar
KEVIN C. KEVIN C. is offline
KEVIN C. will become famous soon enough
KEVIN C.'s Avatar
Excellent. I have a roll of Soundskins to install and this is helpful.
KEVIN C. is offline   Reply With QuoteReply With Quote
Old 12-29-2018, 10:42 AM #4
heisenbise heisenbise is offline
heisenbise is on a distinguished road
How many rolls do you think it’ll take to do the doors and hatch?
Been thinking about sound treating the 4Runner with inner/outer door layers as you’ve done, but never got as far as actually taking some measurements.
Looking forward to your floor tips when you inevitably do that too :-)
heisenbise is offline   Reply With QuoteReply With Quote
Old 12-29-2018, 11:34 AM #5
After the front two doors I’ve used about 2.75 rolls. Admittedly, I wasted a bit on the first door. I expect the four doors, plus the hatch will take about 6 rolls. This is in line with what the soundskins web site states- one roll for each sedan sized door, doing both inner and outer door skins, knowing our doors are bigger. I’ll update this thread with actual material usage.
Old 12-29-2018, 12:31 PM #6
mustangr2 mustangr2 is offline
mustangr2 will become famous soon enough
Looking forward to hearing how well it cuts down the noise. I been thinking about doing something like this. Dam it another thing to add to the list. LOL
mustangr2 is offline   Reply With QuoteReply With Quote
Old 12-31-2018, 08:54 AM #7
MSU_Spartan's Avatar
MSU_Spartan MSU_Spartan is offline
MSU_Spartan is on a distinguished road
Nice write up and agree. Looking forward to your feedback on whether it was worth it. I’m also considering. Deciding do I just replace the speakers and move on or add the sound deadening too.
2018 4R TRD ORP Magnetic Grey w/ KDSS - TRD Wheels | 265/70 R17 E Bridgestone Dueler A/T Revo3 | Nfab Step | AVS Bugflector | Maxpider 3D floormats | Emblem blackout | XD 5000k HIDs | Philips LED Fogs + Lamin-X Overlays | Philips LED interior lights | Compustar Remote Starter + DroneMobile | Ellis Precision Shift Knobs | ProClip Dashmount Cellphone holder
MSU_Spartan is offline   Reply With QuoteReply With Quote
Old 01-08-2019, 12:17 AM #8
Rear Door(s)
This last weekend I made it through one of the rear doors and learned a few new things:
1. The super thin panel tool is THE tool you need to use (pics below) this thing is perfect for getting out the square screw cover I scratched in on the driver side door. Additionally, it's good for scraping off the black devil adhesive that holds the factory plastic on.
2. Don't get over confident after the front panels and start just pulling off the panel like you're starting a lawn mower. I partially broke a couple clips by pulling too fast/hard (pics below). Luckily they still function. You can pull hard, but think of it as pulling just that one clip out, then slide your hand over and pull out the next one and so forth. You'll probably get a couple, and that's cool. Where I had an issue was pulling like the whole panel was going to come off at once.
3. The duct tape wrist bands worked well for protecting my wrists.
4. The combination of hole opening and door size make the back doors tighter to work in and harder to put material inside of (outer skin) than the front doors.
5. I like having two tape measures and two sharpies - one with me at the door for when I'm working on it and one at the work bench where I'm cutting the material.
6. The back trim panel is harder to put back on than in the front. Specifically getting the top of the panel to catch the upper sheet metal edge by the window. I read on another thread it's helpful to roll the window down. I will try this next time.
7. On the FRONT doors I do notice the bass being tighter / not muddy, even with factory stereo & speakers still installed. Road noise seems similar to original. I expect this will improve with the other doors being done and potentially the floor.
I ran short on time and forgot to take a pic of the completed rear door - I just have one half way through with the outer skin done. I'll get one next time.
More to come...
Sound Deadening Project Write Up-img_4100-jpg  Sound Deadening Project Write Up-img_4102-jpg  Sound Deadening Project Write Up-img_4103-jpg  Sound Deadening Project Write Up-img_4111-jpg  Sound Deadening Project Write Up-img_4113-jpg  Sound Deadening Project Write Up-img_4115-jpg  Sound Deadening Project Write Up-img_4117-jpg
Old 01-08-2019, 02:03 AM #9
Duuuuuuuude Duuuuuuuude is offline
Duuuuuuuude is on a distinguished road
I'll be diving into the same project in the next week or so. Thanks for the details.
Duuuuuuuude is offline   Reply With QuoteReply With Quote
Old 01-08-2019, 09:18 AM #10
KingTaco's Avatar
KingTaco KingTaco is offline
KingTaco is a jewel in the rough KingTaco is a jewel in the rough KingTaco is a jewel in the rough
KingTaco's Avatar
Hats off to @DreamsOfDirt and others who tackle this project. I'd love to do this to the full cab, but know I will never bite the bullet and remove the ceiling and floor. I hope it gives you the results you are after.
KingTaco is offline   Reply With QuoteReply With Quote
Old 01-08-2019, 09:36 AM #11
4RExplorer 4RExplorer is offline
Real Name: Ted
4RExplorer is on a distinguished road
Real Name: Ted
Very helpful description. From the pictures, it looks like there may be room in the doors to install additional storage areas.
2019 4Runner TRD Off Road
4RExplorer is offline   Reply With QuoteReply With Quote
Old 01-08-2019, 01:49 PM #12
007Tacoma's Avatar
007Tacoma 007Tacoma is offline
Real Name: Mark the Common Sense Wizard
007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice
007Tacoma's Avatar
Thank you for putting all this together. This is on my 2019 to-do list!!!
Also, Taco Tunes has done some amazing work lately. Got to see their show 4Runner last year, and it was impressive.
I'm 007Tacoma.
...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
007Tacoma is offline   Reply With QuoteReply With Quote
Old 01-08-2019, 01:52 PM #13
Offwidth Offwidth is offline
Offwidth is on a distinguished road
I can highly recommend Noico’s stuff for sound deadening mats. Used both mass loaded vinyl and self adhesive foam mats and prefer that over dynamat- for much lower price.
They also make nice little roller tool - metal and ribbed. Use that over rubber smooth rollers.
Offwidth is offline   Reply With QuoteReply With Quote
Old 01-08-2019, 03:11 PM #14
tigger tigger is offline
tigger is on a distinguished road
Couple of suggestions.
There is absolutely no advantage to trying to use 1 whole sheet or just a few really large pieces. No one sees behind the door panel and it doesn't make a difference in sound reduction. This product is mainly to reduce vibrations. Using a full sheet is far more important when installing Mass Loaded Vinyl as this is where the most sound reduction will come from.
Make sure to thoroughly clean the inside of the door with isopropyl alcohol.
Not cleaning all of the vapor barrier adhesive will have no affect on the adhesion of the CDL
When pulling off the door panel, pull straight out from the window, not up. There is a bar that fits into the window channel that has clips that the door panel click into. Makes it 100 times easier to reinstall.
tigger is offline   Reply With QuoteReply With Quote
Old 01-08-2019, 03:18 PM #15
4RDoc 4RDoc is offline
4RDoc is on a distinguished road
Any initial impressions of how it’s working? Is your audio better and noise decreased? Looking forward to hearing about your results when it is complete
4RDoc is offline   Reply With QuoteReply With Quote
dampening , deadening , dynamat , sound , soundskins
The $30 / 90 minute sound deadening project... xxaarraa 4th Gen T4Rs 1 02-14-2022 05:00 PM
Shhhhh Quiet Please (3rd Gen Sound Deadening Project) alphyn 3rd gen T4Rs 99 04-23-2016 10:53 AM
Sound Deadening Project (picture heavy) Skidmarcx 3rd gen T4Rs 28 03-09-2016 05:05 PM
4th gen sound deadening drapaki 4th Gen T4Rs 5 01-02-2011 06:30 PM
Sound Deadening Help!! Tego Engines / Suspension / Wheels / Tires / Audio / Accessories 3 07-23-2009 05:44 PM
