Thread Tools Rating: Thread Rating: 3 votes, 2.00 average. Display Modes
Old 07-20-2021, 05:51 PM #61
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
For the first time since November 2020, the Dobinsons UCA's are finally back in stock!!!
Anyone who has been incredibly patient and waiting all this time, they're shipping out today and over the next couple of days. But the great news is that there is a ton more in stock also, so if you're in the market for some ridiculously beefy UCA's, check these out!!
4Runner UCA's by Dobinsons also suit GX470 GX460 and FJ Cruiser
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 07-20-2021, 05:58 PM #62
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Originally Posted by Crikeymike View Post
I have about 3.5 degrees of caster on my 4runner and zero complaints. The majority of techs seem unable to know how to max out the caster during an alignment anyway, it's a huge issue where "they know what they're doing" but they don't always.
The less lift you have, the more caster you can get in it.
What UCA's are you running now?
Same story here in Phoenix.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
Old 07-27-2021, 07:18 PM #63
4R4Trout's Avatar
4R4Trout 4R4Trout is offline
4R4Trout will become famous soon enough
4R4Trout's Avatar
Caps
Has anyone had issues with the o-ring caps falling off? It looks like they just press in and aren’t threaded. Is there a groove that they snap tight into?
Thanks for the reply’s,
Dave
2012 TE~Shoreline Blue~KDSS~Nav
ARB Diff Breather, Dobinson 302/700, 327/701, Yokohama Geolandar MT G003 255/75R17, ARB CKMA12 onboard air, IndeFlate, Arclight LED, Victory 4x4 Strike rear bumper, Kenwood TM D710GA Ham Radio, Engel MT-45, Method 701 (Black) UpTop Overland Bravo, 38” Extreme LED lightbar, Dobinson UCA
4R4Trout is offline   Reply With QuoteReply With Quote
Old 02-25-2022, 09:19 PM #64
@jrfordlandia's Avatar
@jrfordlandia @jrfordlandia is offline
Real Name: Jason Ford (not related to Henry or Harrison)
@jrfordlandia will become famous soon enough
There is easily over 100 guys on this forum running our UCA's, but I guess they haven't seen this thread.
A sealed ball joint undoubtedly lasts a really long time. Anyone with a 5th Gen running stock UCA's for over 100K miles? I doubt they have ever touched their upper ball joints. That's why we used exactly the same kind as stock, since they'll never have to be touched.
Mike, what is the highest lift you recommend I can run with Dobinson UCAs before the Camber creates tire wear from too much lift?
I am running C59-302 coils on GS59-574 struts plus a diff kit. How much front lift should that give me in theory on a 2018 SR5P with factory bumper and no winch?
I'm currently on C59-505 rears and I have negative rake. I need to lower the front or raise the rear. Otherwise, I'm getting some tire wear on outer edges despite using full adjusted SPC UCAs.
2018 4Runner 4x4 SR5P, Super White w/Third Row, 285-KO2's, SCS Ray10’s, Dobinson 302/505 springs with 700/705 gas shocks, Tandem Sliders, TRD Skid, Cold Air Intake
2015 4Runner 4x2 SR5 Premium, 5100’s, KO2's, Super White (sold)
@jrfordlandia is offline   Reply With QuoteReply With Quote
Old 02-25-2022, 10:34 PM #65
Crikeymike's Avatar
Crikeymike's Avatar
The SPC's you have now have all the adjustment to get it dialed in right. The Dobinsons UCA's have no adjustment, so you wouldn't get it as dialed with those.
I'd say your alignment isn't correct if you're still getting tire wear.
3.5" is the max lift Dobinsons suggests with their parts and UCA's. Camber can get dialed in by the tech, but the more camber it needs, it takes caster away.
You're probably at 23-23.5" from hub to fender on the front with that setup and no additional weight.
You can add one of these to both sides on the back to gain 1/2"
Dobinsons Rear Spacer, 15mm | 4Runner FJ Cruiser Lexus GX470 GX460
Anyone running the new Bilstein 24-248730 / 24-249966 shocks? Opinions? thor999 3rd gen T4Rs 54 07-10-2018 12:32 AM
Dobinsons vs Bilstein 6112/5160 (+ Dobinsons ?s) MossJenks 5th gen T4Rs 14 09-19-2017 10:58 PM
Running Boards Removed, opinions? dirtbike250x 3rd gen T4Rs 38 02-11-2015 11:49 PM
5th Gen Running Boards Opinions dicec2 5th gen T4Rs 4 10-08-2011 08:02 PM
Running Boards/Tube Steps: Opinions Please ARK_SWAMP_RIDER 4th Gen T4Rs 14 04-04-2010 07:42 PM
