Need some help here.
I replaced front brakes, pads and rotors, about 2k ago. About 500 miles after bedding the front left started doing the constant cyclic squeal at low, 5-25, mph.
Constant Cyclic Squeeking
Fast forward a little while and they started doing a constant hum at low speed and high pitched noise at high speed until the brake pedal is applied.
So I thought the pads were fword, so I replaced those 2 weeks ago along with all new pins and retainers.
Now the problem is worse. I took the front apart the last 2 saturdays and checked everything. Rotors are fine, not any glazing, and the caliper pistons all seem fine.
I got fed up and took it in to Toyota to have their techs inspect it. The tech recommended a full brake fluid replacement at $170. He believes the issue is due to air in the system.
Has anyone had these issue, and were you able to solve it with fluid flush?
Any other ideas?
