Thread Tools Rating: Thread Rating: 17 votes, 3.29 average. Display Modes
Old 07-11-2018, 12:46 AM #46
Jarheadoo7's Avatar
Jarheadoo7 Jarheadoo7 is offline
Jarheadoo7 is on a distinguished road
Jarheadoo7's Avatar
Originally Posted by Turfboy View Post
It is ALIVE!
I was going to do an orange display in my 15! Looks awesome! Where did you find the display?
Jarheadoo7 is offline   Reply With QuoteReply With Quote
Old 07-11-2018, 10:16 AM #47
Turfboy Turfboy is offline
Turfboy is on a distinguished road
Install process notes:
1) The metal tabs on the radio WILL scratch anything they touch.
2) The plug that controls the AC WILL plug into the empty radio socket.
3) There is a set of wires on the radio that you do not have to unplug
4) The two wires on the harness go on the same side of G13
5) The first notch on the key turn will just light up the clock, the second is the one that will tell you if the install went right.
6) A sharpie to lable the plugs you pull out will speed the reinstall.
Some more pics:
The top is the plug that shows the LIGHT GREEN wire to be tapped (#4 from right side)
The second is G13 showing both wires plugged in.
All in all a most excellent build!
2015+ Accessory Meter Display Mod & Conversion Harness How To-20180710_191128-jpg  2015+ Accessory Meter Display Mod & Conversion Harness How To-20180710_192728-jpg
2016 trail premium,KDSS, ALPRO Apex Sliders, Focal IS690TOY, Old Red's Accessory Meter Display Mod
Turfboy is offline   Reply With QuoteReply With Quote
Old 07-11-2018, 11:18 AM #48
I had bugged Old Red with various incorrect LCD displays until he was able to tell me what and where to look for one.
#5 for the win!
Honestly though, I want to post on the main board the question you ask. What is the best way to locate a used part from the yards. I just have not formulated the question to avoid the obvious replies (eBay, parts.com, etc) I can locate the parts car at the auction web pages but I can not follow them to the parts yard they go to so I can ask for a quote/pull.
2015+ Accessory Meter Display Mod & Conversion Harness How To-20180710_185054-jpg
Old 07-18-2018, 05:44 PM #49
Jarheadoo7's Avatar
Jarheadoo7's Avatar
I would just like to add...
When inserting the wires into the G13 clip you must release the white plastic lock otherwise the wires won’t go into the black harness all the way and ‘click’ in place. You have to pry that little white plastic lock part away from the clip like it’s coming out. This was stated in the original how to, I was just confused on what direction that white plastic lock part should be going. It makes sense once you get it but I thought I was going to bust the clip prying in all directions. You have to pry it away from the black clip, as if the clip was laying on a table and the white piece was facing up, you pry it up, then seat the wires then snap it back in place.
Old 08-04-2018, 11:44 AM #50
mstpn2 mstpn2 is offline
mstpn2 is on a distinguished road
Works Great!
Installed mine today and love it! Great job on the instructions and thanks again for the hard work to figure this out and create the harnesses!! Highly recommend to anyone considering doing this, you won't regret it!
mstpn2 is offline   Reply With QuoteReply With Quote
Old 08-20-2018, 12:42 PM #51
jcage89's Avatar
jcage89 jcage89 is offline
jcage89 is on a distinguished road
jcage89's Avatar
Cool
Some more pics:
I did the mod yesterday and would definitely praise Old Red for his workmanship on the harness, dedication to support of his work and the extremely detailed How To. The parts I would like to emphasize is #1 to re-emphasize Turfboy's comment that The two wires on the harness go on the same side of G13. By same side, another way of saying it is if you pinch the edge of the G13 clip that the two wires go into between your thumb and forefinger, the wires would both be next to your fingers... one under your thumb your thumb and the other under your finger. Old Red's How To showing those wires and where they go is really detailed but unless you are paying really close attention (just like he instructs you to do) it is easy to miss that he flips the G13 between the two pictures.
Next thing is a part I was still not comfortable with and would have liked to see more detail about how to remove the softex material behind the steering column while taking out the cluster bezel. here is a picture with more detail about how the clips to that softex look and showing the rigid part that anchors the softex which is where you need to pry to avoid ripping the delicate softex.
Cheers, and thanks again to Old Red for all of his work and the awesome Mod.
JC
18 CavBlue TRDPro
06 4runner Sport
jcage89 is offline   Reply With QuoteReply With Quote
Old 08-21-2018, 12:38 AM #52
Old Red's Avatar
Old Red Old Red is offline
Old Red has a spectacular aura about Old Red has a spectacular aura about Old Red has a spectacular aura about
Old Red's Avatar
Hey guys, sorry for the absence as of late. I have been checking in but not posting. Work has been crazy, but it is starting to settle down. I have seen the feedback on adding some clarification to the original instructions/images, and will be doing so. You guys are awesome! what can be clear to me may not be so for others, so if more detail is needed on a certain step, or better images, etc. I am more than happy to update/clarify.
-Tanner
1994 "Old Red" Toyota Pickup Garnett Pearl Red 4x4- STOCK FOREVER
2016 MGM 4Runner Base SR5 4x4-
Factory Nav & Heated Seats Conversion, Limited Interior Illumination, TRD Crawl Control/MTS Conversion, Alea Leather; Creator of the 2015+ Accessory Meter Display Mod; More mods coming...
Old Red is offline   Reply With QuoteReply With Quote
Old 08-27-2018, 02:40 AM #53
docsnavely's Avatar
docsnavely docsnavely is offline
docsnavely is on a distinguished road
MY GARAGE
docsnavely's Avatar
MY GARAGE
Hell, Iím still searching yards and websites for a blue display. Take all the time you need.
2018 Cavalry Blue TRD Pro - Trips and Mod Thread
Former owner of a 2015 Nautical Blue Metallic Limited with 3rd row and managing owner of my wife's 2013 PriusC III
docsnavely is offline   Reply With QuoteReply With Quote
Old 09-01-2018, 06:47 PM #54
rayofsi rayofsi is offline
rayofsi is on a distinguished road
Thanks finally got this done! Lost direction display in steering column when I swapped to Alpine nav. Nice to have it here
2015+ Accessory Meter Display Mod & Conversion Harness How To-20180901_182918-jpg
2017 Barcelona Red TRD PRO - Urd Supercharged - ADS Shocks with External Reservoir/Clickers - JBA UCA - SCS RAY10 Black - Kumho AT51 275/70R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 09-01-2018, 08:40 PM #55
slprciv slprciv is offline
Real Name: Nick
slprciv will become famous soon enough slprciv will become famous soon enough
Real Name: Nick
Sub'd
slprciv is offline   Reply With QuoteReply With Quote
Old 09-13-2018, 07:34 AM #56
Matty0317 Matty0317 is offline
Real Name: Matt
Matty0317 is on a distinguished road
Real Name: Matt
Awesome Job on this! Will be placing an order as soon as we're done with the aftermath of Florence. Thanks for the writeup
Matty0317 is offline   Reply With QuoteReply With Quote
Old 09-15-2018, 04:04 PM #57
TaNk007 TaNk007 is offline
Real Name: 2017 TRD PRO
TaNk007 is on a distinguished road
Done!
2015+ Accessory Meter Display Mod & Conversion Harness How To-20180915_125111-jpg
TaNk007 is offline   Reply With QuoteReply With Quote
Old 09-15-2018, 04:24 PM #58
Old Red's Avatar
Old Red's Avatar
Originally Posted by TaNk007 View Post
Done!
Nicely done!!!
Old 09-17-2018, 12:06 PM #59
Dave 41079 Dave 41079 is offline
Dave 41079 is on a distinguished road
Finding a used blue screen is a royal pain. I just don't feel like paying almost $400 for this by buying a new screen.
Dave 41079 is offline   Reply With QuoteReply With Quote
Old 09-17-2018, 12:08 PM #60
vicmm vicmm is offline
vicmm is on a distinguished road
About $365 shipped is not too bad, you can always keep your old screen as a backup
vicmm is offline   Reply With QuoteReply With Quote
Clock Display 2015 Trail Edition Erkelbot 5th gen T4Rs 137 06-24-2018 09:41 PM
Plug & Play Foglight Conversion Harness' TotalAutomotiveLV Total Automotive Performance 37 09-22-2016 05:42 PM
Accessory Meter Freezing? deejayshag 5th gen T4Rs 2 05-24-2011 10:03 PM
Help with 05 to 06 headlamp conversion (harness) racer08 4th Gen T4Rs 6 03-04-2008 06:14 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
