05-31-2018, 09:54 AM
#31
Originally Posted by MossJenks
People do it off road all the time. There are several possible techniques. Isn't "in a pinch" exactly what we're discussing here?
Indeed, what we're discussing is CURRENT and typical solutions. What I'm asking about is a different solution.
The whole replace the tire solution requires having the space (and weight) capacity to haul around the replacement tire (or scavenge to find a suitable replacement).
What I'm asking about is a solution that would simply allow you to foam fill a heavily damaged tire which could allow you to limp along for an extended amount of time until you find a different tire to swap.
05-31-2018, 10:04 AM
#32
Real Name: KE0OIC
Real Name: KE0OIC
Originally Posted by MidnightOffRoad
Rather than lug around replacement tires or spend time looking for a set to steal or salvage, wouldn't it be a great solution if you could have a compressed/canned inflation medium in your rig that you could simply fill up the damaged tire to keep you going (for an extended period of time) till you could figure things out?
Better yet, how about a magic wand that you can just wave and fix everything? That would be awesome!
Seriously though, no such product exists. How would you keep the foam from just spurting out of a sidewall tear? There are some foam fill products out there for industrial applications, but you fill the tire BEFORE there is damage and you give it time to cure. But these are only for industrial applications. Nobody runs this on highway vehicles because it creates balance issues and a much harsher ride.
If such a product existed it would be a top-selling accessory for Colorado off-roaders. Believe it or not you're not the first person to figure out that flats in the middle of nowhere are a PITA.
If we're wandering off topic here it's because the answer to your original question is simply "no".
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
05-31-2018, 10:45 AM
#33
Banned
Banned
a high volume compressor can absolutely seat a tire, or you can get an air tank for even higher volume. i'm not sure i understand your concern, this is something people do regularly, you just need to practice.
you can patch a sidewall puncture, it's just not something you want to do for highway speeds but in an emergency situation it will still work. the example i gave above about stitching the hole closed with wire was on a sidewall.
any puncture or damage that can be filled with any of the slime products can be fixed with a plug or patch kit
you could also get split rims and tube tires and carry plenty of tubes, but modern tubeless tire is going to be more rugged and reliable
there is no magic foam that can fill a damaged tire in the field. and if you don't have the space/weight to carry a rimless spare you also don't have the space/weight to carry a giant tub of sealant and the pump adapter for it
05-31-2018, 11:40 AM
#34
Real Name: Chris
Real Name: Chris
My South Florida, Irma evacuation vehicle. I carry an ARB patch kit and the basic tools a recovery gear necessary to fix a tire. As others have stated I don’t know of any fill or foam that would work. The biggest issue that I and everyone else ran into is fuel. I was able to get out of state, but it was tricky. On the way back I bought extra gas cans. Because it’s 400 miles to get out of state I figure with 20 gallons of extra fuel I can at least get out of state and then some. The Gas buddy app is also super helpful. I know this isn’t really answering your questions but it’s the best I got.
I’ve also been looking into travel trailers, mainly for camping and moving my RTT to, but I think it would also be the best option/addition for this scenario as well (The hitch carrier did its job, but not the best/ideal solution).
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
05-31-2018, 12:38 PM
#35
Consider a sidewall puncture, which virtually NO patch or plug kit is going to remedy and you're either far away from help or any typical tire store/help is shuttered and you still need to keep going.
I used to assume the same thing but have been proven wrong. I don't mind knowing that I have a chance of repairing a sidewall to get me out of a jam.
inside
outside
Jim _ My Adventure Blog: http://suntothenorth.blogspot.com
2018 TRD Off Road Premium
ARB on-board compressor - RadFlo coilovers & rear suspension - Engel freezer-fridge - All Pro LCAs - African Outback roof rack, RCI skid plates
05-31-2018, 12:42 PM
#36
. So if one were say, hundreds of miles from help/civilization/tire replacement and had already run out of viable patching solutions....
Have you ever heard of inner tubes??
They can be used in tubeless tires.
Break the bead, remove old valve stem, insert tube, thread valve stem
Sidewalls can be stapled or sewn..not easy but have seen it done
https://youtu.be/_bctAjk0MCI
1994 4Runner AKA: Project Recycle
@503dropzone on IG
05-31-2018, 12:51 PM
#37
OP - I would keep an eye out for these products when they grow beyond ATV sized tires
(502) 243-1601, www.tireballs.com
05-31-2018, 01:48 PM
#38
Real Name: Steve
Real Name: Steve
Originally Posted by Louise
The best tires for a bug out scenario are a good pair of boots. Would recommend cardio + weight training exercises daily, 6 days a week.
Originally Posted by e60ral
My favorite thing about the pepper industry is the amount of 300+ lb people spending real money on prepper supplies when getting in shape would be a much better investment
Sent from my SM-G930V using Tapatalk
Walking expends too much "personal" energy and I need my 4runner to haul my survival twinkies!
_________________________________________
'14 Mag Gray 4Runner TEP
No More: '11 T4R SR5 - '98 Lexus GS400 - '98 T4R Limited - '87 T4R
05-31-2018, 03:08 PM
#39
How bout a good poncho...I hear they accomplish most things in a survival/zombie apoc... may have a tire application too
2014 SR5P 4x4 - TRD OR Rims/ BFG 265 KO2s/ 3/4 Prinsu Design Rack/ Lamin-X Fog Covers/ Bilstein 5100s x 4 (.85)/ Gobi Ladder/ Driver Seat lumbar mod
05-31-2018, 05:08 PM
#40
2013 SR5 - 255/85r17 Cooper S/T Maxx| Level 8 Tracker wheels 17x8.5 | 4 x Bilstein 5100, fronts @2.5" | SAW rear coils 1.5" | Camburg uniball UCAs | Demello sliders | Camelback full-length roof rack | Gobi ladder | RCI alum skids front+fuel | Indel-B Fridge constant-on
06-01-2018, 12:35 AM
#41
I stayed for Hurricane Andrew...probably one of my dumbest decisions as i got real lucky through that one.
-2016 7%'er---RCI aluminum skids; C4Fab sliders; Rago Fab modular storage panels; Complete 3M ceramic tint; The Ultimate Camping Mod; Xenondepot HID kit; BFG KO2's
-1967 Stephens M416 military trailer---slow build
06-01-2018, 12:48 PM
#42
Originally Posted by gloveflip
can't believe how many views he got for his mock-u-mentary
03-01-2021, 05:56 PM
#43
Hence my question about a "kit" and not using solid tires.
You guys keep meandering off. I never said hurricane evac was my only goal.
I'm simply asking a question (which the basic response is, no kit or method exists that anyone knows of) if someone has explored a kit that could convert the tires to solid core in a pinch. So if one were say, hundreds of miles from help/civilization/tire replacement and had already run out of viable patching solutions, would there be a compact/canned kit that could fill the tires (as a medium term solution which might require longer time till new replacement tires can be acquired).
I'm not advocating driving around on solid core tires. I'm asking if anyone's considered something more robust than tire patches or run flats, OTHER than simply dragging around a replacement set of tires.
Hi MidnightOffRoad, I found this thread browsing about Run Flat Tires and was wondering if this product might be something close to what you are looking for: Flats Over Run Flat Inserts - US VEHICLE SECURITY GROUP.
Some Off-roaders have said that it might be a good device to get in case they get a blowout outdoors. Do you guys agree?
03-02-2021, 11:28 AM
#44
Mods should delete this stupid thread. There are plenty of 'What tires should I buy?' threads to nauseate readers. We dont need a prepper flavored one.
Super White 2016 4Runner Trail Edition
03-02-2021, 02:35 PM
#45
E-rated KO2s are fairly indestructible. I've abused the heck out of them and the only issue in 4 years is having to plug one of them after a slow leak that turned out to be a large nail stuck in the tire. They are not great in wet conditions though. I carry a VIAIR pump made for RVs that works great. I'd suggest carrying a small backup inflator attachment, my main one has got clogged up with grit.
Really you're more likely to die in an every day car accident than SHTF event though.
99 SR5 v6 4WD
11 SR5 v6 4WD
