Old 06-11-2018, 02:47 PM #31
boyguan boyguan is offline
boyguan is on a distinguished road
Originally Posted by Senorlechero View Post
Yes, anyone with AC test equipment can easily diagnose this. The 4runner should be able to freeze you out.
We can only run ours on full for a few minutes and then it's too cold.
I have been to the dealer for this issue before on other cars. The first step will be to confirm temp at the vent. How you feel is subjective. The air coming out of the vent should be like 20-30 degrees cooler.
Bring it into the dealer since you have warranty. Problem solved.
boyguan is offline   Reply With QuoteReply With Quote
Old 06-12-2018, 03:06 PM #32
Hans Moleman Hans Moleman is offline
Hans Moleman will become famous soon enough
With my temp setting on the lowest and the blower speed also on the lowest (1 tick) it is ice cold. I usually have to raise the temp because it's too cold.
2018 SR5 Premium MGM
Hans Moleman is offline   Reply With QuoteReply With Quote
Old 06-12-2018, 03:43 PM #33
e60ral e60ral is offline
Banned
e60ral is on a distinguished road
Banned
yeah, i may run it higher to initially cool the vehicle but after that i'm usually on the low setting with the temp at least a few clicks above cold
e60ral is offline   Reply With QuoteReply With Quote
Old 04-18-2019, 08:49 PM #34
BamaT BamaT is offline
BamaT is on a distinguished road
Did you end up getting it checked at the dealer? My Ď14 SR5ís A/C is weak. I can run it full blast and never get cold. My 3rd gen on the other hand blows ice cold air.
BamaT is offline   Reply With QuoteReply With Quote
Old 04-18-2019, 09:09 PM #35
bluecollarjock bluecollarjock is offline
bluecollarjock is on a distinguished road
MY GARAGE
MY GARAGE
Yup. They admitted itís not that cold and recharged it. Didnít change a darn thing. I could take a cold shower and drive around naked and it wouldnít chill me out. My warranty runs out in a few months. Want to take it back but what can I expect?!! I took it in twice and they sort of blow it off.
bluecollarjock is offline   Reply With QuoteReply With Quote
Old 04-18-2019, 11:50 PM #36
realquiet1387 realquiet1387 is offline
realquiet1387 is on a distinguished road
Keep taking it back, if the dealer has already documented warm blowing air within the warranty period and the problem persists it should be covered under the original 3 year/ 36k mile warranty after it has expired. But you need to keep having this documented and put your foot down (you paid good money for this 4Runner).
As a former Honda master technician I cant tell you how many customers have complained about warm A/C when its actually not. I would take them in their car, stick several thermometers in the dash vents and simulate normal driving conditions on a test drive. typically 30-40 degrees is great, always will get slightly warmer air under stopped conditions as RPMs are lower. Get the concrete evidence and ask for this to be shown to you if this Toyota dealer is trying to brush you off when you're truly having problems call Toyota of North America, But documentation is imperative. Worst case you take that documentation and find another Toyota dealership to take a look at it.
Hope this is helpful!
realquiet1387 is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 12:34 AM #37
Teamoatmealpie's Avatar
Teamoatmealpie Teamoatmealpie is offline
Teamoatmealpie is on a distinguished road
Agreed get it documented before warranty runs out. That saved my ass on the front diff bearing as I reported it before warranty ran out. I also suggest you call or email Toyota corp, they will assign you an incident #. That will help too if the warranty runs out before it gets fixed.
Had same AC prob with a Ford when I lived in PHX - not good.
Get a meat thermometer and put it in the vent. See what kind of temps its putting out. Compare it to another vehicle, another 4Runner if you can. Or maybe another inmate here can do the same and post results.
2003-SR5 V8 TRD Supercharger - 2016 SR5RR- 1998 454 Chevy Express 15 Passenger Van 4x4 Conversion
Teamoatmealpie is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 02:06 AM #38
MY GARAGE
MY GARAGE
Thanks guys. Will do!! Iíve read other peopleís complaints and thought I had to settle. A friends Ď15 SR5 will make you Freeze and my girlfriends Honda Civic will freeze everyone in the car too. I shouldnít say mine is blowing warm, itís not warm air actually but itís not cold. Itís cool af best. Even with 70 degrees it wonít get cold enough that youíd want to turn it down. It sucks !
Old 04-19-2019, 08:48 AM #39
SolidPooP's Avatar
SolidPooP SolidPooP is offline
SolidPooP is on a distinguished road
SolidPooP's Avatar
Iím pretty sure youíve checked already, but just in case... I was having the same issue in my 16 since new. Ended up changing the cabin air filter during my last oil change and noticed a HUGE difference. Used a cheapo fram cabin filter from Wally World. Stock filter didnít seem too dirty either.
SolidPooP is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 08:54 AM #40
mteolus's Avatar
mteolus mteolus is offline
mteolus has a spectacular aura about mteolus has a spectacular aura about
mteolus's Avatar
Just because the tint has the name 3M doesn't mean it's good. I am sure they probably fixed it by now, but in the past 3M tint turned purple over time. Find a good reputable tint shop and they should know what the best tint is.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plate aluminum (all except tank), SCS Ray 10 Wheels Matte Gray, 285/70R17 BFG KO2 C load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers.
Old 04-20-2019, 05:29 PM #41
tacoyota tacoyota is offline
tacoyota is on a distinguished road
I noticed that the 4runner has pretty weak blowing A/C and it is not ice cold. It is cold but not freezing. My old lexus sc430 would freeze your fingers in a minute on low haha. I attributed it to maybe a bigger condenser in a v8 or something. like others have said; fork out the cash for ceramic tint all around and life will be good again.
2017 TRD Offroad Premium Super White | 275 KO2 on Stock Rims | Stock Stereo with JBL GX302/GTO638/938, Kenwood KSC-SW11 | DDM 35W HID Ultra | Shrockworks Step Sliders | FR 5100s @1.75 RR Daystar 1.5
tacoyota is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 08:43 PM #42
Sonoran_Desert Sonoran_Desert is offline
Sonoran_Desert is on a distinguished road
Try This
I had an 2017 SR5 with the same issue. I lived with it through the 2018 Tucson summer. I had Cool A/C but not cold A/C. I finally fixed the problem last month by doing this:
1. While driving (on a deserted road ideally) turn Temp to Max Cold (hard left on the Temp dial)
2. Turn Fan to Max High (hard right on the Fan dial)
3. After a few seconds, dial the Air Flow position dial to the setting two clicks left of Defrost which is a person icon with down arrow to legs and a defrost icon and wait a few seconds.
4. Now rather aggressively dial air flow position to the left, selecting the Air Flow position with a person icon and an arrow down to legs and arrow right to face (A few clicks off hard left)
You will hear a vent shut. It was that open vent, likely leading to the engine compartment or outside, which was competing the A/C cold air flow into the cabin, at least for my situation.
After dong 1-4 above once, I no longer have to go through those steps. Possibly factory settings somehow stick the vent open until a one-time force shut using this "procedure".
Sonoran_Desert is offline   Reply With QuoteReply With Quote
Old 04-21-2019, 02:50 AM #43
borfoo3 borfoo3 is offline
borfoo3 is on a distinguished road
You only know a good A/C system if you live somewhere warm enough to find out.
My A/C works 'on spec', yet I found the 4Runner A/C as one of the weakest I've owned. Rear passengers in summers will not get cool air
I added ceramic tints, an auxiliary fan up front that runs with with compressor, keep filters clean...etc. It helped a bit, and I got used to being a bit warmer than I like. That is the sad truth.
2015 T4R TEP-KDSS | KING 650lb extended travel shocks w/adj | JBA STD High Caster UCA | Wheeler's SuperBumps | ICON 3" Overland Rear coils + Hydraulic bumpstops | TRD CAI | URD Y-Pipe | URD MAF Calibrator | Gibson side exhaust | Suntek Themal Tint | Spidertrax 1.25" Wheel Spacers | TRD Skid Plate (modded) | SSO Rear bumper | RhinoRack 76" Pioneer platform and backbone | WirthCo Dual Battery Setup | Rigid D2 Lights + Rago Fab hood brackets | Baja Design S2 Sport flood lights | ICOM-ID 5100E VHF/UHF digital transceiver | Diamond SG7500 Super Gainer Dualband Antenna
Borfoo3's 5th Gen 6112/ 5160 Build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 04-21-2019, 04:30 AM #44
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut will become famous soon enough
Who know? - maybe some of the 4Rs have this problem:
Lack of A/C Performance at Idle in High Ambient Temperature T-SB-0034-18 | Tacoma World
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 04-22-2019, 01:40 PM #45
MY GARAGE
MY GARAGE
Documented it with Toyota USA. They have in their notes the dealer had my A/C at 44 last time I complained and thatís within specs. Didnít say it was recharged or not. Whether the service guy was trying to be nice or what, he said they recharged it and admitted to me that whatever they got it at it wasnít that cold.
will try that procedure of cranking it on max and full power and going from the positions you indicated.
Toyota said some case manager will call me tomorrow. I said Iím not trying to stir issues just would be great if it could be fixed before warranty runs out. My next service (30k) is in a few weeks. I think they do change the cabin filter at 30k. So maybe that will help too. And if not seems if itís in spec Iíll have to learn to live with it like others and consider tint. For sure back seat passengers donít get cooled off and you can crank it all day and the front seat passengers wonít need to turn it down. Iím in LA and can get hot , and occasionally when Iím driving on road trips through more desert type areas to the east it really doesnít seem sufficient.
Gibson catback exhaust deal! Ends 12/18 at 5pm eastern. Last deal of the year. Jason B 4th Gen T4Rs 32 03-19-2016 12:40 PM
Gibson catback exhaust deal! Ends 12/18 at 8pm eastern. Last deal of the year. Jason B 5th gen T4Rs 8 12-23-2015 09:10 PM
catback exhaust deal! Ends 12/18 at 8pm eastern. Last deal of the year. Jason B 3rd gen T4Rs 12 12-18-2015 09:26 PM
Weak A/C? MidwestJ 5th gen T4Rs 29 09-10-2013 05:34 PM
Weak 90. red90 Classic T4Rs 6 09-13-2010 09:27 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
