Thread Tools Rating: Thread Rating: 2 votes, 4.00 average. Display Modes
Old 07-25-2018, 04:59 PM #1
TOTAL CHAOS TOTAL CHAOS is offline
TOTAL CHAOS will become famous soon enough TOTAL CHAOS will become famous soon enough
TOTAL CHAOS Upper Control Arms
Upper Control Arms contacting your coil overs?
Can't get your vehicle into proper alignment specs with 2-3" of lift?
Looking to ditch the stock ball joint setup for a much stronger uniball UCA?
TOTAL CHAOS has you covered!
TOTAL CHAOS
(03-18) 4Runner - Upper Control Arm
- 100% Bolt-On UCA constructed of 4130 Chromoly.
- Designed with added caster. When you lift a vehicle with factory upper control arms the wheel will move towards the rear of the vehicle (negative caster). With negative caster you will often have wandering or darting of the vehicle. The TOTAL CHAOS UCA's have positive caster built-in for lifted applications. This allows vehicles with 2.5-3" lifts to get back into factory alignment specs.
- TOTAL CHAOS includes 1" I.D. uniballs that feature a heat treated stainless steel ball & heat treated stainless steel race for maximum corrosion resistance and component longevity. These uniball's also features a military grade PTFE woven fabric liner that helps prevent noise.
- Custom profile upper and lower hi-misalignment spacers maximize droop wheel travel and are machined from heat treated 17-4 stainless steel. Will allow for up to 1" of additional wheel travel when paired with extended travel coil over shocks.
- Urethane bushings reduce bushing deflection compared to stock rubber bushings
- 2 stage powder coat process includes a durable clear coat to provide a long lasting finish.
- Complete grade 8 hardware kit is included
ORDER HERE
HOW TO VIDEOS:
UCA Bushing Prep *** WATCH BEFORE GREASING YOUR ARMS ***
UCA Uniball Prep
UCA Bushing & Uniball Replacement
TOTAL CHAOS
WWW.CHAOSFAB.COM
TOTAL CHAOS is offline   Reply With QuoteReply With Quote
Old 07-25-2018, 05:12 PM #2
Running a larger lift application or simply want more alignment adjustability?
OPTIONAL HEIM PIVOT UPGRADE
- TC includes 3/4" chromoly heim joints for the pivots.
- Heim upper control arms are fully adjustable to allow maximum tuning of caster and camber.
- Designed for use on 6" or higher drop bracket lift kits.
LEARN MORE
Old 07-25-2018, 06:32 PM #3
Hadelson's Avatar
Hadelson Hadelson is offline
Hadelson will become famous soon enough
Hadelson's Avatar
Quick Question: How does this affect the wheel balance issues experienced with 4 Runners at 55MPH-65MPH running lifts, spacers and larger tires?
Hadelson is offline   Reply With QuoteReply With Quote
Old 07-25-2018, 07:05 PM #4
Tuc4R's Avatar
Tuc4R Tuc4R is offline
Tuc4R is on a distinguished road
Tuc4R's Avatar
Installing mine this Friday, along with ADS coilovers and rear shocks.
2018 TRD ORP W/KDSS & Sunroof - ADS C/O's and rear RR, TC UCA's, Icon 2' springs, SSO bumper, Smitty X20, Nitto RG, FX PRO wheels, AVID sliders, RCI Alum skids, Bussmann RTMR, Canvas backs, Accessorides remote start, Rago Molle’s, HID low's, LED high's, Morimoto XB fogs, Ceramic window tint, Ecotechne roof rack, ARB diff breather, Indel B TB51, Ellis shift knobs, Plastics Guy bump stops, ARB twin comp., Pedal Comm, X2 Power G27
Tuc4R is offline   Reply With QuoteReply With Quote
Old 07-25-2018, 07:06 PM #5
TRDORmike's Avatar
TRDORmike TRDORmike is offline
TRDORmike is on a distinguished road
TRDORmike's Avatar
I would like to know this as well..
2017 TRD Off Road w/KDSS.
275/70/17 KO2s
Fuel Vector 17x8.5 +7
Bilstein 5100s @ .85
TRDORmike is offline   Reply With QuoteReply With Quote
Old 07-25-2018, 07:11 PM #6
This will not change wheel balance, but will help greatly with alignment. These arms have positive caster built-in which was designed to allow factory alignment specs on lifted applications. As a result, there is much less wandering or darting of the vehicle. Customers often report a more "planted" or "stable" feel when driving with TOTAL CHAOS UCA's.
TOTAL CHAOS
WWW.CHAOSFAB.COM
Old 07-25-2018, 07:13 PM #7
Sweet! Post up some pictures once you've got them in
TOTAL CHAOS
WWW.CHAOSFAB.COM
Old 07-25-2018, 07:14 PM #8
TRDORmike's Avatar
TRDORmike's Avatar
TOTAL CHAOS
WWW.CHAOSFAB.COM
Yes definitely will not change the wheel balance. I think more of his questions relates to being that these trucks STOCK are so sensitive to any imperfection does this planted feel also numb some of those issues.
Given the change in geometry thinking it may possibly lessen the tire balance feedback going to the steering wheel
275/70/17 KO2s
Old 07-25-2018, 07:40 PM #9
bnorton00's Avatar
bnorton00 bnorton00 is offline
Real Name: Brandon
bnorton00 is on a distinguished road
bnorton00's Avatar
Real Name: Brandon
I'm running TC UCAs. More details are in my signature. I will say that I do feel more feedback in the steering wheel, but that is likely due to a more massive tire and stiffer sidewalls. I would not necessarily count that as negative. Overall, the truck is incredibly predictable and stable, even during evasive or aggressive maneuvers.
2017- LAND CRUISER!!!!
2018 TRD PRO- Sold
2016 TORP- Sold
KI5BAH
bnorton00 is offline   Reply With QuoteReply With Quote
Old 07-25-2018, 08:06 PM #10
MTN4RNR's Avatar
MTN4RNR MTN4RNR is offline
Real Name: Max
MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough
MTN4RNR's Avatar
Real Name: Max
I have had my Total Chaos upper control arms installed on my 4Runner for the last 15k since I upgraded to King shocks and Dobinsons rear springs. The UCA's have been great. They are easy to maintain and keep quiet with super lube on the bushings and Tri-Flow dry lube on the uni-ball. My front end is in alignment spec with the approximate 2.5" lift I have on the front coil overs. The handling is tight and confident on and off-road with little to no negative side effects that are typical with increased control arm angles. Overall, they're one part that I don't need to worry about on the 4R, and I would do it again in a heartbeat.
Thanks for the product, @TOTAL CHAOS
2016 MGM Trail Premium - KDSS
Explore4R.com
Building the MTN4RNR
Instagram --- life.to.the.max
Writer/Editor at Trail4Runner.com
MTN4RNR is offline   Reply With QuoteReply With Quote
Old 07-25-2018, 08:10 PM #11
danielhfranks's Avatar
danielhfranks danielhfranks is offline
danielhfranks is on a distinguished road
Loving mine on the 4runner. Had them previously on two Tacomas and wouldn't go with any other. Thanks for making a great product.
danielhfranks is offline   Reply With QuoteReply With Quote
Old 07-25-2018, 08:44 PM #12
The added caster built into the TC UCA’s will reduce the darting and road wandering tendency that is associated with most 2-3” lift kits. Making sure that you have proper wheel balance and alignment are the only true remedy to the balance or feedback issues that you are experiencing.
People often take for granted the performance that can be lost with improper rim and tire combinations, or worn out tires. These are very important components to consider when you measure your overall ride quality. We also recommend that you check for worn out ball joints, tie rod ends, and lower control arm bushings. These components all require periodic maintenance whether you run stock or aftermarket equipment. Worn out uniball’s can also be a factor to uneven tire wear or poor steering response.
Hope this helps!
Old 07-25-2018, 08:48 PM #13
TOTAL CHAOS FABRICATION
Thank You for the support and feedback! We really appreciate it.
Always love seeing rig photos! Keep them coming
TOTAL CHAOS
WWW.CHAOSFAB.COM
Old 07-26-2018, 10:59 PM #14
Since you asked-
Old 07-27-2018, 05:07 PM #15
Since you asked-
Very nice! Thanks for sharing
TOTAL CHAOS
control arm , total chaos , uca , upper control arm
FS: 5th Gen Total Chaos Upper Control Arms $600, Bay Area, CA ybukhan For Sale: Suspension/Wheels/Tires 6 12-13-2016 01:30 AM
FS - Total Chaos Fab Uniball Upper Control Arms (3rd Gen) - BRAND NEW - $450 OBO NotKewl For Sale: Suspension/Wheels/Tires 4 09-19-2016 06:18 PM
Total Chaos Upper Control Arms + 2.5 Fox/King Coilovers with Rem Res tplane2 Want to Buy/Trade 0 03-07-2013 10:50 AM
brand new: TOTAL CHAOS upper control arms Chaplain Classifieds - buy & sell (no commercial ads please) 1 12-17-2009 05:01 PM
