So the Limited trim comes with projector housings but not HID/LED bulbs. Swapping to LED seemed an obvious choice, and I hope this post helps others who are considering doing the same. I used DDM Tuning for parts as I've good experiences with them in the past.
I used their 40W LED kit plus the decoders. I'm not sure the decoders were necessary, but they weren't expensive and the last thing I wanted was a CEL down the road.
The bulbs require a little ballast thing attached to the bulb wire. Not a big deal but another complication. The decoders are another box in the linkage.
Comparison of the OEM bulb vs DDM Tuning LED:
Before:
To do this, I had to drill a hole in the dust cover for the headlight bulbs. There isn't enough room the housing to hold the various pieces, and this was exactly what I did with a Subaru once upon a time. For the passenger side, I decided to zip-tie the ballast(?) and decoder to the top of the dust cover for the air pump thing (at least I think that's what it is).
Before mounting, I put a little strip of closed-cell foam on the back of the ballast and decoder just to reduce any vibrations:
Tied down:
On the driver's side, I had to zip-tie the ballast and decoder to the stock wiring harness as there was no good place to put this...
After, you can see a big color difference. Never mind the relative brightness as this was shot in a well-lit garage. I promise it's quite an improvement.
