I wouldn’t do it that way. I did what catrains said and add back what you took out with the check plug in place.
When starting with a cold vehicle:
Loosen the fill plug located on the passenger side.
Loosen the check valve just to make sure you’ve got the correct tool and it will open. Get your container(s) ready.
You will need a 5 qt container.
Loosen the drain valve and drain.
If you don’t have a 5qt then you can do what I did.
I got two 2-1/2qt paint mixing buckets from Home Depot because they were out of 5 qt.
Open the check plug and you will get about 1.5 qts.
When that stops dripping, open the drain plug and get the rest, about 2 qts.
Replace the check plug and drain plug. Use the old gaskets. Flat side against the screw head.
Fill the transmission with the same amount you pulled out.
Now you’ve got a choice:
- Call it good
- Do the temp check and level adjustment
- Start truck, go through the gears as outlined in the trans fluid circulation procedure, and do the drain and fill procedure 1 or 2 more times.
Many recommend three to four drain and fills is pretty good.
I would definitely recommend setting the level correctly at the end.
Replace the gaskets with new ones on the last drain as well.
Recommended:
Get a Motive power fill.
...or make you own from a Home Depot garden sprayer.
I just made one of these and tested with water but not yet with oil. I’ll be using it for diffs.
Here’s a vid on how to make one.
How To : Make a Pressurized Fluid Dispenser - YouTube
This is a very thorough vid on changing the fluid.
How to Service a Sealed Toyota Transmission - YouTube
Transmission fluid drain and fill.
Torque specs:
Drain plug - 15 lb-ft (14mm)
Overflow plug - 15 lb-ft (5mm hex)
Fill plug - 27 lb-ft (24mm or 15/16")
Parts: (I pulled this info from someone else’s post. Sorry I can’t remember who’s.)
4 to 12 qts Toyota ATF WS fluid - Toyota part # 00289-ATFWS
Drain plug gasket - Toyota part # 35178-30010
Overflow plug gasket - Toyota part # 35178-30010
Fill plug gasket (rubber O-ring) - Toyota part # 90301-15004
Oh, the fluid in the pics has 111,000 miles on it. It’s dark but smells fine and is not gritty at all. Nothing much was left at the bottom when I dumped it.
