10-24-2018, 11:01 AM
#61
Thanks for the reply...how often have you needed to clean/re-oil the filter?
2018 TRD Off Road
1996 FZJ80
1969 FJ40
10-24-2018, 11:17 AM
#62
Real Name: Chris
Real Name: Chris
I just installed mine on Monday, I would guess it depends on the environment you live in or if you go on dusty trails, etc. I would think once a year would be sufficient, but I plan to check it in the spring and see how bad it is. They're only 15-20 bucks so if they get too dirty I will just replace it
10-24-2018, 01:19 PM
#63
Real Name: Max
Real Name: Max
I'd be interested to see what effect the oil from the oiled filter has on the pump over time. I know they can over time gunk up MAF sensors and throttle bodies on engine filters. Wondering if there will be anything similar for these...
10-24-2018, 02:14 PM
#64
Real Name: Chris
Real Name: Chris
Doubtful much if anything, they're very small and don't appear to have much oil on them really. Not much more harm that foam coming apart and getting sucked into the fan at least lol
10-24-2018, 03:42 PM
#65
UNI filter is a dry filter (no oil).
10-26-2018, 08:51 PM
#66
Real Name: Chris
Real Name: Chris
The only time oiled filters cause issues is when people don't read simple instructions and over oil them. 100K miles on the K&N filter on my wifes truck. Washed and oiled two or three times since installed and never an issue. I think i'll go with the UNI though simply because it's black and will blend in like it's OEM
10-27-2018, 05:15 AM
#67
Does the secondary air pump always run or does it only spin on start up and shut down?
10-27-2018, 08:23 AM
#68
It only runs at start up and shut down.
10-27-2018, 05:56 PM
#69
Real Name: Todi
Real Name: Todi
Ordered yesterday, in today. I went with UNI filter for the same reasons
The original sponge filter
2018 TRD OR
- SSO Full Rack; Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load – front, Performance Load – rear; M.O.R.E. aluminum full set skid plates; Artec aluminum gas tank skid; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; ReszFab flat sliders; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E;
10-27-2018, 06:16 PM
#70
Real Name: Chris
Real Name: Chris
Originally Posted by TodiN
Notice any additional noise or anything? Some people do, some people don't.
10-27-2018, 07:53 PM
#71
Originally Posted by Taco04
I have had one on my 4runner for over a year. This is a well known problem on Tacoma's since they were one of the first victims to receive the crappy air pumps. Any way below are some pics of the one on my 4Runner never mind the air pumps location it has been moved to make room for a couple of other things. The only thing I have noticed is it makes the pump a bit louder as it probably breaths a bit better now.
With the factory cover on. Not worried about ingesting water on mine the truck will be floating before this thing takes in water on so I will have far greater issues....
Would this void a warranty?
10-27-2018, 07:57 PM
#72
Location: N California (not the middle called northern)
A warranty on a part that is ruined by a lawnmower filter when it fails? No way, no how.
2018 TRDP Cavalry Blue
10-27-2018, 08:05 PM
#73
Is that shrockworks washer reservoir kit I see there??
Mods are loading.......
10-27-2018, 10:14 PM
#74
Real Name: Chris
Real Name: Chris
If the pump happens to fail under warranty, just put the OEM filter and cone back on before you bring it to the dealer. This is all 100% reversible with no evidence it ever happened.
10-27-2018, 10:57 PM
#75
Real Name: Todi
Real Name: Todi
No additional noise and I don’t know why would it be if installed correctly...
2018 TRD OR
