Originally Posted by Hammer0313
Anyone try a thermal gun measuring the transmission pan temperature from the outside? That young girl used it in that video and it was only a few degrees off; seems to be a little easier than a scan tool.
Yes, I used a thermal gun to measure pan temperature because I knew I would became immensely bored and lose focus while sitting in the vehicle waiting for a dash light to indicate proper temperature to check fluid level. I had seen Faye Hadley's video, so I used a thermal gun to wait until the pan temperature was 4-5 degrees below the minimum temperature range, and then began watching the dash light. When the min temperature was indicated, I measured the pan temperature again and was satisfied with her finding. Next time, I'll just use the thermal gun. I'll check the level when the gun reads 2-3 degrees less than the min temperature for checking fluid level when the ambient temperature range is 68-80 F. I would not solely rely on a thermal gun if the vehicle has cold soaked in sub-freezing temperatures or hot-soaked above the upper temperature limit.
