Old 06-08-2018, 12:34 PM #1
bluecollarjock bluecollarjock is offline
bluecollarjock is on a distinguished road
MY GARAGE
MY GARAGE
Ď16 weak A/C ... just deal with it?
Iíve browsed the threads on 5th gens with weak air conditioning. Seems like mpg reports with different owners having huge variances. Some get frozen out of their 4runner and others complain (like me) that even on the coldest temp setting, highest blower setting, and rear plus passenger vents closed - it wonít freeze me out even at highway speeds in only 75 degrees LA weather. Obviously worse when itís hotter driving in the valley or desert. My 3rd gen blew way colder and so has every Jeep and Chevy 4x4 Iíve owned.
Sometimes I wonder if there is some issue I should get corrected before he warranty runs out, but enough people comment in threads about same issue that itís likely normal ? To just have ďcoolĒ A/C Not cold at all...and the suggestions to Tint windows to help keep the interior cooler?
Love my 4runner but the terrible gas mileage and weak A/C are drawbacks. Still no regrets in buying it :-)
bluecollarjock is offline   Reply With QuoteReply With Quote
Old 06-08-2018, 12:46 PM #2
boyguan boyguan is offline
boyguan is on a distinguished road
run a test. Cause you think or feel isnt that valid. Take a thermometer and stick it in the vent. Should be about 32-37 degrees. I assume that the recirculate is on as well?
boyguan is offline   Reply With QuoteReply With Quote
Old 06-08-2018, 12:49 PM #3
MY GARAGE
MY GARAGE
Thanks Iíll try to do that. And yes recirculate is always on.
Old 06-08-2018, 01:08 PM #4
RUNTHAT's Avatar
RUNTHAT RUNTHAT is offline
RUNTHAT is on a distinguished road
RUNTHAT's Avatar
I'm with @boyguan on this one in regard to testing. Seems like a problem. The triple digit heat days are already upon us in Arizona and I regularly need to dial down the blower setting.
'12 Trail w/KDSS
RUNTHAT is offline   Reply With QuoteReply With Quote
Old 06-08-2018, 01:23 PM #5
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail will become famous soon enough BobsTrail will become famous soon enough
BobsTrail's Avatar
Real Name: BobH
IMO -- Our systems are working as designed. Cold enough discharge but not enough volume/capacity.
I helped mine by adding Solar Guard tint (clear) to the front windshield and the moonroof. It helps a lot by reducing the incoming heat and the dashboard does not get hot and radiate heat into the cabin. I can leave the moon roof uncovered without the sliding cover even in Arizona.
Expensive and illegal, but it works great.
I also had light tint on the front side windows to block the UV but I wish had used the Solar Guard or the 3M product there too.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 06-08-2018, 01:28 PM #6
MY GARAGE
MY GARAGE
Made me laugh ďexpensive and illegalĒ. If I get really fed up Iíll call the guy whose shop I trust that does tint and ask what the side front windows and windshield would cost. I also would need to ask about the laws as I donít want to be pulled over.
Not familiar with Solar Guard or 3M product.
Old 06-08-2018, 01:46 PM #7
BobsTrail's Avatar
Real Name: BobH
BobsTrail's Avatar
Real Name: BobH
I used a 90% tint, so it does not look tinted, probably won't get the attention of anyone. It still blocks the UV and heat even with the very light tint.
They are called ceramic tints, here is info from the 3M site:
The Ceramic Series delivers outstanding heat reduction.
Advanced ceramics in the film reject up to 59% of total solar energy and up to 80% of infrared rays - all while retaining great visibility.
Non-metallized window film lets you stay connected with mobile devices, GPS or satellite radio reception without interference.
Old 06-08-2018, 01:50 PM #8
MY GARAGE
MY GARAGE
Thanks ! Havenít looked into any of this so clueless, and seems your also inferring regular tint can interfere with GPS and other gadget signals. Good to be aware of.
Old 06-08-2018, 02:25 PM #9
DesertCanyons's Avatar
DesertCanyons DesertCanyons is offline
Real Name: Dave
DesertCanyons is on a distinguished road
Real Name: Dave
AC settings
If the vent settings knob is not clicked solidly onto one of the interior locations the air will not run cool. I found this out by accidentally setting it in between the 5 or 6 locations. Make sure the dial is set fully into one of the positions.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
DesertCanyons is offline   Reply With QuoteReply With Quote
Old 06-08-2018, 02:27 PM #10
borfoo3 borfoo3 is offline
borfoo3 is on a distinguished road
If I remember correctly from my Cali days, 70% was the max legal limit on tints. You want the good ceramic heat reflecting ones, not cheapo color films
Park under shaded areas. Use windshield sun shades. Black interior soaks up heat on our T4rs so that's a big part of the A/C not keeping up issue
Check AC refrigerant before summer and for refills or leaks. Clean air cabin filters to not lose precious airflow. Change annually. That's practically all you can do with them for now
I added a front pusher electric fan (from a Prado) with relay to run when the A/C kicks on. It only helps when truck is stationary, but final coldness and airflow power are fixed based on our compressor/ fan setup. Have to live with it..
2015 T4R TEP-KDSS | KING 650lb extended travel shocks w/adj | JBA STD High Caster UCA | Wheeler's SuperBumps | ICON 3" Overland Rear coils + Hydraulic bumpstops | TRD CAI | URD Y-Pipe | URD MAF Calibrator | Gibson side exhaust | Suntek Themal Tint | Spidertrax 1.25" Wheel Spacers | TRD Skid Plate (modded) | SSO Rear bumper | RhinoRack 76" Pioneer platform and backbone | WirthCo Dual Battery Setup | Rigid D2 Lights + Rago Fab hood brackets | Baja Design S2 Sport flood lights | ICOM-ID 5100E VHF/UHF digital transceiver | Diamond SG7500 Super Gainer Dualband Antenna
Borfoo3's 5th Gen 6112/ 5160 Build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 06-08-2018, 02:31 PM #11
ayeyothisiskyle's Avatar
ayeyothisiskyle ayeyothisiskyle is offline
ayeyothisiskyle will become famous soon enough ayeyothisiskyle will become famous soon enough
In CA it is illegal to add anything to the windshield or front passenger and driver window. Put whatever you want on the rears.
Shops will still tint windshields and front windows, they just have to tell you its "illegal" before they do it.
There are shops that have a "ticket warranty" where in the event of a ticket, they will remove tint, you go to the station and show them you dont have tint anymore, pay your fix-it and the shop re-tints your windows. I'm considering this, as I have gotten front window tint tickets on my previous vehicles.
2016 Trail + KDSS | Kings 2.5 w. Adj + Ext Travel Front & Rear - JBA High Caster UCA - Icon 3" "Overland" Springs - Proline 4x4 Rear Elite Dual Swingout Bumper - Demello Offroad X-Wing Sliders - SCS Ray 10 - Falken Wildpeak MT01 285/70/17 - Dirty Pants
ayeyothisiskyle is offline   Reply With QuoteReply With Quote
Old 06-08-2018, 02:32 PM #12
I find the AC so cold on all my toyota that i can never run at full blast and even have to turn it up a tad.
Old 06-08-2018, 03:02 PM #13
MY GARAGE
MY GARAGE
Thanks Iíll play with that, good to know
Old 06-08-2018, 03:12 PM #14
MY GARAGE
MY GARAGE
Good to know, thanks. I may ask the one shop Iíve used in past for tint and stereo stuff on my other trucks/Jeeps. I looked at their website and they use some local small company Film not 3M. I sort of like the initial idea of 3M from the suggestion here.
Ugh I bought a TRDP instead of a Trail which I may have preferred cloth and a sunroof, but I ALWAYS modify my 4x4s. And once I start it becomes an addiction. So I felt like if I got a TRDP Iíd not do a lift immediately and be happy with the minor leveling up front. But here I am now wanting Colder A/C, and just from this mornings comments telling myself ďmaybe Iíll get Tint and while Iím at it find a shop that can also do a light bar behind the grill or replace the weak fog lights with something more potent ď hahha.
Iíll need to round up a thermometer to test it and also check all the dials etc to make sure everything is ok. I just know comparing it feeling wise even to my girlfriends Honda Civic, my dads Chevy Colorado and a Tahoe I just rented for a bear hunting trip, itís no where close to those vehicles. You crank up most cars fill blast and you gotta dial it down after a while. Iíve never been ďcoldĒ in my 4runner even with it on ďmaxĒ cold on the right dial and the left blower cranked, the rear and passenger vents closed. The few times Iíve had people in Back it seems to really drain any mojo for up front.
Old 06-08-2018, 08:20 PM #15
Jdholder Jdholder is offline
Jdholder is on a distinguished road
I have a 2014 SR5 and Iím in the same boat. Itís the first AC Iíve had that literally is too cold.
Jon - 2014 SR5 - Toytec BOSS - Camburg UCAís - Cooper 285/75/17 - BMC - ADVFiberglass Fenders - Plastics Guy Bumps - EIMkeith PCK - TRD CAI - RCI Skids - Spidertrax - MagnaFlow Cat Back - Blendmount - Valentine One - ProClip - Kicker Subaru Tweeters - Braided Lines - Brakes Still Suck
Jdholder is offline   Reply With QuoteReply With Quote
Gibson catback exhaust deal! Ends 12/18 at 5pm eastern. Last deal of the year. Jason B 4th Gen T4Rs 32 03-19-2016 12:40 PM
Gibson catback exhaust deal! Ends 12/18 at 8pm eastern. Last deal of the year. Jason B 5th gen T4Rs 8 12-23-2015 09:10 PM
catback exhaust deal! Ends 12/18 at 8pm eastern. Last deal of the year. Jason B 3rd gen T4Rs 12 12-18-2015 09:26 PM
Weak A/C? MidwestJ 5th gen T4Rs 29 09-10-2013 05:34 PM
Weak 90. red90 Classic T4Rs 6 09-13-2010 09:27 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
