02-19-2020, 07:58 PM
#106
Originally Posted by codeman870
Very nice! I know I have a different camera, but here is what I did for mounting the rear view dashcam. I basically bought a little piece of aluminum from Home Depot (or your other local box store) drilled a hole in it and cut it to length. I bought a screw and washer to fit into the headliner attachment point. I don’t see it at all when I’m back there.
It actually sticks out past the weather sealing to get the camera as close to the rear window without touching.
I just recently moved it off the center headliner attachment point and put it on the one closer to the passenger side so that it would be in the wiper path.
Viofa A129 Pro? If so, thats what I got. I did similar but mounted right next to the button with a screw through the hole where the snap is and a piece of aluminum. Worked great.
2019 4Runner Limited in Magnetic Gray Metallic, w/Redwood Interior, and 3rd row. Mods: Lastfit 7440/7443 Led Blinkers | JDM ASTAR LEDs throughout the interior and backup/license plate bulbs | OEM Tundra LED Fog Lights | Morimoto Elite HID 5500k 35w | Xenon Depot Led Pro 9005 w/LED Driver for DRL / XPLORE OFFROAD USA Flag rear windows | Adams Polishes UV Ceramic Paint coating
02-20-2020, 11:43 AM
#107
Originally Posted by BigCountryT4R
Viofa A129 Pro?
Yup, that's the one!
2017 TRD Off-Road, Baja Rack & Ladder, Shrockworks Rock Sliders, C4 Lo Pro Front Bumper, LED Interior Conversion, Toytec Boss Performance Lift, TRD CAI.
02-29-2020, 09:21 PM
#108
Real Name: Thomas Reiter
Rear mount
I made my rear mount out of 1/2” aluminum tubing. Works great.
02-29-2020, 10:08 PM
#109
Any reason why you decided to do this from the side instead of dead center for mount?
03-01-2020, 08:54 AM
#110
I mounted it off to the side to keep it out of the way. I wanted to get it close to the rear window and felt if I centered mounted it I would likely be bumping it in the future. The rear video is really nice. Now to figure out the "cloud" option.
Tom
03-01-2020, 01:15 PM
#111
Tom
The cloud this is pretty cool when it works. The issue I have now is that the camera starts and restarts constantly while in use. I called the vendor and they told me to send it in. They then send it back to Blackvue in KOREA!!!!! They told me the whole process can take 6 to 8 weeks. Had I know that, I would never have bought it.
2011 SR5 4x4, Toytec Ultimate w/ SPC UCA's, Shrockworks Front Bumper, 285/70/17 BFG KO2, NFAB Steps
03-01-2020, 09:57 PM
#112
I removed the plastic button that holds the headliner and tapped it so I could bolt a bracket to it that I made. I just so happened to have some spray paint that is a very close match. Keeps it fairly close to the window and up out of the way.
Sent from my SM-N976V using Tapatalk
03-01-2020, 10:10 PM
#113
This is a great setup. What size screw did you use?
Do you have a camera view example?
15 SR5 4WD
03-01-2020, 11:20 PM
#114
If I remember correctly I used a M6 screw.
The camera can see just about every edge of the back window and also has less line being up high.
03-02-2020, 11:17 PM
#115
TheDashCamStore ships out RMA item and include a return label where they'll send that defective camera back to Korea while you don't have to wait at all or worry about the camera that was being repaired
03-03-2020, 02:58 PM
#116
I got mine on Amazon and apparently the seller dosent do that.
03-03-2020, 03:17 PM
#117
Real Name: Chris
Real Name: Chris
That is a serious freaking mount!
03-05-2020, 08:06 PM
#118
*clenches fists* mother****ers...
03-06-2020, 07:40 PM
#119
Yep, im apprehensive to send it off. My luck i wont get it back.
03-07-2020, 07:03 PM
#120
How long ago did you place this order with the Amazon seller? Could always do a chargeback if you don't get it back in a timely manner
