06-15-2018, 06:10 PM
DIY guide 5th Gen Transmission fluid change?
anyone have the link of DIY guide for tranny oil change?
06-15-2018, 06:17 PM
Real Name: Morgan
Real Name: Morgan
2010 SR5 Blizz Pearl- Borla cat back, Firestone ride rite, Huskyliners, Afe Cai, Urd MAF, Gobi stealth with ladder, 5100s, icon 2" rear, toytec 1.6" front, TC UCA, HAF custom sliders, hand hold light mod, Led interior, stock rims and BFG KO2 265/70 C, Arb CKMA12- slider tanks w/ couplers, BD S8 10", opt7 40", BD dome light led in rear hatch
06-15-2018, 06:52 PM
Thanks, i saw that earlier.
Just want to make sure my 5th gen fill and drain bolt are the same location as in the picture ?
Many oil quart do i need for just drain and fill ?
06-15-2018, 08:14 PM
See link in my sig.
2016 Trail Edition Premium w/ KDSS. LT265/70R17 BFG KO2s, Ceramic Pro, TSO pro grille, sliding cargo tray, WeatherTech floor liners, '10-'13 trail running boards.
Nobody cares about your vehicle as much you do. DIY Maintenance Quick Reference
06-19-2020, 02:47 AM
sorry, late to the party!
I'm going to use this:
ATF Exchange (using the cooling line)
I know, I know, it's from the 4th gen forums, BUT it's the same transmission.
The only thing I can tell that's different is how the cooler tubes are arranged.
Hope this helps!
2016 SR5, electronic dial actuated, part-time 4WD
2016-2019 service manual: https://www.toyota-4runner.org/5th-g...l-rm27f0u.html
08-08-2020, 12:31 PM
Hey guys long time lurker here. Im wanting to change my tranny fluid but am a bit unclear about some of the generalities.
I have seen to two different styles of changing. The pan drop with a filter change (3q) and the complete 12q change with no filtet change.
I bought enough material to change out all the fluids. I also bought stuff to drop the pan and change the filter.
The 4runner is a 2016 and Im at 71k miles and had a complete flush by a shop at maybe 40k miles.
Im not even able to find at what intervals I should change the fluid.
Thanks
Sent from my SM-N975U1 using Tapatalk
08-08-2020, 06:43 PM
No official interval for regular maintenance. You’re definitely on a shorter schedule than I am, I changed mine a couple weeks ago at 111,000.
I posted at the end of this thread here.
Transmission Fluid Change procedure
I did the three drain and fills method, I really see no need to drop the pan, replace the screen, clean the magnets unless you’ve been towing or are otherwise hard on your truck.
Maybe I would think differently if I had a lift.
I recommend this video as it was the easiest to follow and she’s fairly detail oriented.
How to Service a Sealed Toyota Transmission - YouTube
08-09-2020, 12:03 AM
Appreciate the input. I just went by what the mechanic said, I didnt know other than that. But it was expensive and I didnt really want to go the route of them doing a power flush again (not sure the exact term).
From what I have read it can be hard on the tranny. And it just makes more sense to me to just change the fluid.
08-09-2020, 01:10 PM
If you look at the history of the 750F transmission you’ll see they tend live a long time with minimal maintenance.
Other than looking for leaks, this is the first time the transmission shows up in the Maintenance guide (2020)...
08-09-2020, 05:46 PM
Interesting, I wonder where my mechanic got the idea to flush mine. So if I had mine changed at let’s say 35-40k I should be good to go for quite some time. I’m not going to mess with it. And I do not tow anything with it.
Now on to fixing my rear camera... just quit working. The screen started to go out once and a while, blink and flash a bit, then quit altogether.
08-12-2020, 04:57 PM
I haven't found any other guides, but I do have these two images that might make things easier for you.
Also, check here for a list of Toyota parts, some you need and some you may need: Beginner Fluid Maintenance
08-16-2020, 12:21 PM
Thanks!
08-16-2020, 12:51 PM
Originally Posted by D's Trail
How many oil quart do i need for just drain and fill ?
I maintain a 2014 4R A750E and a 2015 Tacoma A750E - 2WD transmission.
In both cases, I find that if the unit is properly filled to begin with, 3 qts. are drained if the vehicle engine is cold and on level ground. If you elevate the front as high as a good jack will get it, you'll drain another qt. for a total of 4 qts.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
09-08-2022, 03:39 PM
Real Name: Richie From Boston
Detecting tranny fluid temp with Innovia 5610
Has anyone been able to pull accurate drain and flush and refill fluid temps with the 5610 or do I need to stick to this method. transmission temp check mode - Toyota 4Runner Forum - Largest 4Runner Forum
Thanks in advance im trying to make sure Im sorted before doing this thing.
09-08-2022, 04:50 PM
