Thread Tools Rating: Thread Rating: 7 votes, 2.43 average. Display Modes
Old 08-02-2018, 05:56 PM #1
Baja Designs's Avatar
Baja Designs Baja Designs is offline
Official Vendor
Baja Designs will become famous soon enough Baja Designs will become famous soon enough
Official Vendor
Baja Designs Fog Lights
Baja Designs - Plug and Play, Fog Light Kit
Now on its fifth generation, the Toyota 4Runner has earned a reputation for bullet-proof ruggedness, rock-solid dependability and, over the last two generations, comfort and refinement. It's the perfect SUV (almost). One area that could use improvement is the factory lighting system. Once you take the 4Runner off-road, you'll want to see what's ahead of you sooner.
The Baja Designs 4Runner fog pocket mounting brackets allow you to add the lighting power you need without ruining the clean lines of your Toyota 4Runner. Our fog pocket mount kits are designed for Baja Designs Squadron line of LED lights — the power you need (and then some)
AVAILABLE IN 3 OPTIONS (Stand-Alone, White, Amber)
LEARN MORE
ENTER BDForums coupon code at checkout to save 10% + $5 Shipping to the Lower 48!
bajadesigns.com - Facebook - Instagram - info@bajadesigns.com - (800)422-5292
Baja Designs is offline   Reply With QuoteReply With Quote
Old 08-02-2018, 05:58 PM #2
Official Vendor
Official Vendor
^ Don't forget to apply your forum discount! ^
Code: BDForums saves you 10% + $5 Shipping to the Lower 48.
Apply at www.bajadesigns.com
Old 08-05-2018, 11:18 PM #3
jeroweezy's Avatar
jeroweezy jeroweezy is offline
jeroweezy will become famous soon enough
jeroweezy's Avatar
how hot these get in prolong use
jeroweezy is offline   Reply With QuoteReply With Quote
Old 08-06-2018, 10:36 AM #4
Official Vendor
Official Vendor
Temperature will vary depending conditions and use. These lights do get warm on the exterior of the housing and have built-in thermal management on the inside. If temps start to climb too high the light will slightly reduce performance until temps are back in a safe range.
Baja Designs
www.bajadesigns.com
Old 08-06-2018, 11:14 AM #5
Judd94 Judd94 is offline
Judd94 is on a distinguished road
I still can’t decide between wide cornering or driving combo
17 TRD O/RP Barcelona Red
6112/5160s- 1.6” Front and Dobinsons 599 Rear Coils
Philips 4300K HIDs/ Baja Designs Sport Amber WC
Husky Liners, N-Fab steps, Blackout Kit
Gibson Side Exit Exhaust
Judd94 is offline   Reply With QuoteReply With Quote
Old 08-06-2018, 12:30 PM #6
Official Vendor
Official Vendor
Wide Cornering is ideal for near field lighting and poor conditions like dust, fog, rain, snow, etc. The Driving/Combo is a blend of Wide Cornering and Spot which gives you nice near field, midfield, and distance coverage.
These lights do feature uService Technology which allows you to quickly change a lens pattern or color. You're not stuck with the pattern or color you buy!
Old 08-06-2018, 12:52 PM #7
Well I’m out of excuses at this point!
Old 08-06-2018, 03:20 PM #8
DesertCanyons's Avatar
DesertCanyons DesertCanyons is offline
Real Name: Dave
DesertCanyons will become famous soon enough
Real Name: Dave
Baja Designs wide cornering fog lights
These look great. I want to put these in a new Shrockworks front bumper I'm planning to order soon. I may need to coordinate the opening size, mounting bracket and hole size to accommodate the BD Squadron Sport WC.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
DesertCanyons is offline   Reply With QuoteReply With Quote
Old 08-06-2018, 03:59 PM #9
Official Vendor
Official Vendor
Thank You
Email info@bajadesigns.com if you or shrocksworks needs any info from the BD team.
Baja Designs
www.bajadesigns.com
Old 08-06-2018, 08:28 PM #10
jeroweezy's Avatar
jeroweezy's Avatar
Baja Designs
www.bajadesigns.com
anything to worry about with heat to the bumper? maybe possibly melting ?
Old 08-07-2018, 09:32 AM #11
Official Vendor
Official Vendor
No concerns. The automotive grade plastic takes a lot of heat to melt. Our lights don't get near that temp range.
Baja Designs
www.bajadesigns.com
Old 08-07-2018, 09:37 AM #12
Lost-Again's Avatar
Lost-Again Lost-Again is offline
Real Name: Old man
Lost-Again is on a distinguished road
MY GARAGE
Lost-Again's Avatar
Real Name: Old man
MY GARAGE
Baja Designs
www.bajadesigns.com
So is “slightly reduced performance” still greater or equal to the OEM fogs?
2018 T4R TRD Pro Stock - RSG Sliders - Yaesu 7900 - Cobra 75 - Garmin 55 Dash Cam - Gaia GPS - Garmin InReach Mini - Baja Designs S2s Ditch Lights
Lost-Again is offline   Reply With QuoteReply With Quote
Old 08-07-2018, 09:52 AM #13
Official Vendor
Official Vendor
Greater. More than likely you won't encounter thermal management mode unless you're stopped on a 90 degree night with no breeze. A slight breeze is all it takes to cool these down
Baja Designs
www.bajadesigns.com
Old 08-07-2018, 10:45 AM #14
ChrisJHarney's Avatar
ChrisJHarney ChrisJHarney is offline
ChrisJHarney will become famous soon enough
MY GARAGE
MY GARAGE
I can attest to the performance of the Sport Squadrons, in both near freezing, as well as over 100 degree temps.
I run these in my @pelfreybilt bumper to supplement my S8 light bar. I run wide driving pattern exclusively because I never find myself reaching any speed over 30mph at night on a trail, and rarely ever over 10mph on average. Wide driving spread in the fog light configuration gives me excellent visual of brush and ditches on either side of the trail. You can’t even compare light intensity between the factory “fog” lights and these, they aren’t even in the same league.
I have run these in Mojave up near Mid Hills while it’s been snowing in January, and also out in Anza Borrego in June at dusk with the temps over 102 with absolutely ZERO issues. Not saying it can’t happen, but I have never had decreased performance in actual use.
ChrisJHarney is offline   Reply With QuoteReply With Quote
Old 08-07-2018, 11:22 AM #15
SR5Bart SR5Bart is online now
Real Name: Bart
SR5Bart will become famous soon enough SR5Bart will become famous soon enough
Real Name: Bart
Mine should be here tomorrow!!!
18 Trail. Cookie cutter built
SR5Bart is online now   Reply With QuoteReply With Quote
baja designs , fog lights , lights
Baja Designs Offroad LED Lights Get Brighter TotalAutomotiveLV Total Automotive Performance 3 03-03-2019 06:01 PM
New Baja Designs S8 LED Light Bar - Replaces Baja Designs Stealth - Now Shipping TotalAutomotiveLV Engines / Suspension / Wheels / Tires / Audio / Accessories 2 06-03-2016 08:24 PM
4 baja designs 8" la paz lights blue dog For Sale: Non-T4R Items 8 10-02-2013 10:31 PM
Copyright © 2019
