09-15-2021, 05:25 PM
#136
Originally Posted by arehman11
Hey there, I’m noticing some odd handling characteristics with my 2” rear lift on my 5th gen. Can this be installed with a 2” lift only? Or is it meant for higher lifts?
Bump this my 2013 has a 2" lift in the rear are these brackets necessary for a particular height lift? If so which setting would be ideal?
Thank you in advance.
Charles
09-23-2021, 06:16 PM
#137
Charles
are they necessary? Thats up to you. If you are getting rear bumpsteer or butt wiggle on road when you hit freewway expansion joints then probably yes.
If you are getting fishtailing while offroading in 4hi mobbing it through the desert, than probably yes.
Does your OCD kick in, when you notice that your rear passenger tire sticks out half a inch from your driver side...then probably yes.
Issues with panhard geometry didn't become apparent to me until I went with a super stiff rear spring that pushed my rear end up 3 inches unloaded, and made the rear end a bit more sensitive to changes in the road. Most people don't have this problem.
Probably hole closest to axle. You can always just crawl under vehicle and mock up the bracket against your panhard while the vehicle is on the ground. Goal is to get the bar as close to PARALLEL with the axle.
I have one on order. I recently installed a adjustable panhard bar and that fixed all the above problems that the PCK does, but its more of a bandaid solution. When i say bandaid, it fixes all the problems the PCK does on day to day driving, but all the problems come back when i play in the desert.
If i had to do it all over again, i'd get the PCK over the adjustable panhard bar.
09-29-2021, 11:07 PM
#138
Real Name: Kirk
Real Name: Kirk
I don't yet but will...your experience (and my OCD) sold me on this. A stunningly simple solution to an aggravating issue.
I already carry almost 300lbs permanently installed extra weight over the rear axle. The new trailer will have a 250=- lb tongue weight. New 600lb over stock Dobinsons rear coils with airbags for good measure. This will allow me to level the panhard rod with OR without the trailer. Very cool.
Ordered!
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
12-12-2021, 05:34 PM
#139
What's this diff from OEM hole to lowest hole on the PCK? There's no real guideline on what the holes are for lift height wise.
Got my 3in/2in lift and wondering if this is needed. Anyone have experience with this on a 2 in rear lift?
12-12-2021, 08:01 PM
#140
just take a peak under your car, if your panhard is not leveled, then you may benefit from this mod.
for me, with a 3 inch lift in the rear, i went to the top hole, so probably the middle hole for a 2 inch lift, but every car is different.
I'll be bringing my vehicle down to 2 inches soon but probably keep the panhard where it is.
01-29-2022, 10:52 AM
#141
Anyone able to confirm the middle hole for 2 in. lift?
Thanks
20' ORP Barcelona red
SSO Sliders, Bumper - Rago rear panels - ARK splash guards - J&L AOS - Desert Does It - Dobinsons lift - 33" KO2's
02-03-2022, 10:03 AM
#142
Just received my PCK.
Has anyone used this with an adjustable panhard rod to correct thrust?
Can anyone confirm which rod works?
I would think raising the contact would need a shortened rod as I don't see the hole offset slightly to compensate for length of the rod.
02-03-2022, 10:07 AM
#143
do the middle hole.
02-03-2022, 07:46 PM
#144
Official Vendor
Official Vendor
Hi there, just saw this one - first, adjust your panhard back to stock length, then use the hole that gets you closest to level without the axle end being higher than the frame end, at your typical load level.
If you want to measure your actual rear lift height (as far as the PCK is concerned) then take the delta between the height of the axle end (factory hole) and the frame end.
oh, - and thanks for the order!
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
08-08-2022, 08:34 PM
#146
Official Vendor
Official Vendor
Originally Posted by Hi-desertT4R
Just ordered one for my 4th gen. Finally
Thanks, I appreciate it!
keith
eimkeith.com
08-23-2022, 02:29 AM
#147
Thinking of ordering one for the 4th gen. I have a 1 inch lift because of all the gear I carry. I might switch to stiffer springs in the future. Anyone have experience changing holes and is it easily done? I first need to find a welder in NorCal too. Recommendations appreciated.
2006 Limited V8 4x4. Shadow Mica. FN fx pro wheels. bfg ko2 265/70/17 load range C.
Full album
