Originally Posted by MyFirstRunner
What do people use to refill the trans fluid? I was going to add a Derale aux trans cooler and will need to top off the fluid afterwards. Only saw one video where some manual pump was used to get the fluid up there.
Anybody have recommendations for topping off Trans fluid levels?
How to make a fluid transfer pump
1 gallon pump sprayer ($10 Home Depot)
10 ft 1/4”id x 3/8”od clear vinyl tubing ($3.25 Home Depot)
1/4”x1/4” or 3/8”x3/8” mini ball valve with barb ends. ($12 for two on Amazon)
Optional: hose clamps or zip ties for added security at high pressure.
Remove original tubing from sprayer and replace with the clear tubing.
Cut tubing to desired length. I made mine long enough reach without the need to drag it under the truck.
Add the ball valve to the end.
Cut additional length of tubing to reach from ball valve into fill hole securely.
Done.
If you want to establish a baseline level in your pump, fill it with a qt of your desired fluid and pump it back into the original container to see how much stays in the pump. It’s usually only a few ounces.
Pics on this thread.
Front and Rear Diff fluid change
