Originally Posted by changingtime
my 4runner has about 25k miles on it (2016 limited). I have noticed a faint smell of coolant the last couple times of driving (after walking around the front of the 4runner - is when i smelled it).
Levels in the overflow are exactly the same. is this common? i see if the older forum postings (3rd and 4th gen), this seems common.
Possibly a system purging and smelling from the reservoir?
Hi changingtime,
I my opinion this is
NOT AT ALL common or normal. If you're smelling ant-freeze/coolant, then there is some coolant leaving the cooling system; even if it is in the vapor stage! Like you, my 2012 4Runner (Limited) has very low mileage
'20,170' miles on the clock and no sweet odor of anti-freeze seepage at all.
If I were you, I'd start by placing a clean flat moving/storage cardboard box under the truck directly underneath the radiator, hoses and coolant bottle area when the engine is hot, or normal operating temperature and leave it there over-night. When you pull out of the parking space/driveway, I'd examine it to find any spots or evidence of wetness on the cardboard as a starting point.
If nothing is found, I'd take it to the local
'Auto-Zone' and have them do a pressure test using a hand held air pump from 12 to 15 psi. The system must hold system pressure for a given amount of time... that amount of time would depend on the engine temp and rate of cool-down while under pressure.
But if it does leak, there should be evidence of coolant discharge from the origin of leakage e.g., loose hose clamp, water pump weep-hole or seal...etc! The leak can be very small at this point so be sure to give it time to start showing wet spots near or around the source of leakage! Please be sure to let us know what you find after doing some simple tests at home or Auto-Zone!
'Best to you'
rig
