Thread Tools Rating: Thread Rating: 17 votes, 3.29 average. Display Modes
Old 04-19-2019, 10:25 PM #196
mynameistory's Avatar
mynameistory mynameistory is offline
mynameistory will become famous soon enough
Originally Posted by 4FL View Post
Sorry if this has been answered, but I read many pages and could not find.
I have a US 4r trail (not know if there is a difference between US and Canada, so everything is in Fahrenheit and miles, can I get the display to display in Celsius and KM?
I ask because I see that there is one with the celsius, but he is in Canada. Not know if can select, or got to buy a certain display, or it not work at all.
edit; this is a cool mod, only found out about it from another thread, this might be my first "real" mod I do.
It will display in the units your truck is set to. The part is the same for all trucks.
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
mynameistory is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 10:35 PM #197
4FL 4FL is offline
4FL is on a distinguished road
4FL 4FL is offline
Ok, thank you. Looked and seems have to have the dealer do some techstream thing to get the units changed.
2015 Trail Premium w/KDSS, nautical blue, tinted windows, factory running boards, Cooper Discoverer AT3 4S stock size.
4FL is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 10:47 PM #198
Yeah you'd have to techstream it to intentionally switch the truck over to Celsius. The AMD will just parrot whatever's currently on your speedometer display.
-Tory
Old 04-20-2019, 09:03 AM #199
Paragon1's Avatar
Paragon1 Paragon1 is offline
Paragon1 is on a distinguished road
Paragon1's Avatar
This is the one item i miss the most from my 2010 Trail, definitely in on the next group buy. Probably just gonna buy the new display instead of hunt for one. Don't have much spare time.
2015 Silver TE: KDSS, ICON UCAs, Magnuson, NFab steps, Yakima, XD HID, Phillips LED fogs, LED interior, Fuel Maverick 18x9 w/ -12o/s, Duratrac 275/65/18, 5100's Leveled, SSS hybrid winch bumper, 30" Rough Country single row LED, AOB saquatch light switch (because awesome), Alpine ILX-F309 head unit & R line speakers, clear UV tint on windshield (it works), 15% on the doors, weathertech mats, pre-refresh roof rack, installed factory sliding tray.
Paragon1 is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 09:08 AM #200
SR5Bart SR5Bart is offline
Real Name: Bart
SR5Bart will become famous soon enough SR5Bart will become famous soon enough
Real Name: Bart
You should be able to do it yourself. Go into settings in the little screen between the speedo and tach
18 Trail. Cookie cutter built
SR5Bart is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 10:10 AM #201
Icantdrive55 Icantdrive55 is offline
Icantdrive55 is on a distinguished road
My clock has cancer, and I dont trust the dealership to fix it and not **** up the dash trim....
Guess I'm in on the next one.
Icantdrive55 is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 12:55 PM #202
Old Red's Avatar
Old Red Old Red is offline
Old Red has a spectacular aura about Old Red has a spectacular aura about
Old Red's Avatar
Originally Posted by perf0rmance View Post
If you turn on your lights (headlights and/or parking lights), the accessory meter will dim. Your instrument cluster and navigation will dim as well, but you can override this with the dimmer switch by rotating the illumination wheel to the max (to the indexed position). The accessory meter does not respond to the override. All lights will dim accordingly with the adjustment wheel as expected - but the override won't work with the accessory meter.
Please let me know if this is intended behavior.
Right, so this is the intended behavior in that the display will only be as bright as the LED back lit buttons on the dash when the headlights are on. With headlights off, the display is back lit by 11 LEDs which are powered via accessory power. When the headlights are on, those 11 LEDs are joined by the mode and set button LED's. Those combined 13 LED's are then powered by the lower voltage from the dimming + circuit and are grounded by the dimming - wire (Grey wire). The button's dim with the click wheel.
If you use the override on the dimmer wheel, you should notice that only the Instrument cluster and Radio screen are the only things that brighten up with the override click. This is because the LED driver chips for dimming, etc. are located on the instrument cluster PCB, and the brightening message for the radio screen is sent from the instrument cluster via the CAN BUS to the radio.
SIDE NOTE - when I first powered up the meter, the compass was incorrect (as expected). I re-installed the panels and such, went for a drive, and now the compass is correct. I did not bother to re-calibrate but for some reason, it has changed on it's own. I have a pic of the unit when first installed (west) and now it's changed on it's own after going for a drive (now says south when parked in my garage).
Well by driving you essentially calibrated it in a way lol. Does the direction heading still have the "." next to it? The compass inside the display (wierd little block below the display) is basically a copper coil that senses the magnetic fields. I will post up a picture of it later today if I get a chance. I would still calibrate it via the internal menu in the display. Just find an empty parking lot to do it.
1994 "Old Red" Toyota Pickup Garnett Pearl Red 4x4- STOCK FOREVER
2016 MGM 4Runner Base SR5 4x4-
Factory Nav & Heated Seats Conversion, Limited Interior Illumination, TRD Crawl Control/MTS Conversion, Alea Leather; Creator of the 2015+ Accessory Meter Display Mod; More mods coming...
Old Red is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 12:57 PM #203
Old Red's Avatar
Old Red's Avatar
Originally Posted by ElectroBoy View Post
I just installed mine and Iím pleased with it.
As far as dimming is concerned, the meter is not dimmed by the wheel as you mentioned, but by its own built-in function.
Press and hold the ďModeĒ button for about 5 seconds to get to the dimming mode and make your selection. There are three levels.
Yes, just make sure your headlights are off when you hold "Mode" to get into the menu.
Old 04-20-2019, 02:54 PM #204
4FL 4FL is offline
4FL 4FL is offline
It does a few things in the settings, but not change to Celcius.
My Ford Edge was able to, but that was the only positive thing about that POS, lol.
I will just get in on this group buy thing, then after install, will get the dealer to techstream where I can have a celcius read out.
Old 04-23-2019, 06:51 PM #205
Valkyrie18trd Valkyrie18trd is offline
Real Name: George
Valkyrie18trd is on a distinguished road
Real Name: George
would also be in for the next group buy, by far the best interior mod i have seen. just got my 2018 trdop and would love to install thisss!!
Valkyrie18trd is offline   Reply With QuoteReply With Quote
Old 04-23-2019, 10:10 PM #206
57buick's Avatar
57buick 57buick is offline
57buick is a jewel in the rough 57buick is a jewel in the rough 57buick is a jewel in the rough
57buick's Avatar
I have a 2018 ORP and I can change between C and F and KM and Miles in my steering wheel menu
2018 TRD Premium, KING suspension, 285/70/17 Duratracs, 4.88 gears, Addicted offroad front Bumper, C4 FAB rear bumper, My build thread https://www.toyota-4runner.org/5th-g...ld-thread.html
57buick is offline   Reply With QuoteReply With Quote
Old 04-24-2019, 07:40 AM #207
Truck Norris Truck Norris is offline
Truck Norris is on a distinguished road
This is great! Looking forward to the next group buy
Truck Norris is offline   Reply With QuoteReply With Quote
Old 04-25-2019, 03:47 AM #208
perf0rmance perf0rmance is offline
perf0rmance is on a distinguished road
Yes, the dot was there. The compass was slightly off where my nav would go from N to NW first, then the accessory meter would switch a few seconds later (as my vehicle turned even more).
I calibrated it today and it matches as intended - dot is gone as well.
Thanks again, Tanner!
perf0rmance is offline   Reply With QuoteReply With Quote
Old 04-28-2019, 02:57 PM #209
daneo daneo is offline
daneo is on a distinguished road
In for the next round of group buys. I donít check on here often so hoping Tanner can pm me if he sees this
daneo is offline   Reply With QuoteReply With Quote
Old 05-02-2019, 12:28 AM #210
PatrickBateman's Avatar
PatrickBateman PatrickBateman is offline
PatrickBateman is on a distinguished road
After 2 hrs I figured out mine didnít come with a tap. Wondering what the hell am I doing wrong the whole time. 🤦🏻*♂️
Ordered t-tap on amazon. Fml
2018 TRD Pro
PatrickBateman is offline   Reply With QuoteReply With Quote
Clock Display 2015 Trail Edition Erkelbot 5th gen T4Rs 137 06-24-2018 09:41 PM
Plug & Play Foglight Conversion Harness' TotalAutomotiveLV Total Automotive Performance 37 09-22-2016 05:42 PM
Accessory Meter Freezing? deejayshag 5th gen T4Rs 2 05-24-2011 10:03 PM
Help with 05 to 06 headlamp conversion (harness) racer08 4th Gen T4Rs 6 03-04-2008 06:14 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
