Thread Tools Rating: Thread Rating: 8 votes, 3.38 average. Display Modes
Old 06-01-2018, 12:10 PM #1
DreamsOfDirt's Avatar
DreamsOfDirt DreamsOfDirt is offline
DreamsOfDirt will become famous soon enough DreamsOfDirt will become famous soon enough
Roof Rack Sealant? Need Advice
I need input on whether sealant is necessary when re-attaching factory rails.
I pulled my rails off to have them powder coated. As I was about to put them back on I noticed the rubber/foam pads on the rails were worn/incomplete (see pics below). I'm wondering if I should:
  • leave it alone and assume whats there will do the job.
  • seal with some silicone (e.g. DAP marine grade mentioned elsewhere on the forum)
  • seal with an adhesive (e.g. E6000 mentioned elsewhere on the forum)
  • seal with a thin rubber seal (another thread mentioned that Gobi provides these with their rack).
  • some combination of the above
I'm hoping to put the rails back on this weekend but will be pulling them off in a few weeks when my Rago crossbars arrive. I mention this as I'm not sure if the short term/long term solution are the same.
Thanks in advance for the suggestions.
Roof Rack Sealant? Need Advice-img_2597-jpg  Roof Rack Sealant? Need Advice-img_2598-jpg
2018 TRDORP w/KDSS, Cooper AT/3s, Rago cross bars, TRDP Black wheels, front grille, black valances, Kenwood Excelon DNX996, working on the rest...
DreamsOfDirt is offline   Reply With QuoteReply With Quote
Old 06-01-2018, 12:21 PM #2
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
What’s your weather forecast like?
I ask cause I installed and uninstalled several racks in a short period of time and used silicone because it was over winter. If I did it again I’d use rubber until I had a permanent setup, then use silicone, especially if there was no rain in the future. The silicone pulled some paint off and I had to spend time cleaning the roof of it and touching the areas up, big pain in the rear.
67' Land Rover 109, 97' FZJ80, 16' 4Runner Limited
http://www.toyota-4runner.org/5th-ge...-jr-build.html
http://www.overlandcookery.com
http://www.schaubphoto.com
JSparky is offline   Reply With QuoteReply With Quote
Old 06-01-2018, 12:32 PM #3
Interesting to hear about the silicone.
Weather here will likely be 85-95, with some rain, I’m sure, but not likely days of rain. Your experience makes me lean rubber seal until I get the cross bars.
Old 06-01-2018, 12:37 PM #4
wsgoat's Avatar
wsgoat wsgoat is offline
wsgoat has a spectacular aura about wsgoat has a spectacular aura about
wsgoat's Avatar
I used this when I re-installed my roof rails after powder coat.
Roof Rack Sealant? Need Advice-hs10001-jpg
*2017 4R TRD Pro, 01H5 Cement w/ Shrockworks dimpled tread plate sliders, Moroso oil catch-can, black powder-coated roof rails. (summer runner).
*2005 4R Sport Edition w/ Bilstein 5100's, Gen-5 brake upgrade, K&N cold air intake, cabin air intake mod, Falken Wildpeak AT3. (winter runner).
*1965 Pontiac GTO convertible, 4-speed w/tri-power, PHS documented. (born in Freemont CA).
*1962 Chevrolet C-10 (short-step) pickup, 4-speed, survivor. (born in Oakland CA).
wsgoat is offline   Reply With QuoteReply With Quote
Old 06-01-2018, 02:57 PM #5
tb-av tb-av is offline
tb-av is on a distinguished road
That's good stuff.
tb-av is offline   Reply With QuoteReply With Quote
Old 06-01-2018, 03:07 PM #6
CollinJ's Avatar
CollinJ CollinJ is offline
CollinJ will become famous soon enough CollinJ will become famous soon enough
CollinJ's Avatar
I used black RTV 100% silicone when I reinstalled mine, no water issues at all. The rubber on the bottom would probably be fine but you can see where the factory had some form of sealant on there as well which is why I cleaned that and put some back.
I’ve never personally heard or seen silicone pulling off paint unless it was already chipped? Not saying I don’t believe the individual who said it happened to them just seems weird.
CollinJ is offline   Reply With QuoteReply With Quote
Old 06-01-2018, 04:54 PM #7
Swarty's Avatar
Swarty Swarty is offline
Real Name: Swartwood
Swarty is on a distinguished road
Swarty's Avatar
Definitely
Use RTV, silicone based or not doesn't really matter. I tried to leave it alone the first time and had to go back. It leaks through the threads so Gobi's seal is not sufficient since it doesn't seal the screw threads.
10 TE - KDSS - Icon Suspension - 285/70/17 Hankook MTs - 4.56 nitro Gears - URD equal length headers
Shrockworks front bumper and sliders - MT Rear bumper- RCI aluminum skids - Dif breather mod - K9 Rack - Warn 10S Winch
Come ride with me: PDX 4X4
Swarty is offline   Reply With QuoteReply With Quote
Old 06-01-2018, 08:09 PM #8
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Another vote for RTV. That's what I used when installing my ARB rack and no leaks in two years
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 06-01-2018, 10:00 PM #9
JSparky's Avatar
JSparky's Avatar
It was weird I agree, but it definitely happened. Occured when pulling up the metal spacer plates that are used on aftermarket racks. Unfortunately no photos. When I uninstall the factory rack again I can take some.
Old 06-01-2018, 11:13 PM #10
Depending on the silicone it can release acetic acid when it cures. Then you also may have dissimilar metals in contact. That's a good recipe for problems.
Permatex RTV
TYPICAL CURING PERFORMANCE
Permatex
Clear RTV Silicone Adhesive Sealant cures on
exposure to moisture in the air. The product cures tack free in
1 hour and fully cures in 24 hours. Cure times will vary with
temperature, humidity and gap. Note: The curing process can
cause corrosion to some surfaces
, for critical applications use
the Ultra Series silicones.
Old 06-02-2018, 12:10 AM #11
tristero's Avatar
tristero tristero is offline
Real Name: Justin
tristero will become famous soon enough tristero will become famous soon enough
tristero's Avatar
Real Name: Justin
I'd use the sikasil vs RTV or other silicone
2010 4Runner SR5 Magnetic Gray: Radflo / Icon + Metaltech / Total Chaos / Dirt King / SCS Stealth 6 / BAMF Sliders + Pelfreybilt Bumper / PRINSU / Indel B / 2014+ IS 350 Retrofit
2012 GX460 Premium Black Onyx: Stock af
tristero is offline   Reply With QuoteReply With Quote
Old 06-02-2018, 01:26 AM #12
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
I used Marine Goop about 7 years ago and it has not leaked yet.
1000MPH is offline   Reply With QuoteReply With Quote
Old 06-02-2018, 08:51 AM #13
Fishingkid Fishingkid is offline
Fishingkid is on a distinguished road
Any pictures of the installed powder coated racks?
Fishingkid is offline   Reply With QuoteReply With Quote
Old 06-02-2018, 10:34 AM #14
wsgoat's Avatar
wsgoat's Avatar
Lot of glare in the pic....cost 50-bucks to have both rails powder coated. I went with a semi gloss to match the factory trim.
Roof Rack Sealant? Need Advice-roof-rack-002-jpg
Old 06-02-2018, 10:42 AM #15
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
When I removed mine for painting, I used ARP liquid thread sealer on the bolts, nothing more, no leaks and we've had some intense storms here since. I think this is one of those things people tend to over think.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
adhesive , roof rack , roof rails , seal , sealant
Roof Rack advice shoota 3rd gen T4Rs 28 10-24-2016 05:26 PM
Roof Rack Advice tbm General Discussions 29 06-24-2016 04:44 PM
Watertight roof sealant. Jwhite General Discussions 6 04-02-2014 11:50 PM
roof rack sealant / washers ?? ultimatt 3rd gen T4Rs 5 04-02-2011 08:56 PM
Advice on roof rack for surfboards, gear on 2Gen with no OEM rack? joelbra Engines / Suspension / Wheels / Tires / Audio / Accessories 1 10-27-2008 06:25 PM
