Thread Tools Rating: Thread Rating: 3 votes, 3.33 average. Display Modes
Old 04-10-2021, 08:11 AM #46
d4vid d4vid is offline
d4vid is on a distinguished road
Video of my transmission cooler flush
After plenty of good advice from this thread and others, I did a pan-drop and cooler line home flush, and posted a video of my experience:
https://www.youtube.com/watch?v=AKmMrPAr3iM&feature=youtu.be
d4vid is offline   Reply With QuoteReply With Quote
Old 04-10-2021, 09:31 AM #47
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
Great video!
Dude you've got a series of 4runenr videos. The front differential looks gross! How many miles on your vehicle and do you use 4wd often?
1jzgte is offline   Reply With QuoteReply With Quote
Old 04-10-2021, 01:21 PM #48
Originally Posted by 1jzgte View Post
Great video!
Thanks! About 67,000 miles now, I bought the car at 20,000 miles, changed the front diff fluid at about 40k, I use 4x4 embarrassingly infrequently!
Old 06-21-2021, 08:38 AM #49
MyFirstRunner's Avatar
MyFirstRunner MyFirstRunner is offline
MyFirstRunner is on a distinguished road
What do people use to refill the trans fluid? I was going to add a Derale aux trans cooler and will need to top off the fluid afterwards. Only saw one video where some manual pump was used to get the fluid up there.
Anybody have recommendations for topping off Trans fluid levels?
MyFirstRunner is offline   Reply With QuoteReply With Quote
Old 06-21-2021, 09:29 AM #50
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
When I did mine I used a cheep manual hand pump from the parts store, easy breezy. I dont remember the brand but it was under $10 bucks.
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 06-21-2021, 09:42 AM #51
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Just so you know the engine oil and transmission fluid on these 4Runners run on the cooler side. At least running empty, I haven’t towed with mine yet so not sure how it handles heat while towing.
The pic below is me running empty from Florida to Georgia, about 7 house on the interstate at 70-80 MPH. Not sure if a transmission cooler is needed unless towing or trying to muscle over some mountain pass out west on the heavier side of GVWR.
Transmission Fluid Change procedure-87375b7d-1bdb-44e1-90b8-f0cfd6fe14da-jpg
Old 06-21-2021, 09:52 AM #52
Yes, it's for towing my pop-up camper that is running about 3400 lbs loaded. It may not be necessary, I know. We've mostly stayed pretty close to home (within 100 miles or so) but will be doing our first long trip which will be about 1000 miles round trip from Cincinnati to Sleeping Bear Dunes in Michigan at the end of July. I sold my old Scan Gauge II with my 3rd Gen (dumb, dumb, dumb) when I upgraded to a 5th Gen. The way I see it I could get a new Scan Gauge for $150+ or add an aux trans cooler for a third the cost.
Will 1 quart be enough to top it off after adding the Derale 13504?
Old 06-21-2021, 10:02 AM #53
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
I think the trans cooler is a great idea for towing, especially on those longer trips. Not sure about the amount of fluid after install, I usually buy extra fluid just to be sure I'm covered.
Old 06-22-2021, 01:18 AM #54
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
How to make a fluid transfer pump
1 gallon pump sprayer ($10 Home Depot)
10 ft 1/4”id x 3/8”od clear vinyl tubing ($3.25 Home Depot)
1/4”x1/4” or 3/8”x3/8” mini ball valve with barb ends. ($12 for two on Amazon)
Optional: hose clamps or zip ties for added security at high pressure.
Remove original tubing from sprayer and replace with the clear tubing.
Cut tubing to desired length. I made mine long enough reach without the need to drag it under the truck.
Add the ball valve to the end.
Cut additional length of tubing to reach from ball valve into fill hole securely.
Done.
If you want to establish a baseline level in your pump, fill it with a qt of your desired fluid and pump it back into the original container to see how much stays in the pump. It’s usually only a few ounces.
Pics on this thread.
Front and Rear Diff fluid change
1000MPH is offline   Reply With QuoteReply With Quote
Old 06-22-2021, 01:23 AM #55
what app and what dongle is all that?
Old 06-22-2021, 01:31 AM #56
1000MPH's Avatar
1000MPH's Avatar
I thought there was no oil temp sensor on the 4Runner.
Old 06-22-2021, 06:59 PM #57
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Here is a pic of the tool I use, simply plugs into the port under the dash. Leave it plugged in and it connects by Bluetooth. There are all kinds options from fluid temps, knock sensors, fuel monitoring, air, power and much more. Only option it doesn’t have is oil pressure which kind of sucks for me because that’s important to me. But the bright side is I get to monitor my fluids. I even got a thermal gun and made sure the temps were accurate. I tested the transmission pan and the oil pan and both were consistent with the scan tool readings, usually within one or 2°. Overall I like it, especially on my trips out west hitting the trails and days of interstate travel.
Transmission Fluid Change procedure-29347a39-93fb-4cd5-997b-99e382e3219a-jpg
Old 07-18-2021, 09:09 AM #58
How long did it take you guys to get your trans up to temp so you could pull the check valve? I added fluid in first thing this morning and it’s been idling now in check temp mode for about 30 minutes. I did the 4 to 13 ODB jump and got the D for two seconds so I’m confident it’s in the temp mode.
Old 07-18-2021, 09:27 AM #59
Ha ha, it literally switched to D as I was hitting send.
I added an auxiliary trans cooler in line with the radiator this weekend and here are a couple things that I found with mine. I had Toyota do a transmission flush when I first got the car a couple years ago. So when they did that they must’ve switched up lines because I had the blue line run into a pink back to a blue so make sure you don’t solely go on color. I felt which one was hotter than follow the other one out of the radiator back to the transmission.
Somebody else mentioned to use brake cleaner to clean out the check valve. When I first put in the 5 mm I could feel it starting to strip I sprayed it down and cleaned it out with a tiny flat head eye glass screwdriver then tapped the hex in with a hammer. No issues.
From coldstart it took about 32 minutes and check temp mode to get up to temperature to pull a check valve. Based on what I put in and what came out, I think I needed about half a quart maybe a little less of trans fluid. I used to Hayden 679 cooler.
Also I bought extra hose, and I ran one from the radiator to the trans cooler, and the other from the trans cooler to the transmission hard line. I bypassed the metal tubing that goes up and then back down, hopefully that makes sense.
Thank you to everyone for all the videos and posts and comments on this topic, took a little more time than I thought but it all made sense in the end.It’s been a total of 3 1/2 hours, with two runs to the auto parts store.
Old 07-18-2021, 11:29 AM #60
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
What app is this?
CutthroatSlam is offline   Reply With QuoteReply With Quote
Should I change transmission fluid or not? bgravy 3rd gen T4Rs 34 04-11-2020 02:12 PM
Transmission Fluid Change Flifisher 3rd gen T4Rs 77 12-27-2017 10:58 AM
Transmission fluid change @ 60K? alaskaman 4th Gen T4Rs 21 11-12-2011 09:43 AM
Transmission Fluid Change ?'s rjaudi 3rd gen T4Rs 6 06-16-2011 11:11 AM
Transmission fluid change on an 04? SR5XM Maintenance/Detailing 3 10-01-2008 06:53 PM
