Thread Tools Rating: Thread Rating: 3 votes, 1.67 average. Display Modes
Old 01-18-2021, 12:02 PM #31
007Tacoma's Avatar
007Tacoma 007Tacoma is offline
Real Name: Mark the Common Sense Wizard
007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice
007Tacoma's Avatar
Question Why the difference in Gear Oil???
Sorry to resurrect an old thread, but my searching has not found any clear answers.
Toyota Differentials (OEM) run LT 75W-85 GL-5 Gear Oil
Nitro Gears recommends using 80W-140 Gear Oil.
So, I am curious...
Why the difference?
What is the risk of running the lighter oil with the Nitro Gears?
Background information: I have 165,000 miles on my original 3.73 gears with heavy loads and tons of towing. I had zero metal flakes on the drain at 75,000 miles and 150,000 miles. Last month, I upgraded to a Nitro Gears 4.56 gear set. I did the initial break in then drained and refilled with 80W-140 with the expected fine metal shavings a decent looking oil. I refilled it with Castrol 80W-140 per my mechanic's advice. Since then have put 2,500 miles on the vehicle, and I'm about to change the oil again just to ensure everything is okay. I have noticed that my fuel economy is way down. Power is up, but but I can't break 13MPG unloaded cruising at 55 MPH (I was as high as 18MPG fully loaded - not towing).
I'm 007Tacoma.
...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
007Tacoma is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 12:18 PM #32
Captsolo Captsolo is offline
Captsolo will become famous soon enough
I changed the OEM factory diff fluid on my 2005 at 100,000 miles, and don't recall any issues - including pieces in the oil. It was black. Viscosity seemed thin. Hard to judge.
I used Valvoline 80/90 weight - which is recommended (with normal use)
4runner has always driven noiseless and fine.
I'm at 150,000 miles and may do a 6 quart DF soon. Rear-end holds total 12 quarts.
D/F is all Ill do. Hope 6 quarts Drain out - or I'll have to do it twice or call a dealer for advice.
I never changed this on any car I ever owned. Had a new GMC Jimmy - sold at 88,000 miles at ten years old.
two-year-old Cadillac - never touched it - 100,000 miles.
What is the manufacturers recommended maintenance schedule?
I think the posts here are way over maintenance on any rear ends (that don't tow).
The normal service interval for the differential is 90,000 miles so if you cut that in half you should have no issues. The severe service interval is 60,000. differential service - Bing
Captsolo is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 12:40 PM #33
007Tacoma's Avatar
007Tacoma's Avatar
It's not so much the interval or the maintenance... I'm not having any problems with the new 4.56 gears at all. No noises, no problems on first drain/fill - I'm just having a problem with my fuel economy dropping so low since changing gears. That's why I'm trying to determine what I am going to fill up with at this next change. So far, most people I have talked to have not gone up to a 80W-140 after regearing.
I'm 007Tacoma.
Old 01-18-2021, 12:58 PM #34
Jeremy556's Avatar
Jeremy556's Avatar
So, I am curious...
Why the difference?
A heavier weight oil is better for the longevity of the gears, and they don't really care about your MPGs.
I've been running 140w for close to 200k miles on my Nitro gears, but I wouldn't think twice about switching back to a 90w.
Old 01-18-2021, 01:04 PM #35
007Tacoma's Avatar
007Tacoma's Avatar
Yeah, since the initial post I have talked to a few guys about this, and 2 out of 5 people are running the 90W with no problems. However, like most people with 4Runners, they don't really care about their fuel economy. So, they don't track it. Although they have noticed the dash numbers are usually higher since regearing. Most of them have 285+ tires. I am running 255/75 C-Loads because I drive my vehicle so much, and I hate throwing away money in fuel.
Thanks for the reply!
I'm 007Tacoma.
Old 01-18-2021, 01:25 PM #36
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Yeah, since the initial post I have talked to a few guys about this, and 2 out of 5 people are running the 90W with no problems. However, like most people with 4Runners, they don't really care about their fuel economy. So, they don't track it. Although they have noticed the dash numbers are usually higher since regearing. Most of them have 285+ tires. I am running 255/75 C-Loads because I drive my vehicle so much, and I h ate throwing away money in fuel.
When you cruise on highway now how do your rpm at 60 mph compare to previous with 3.73 gears? 3.73 to 4.56 is a significant change.
Old 01-18-2021, 01:59 PM #37
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
I think we went 120K on the last differential and transfer case oil change.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 09:58 PM #38
007Tacoma's Avatar
007Tacoma's Avatar
I am right about at 2,000 RPM at 64 MPH - with the 3.73 gears 2,000 RPM was about 71 MPH.
I'm 007Tacoma.
Old 01-20-2021, 10:03 AM #39
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
I had 1 mile on my TR4 OD when i drove it off the lot; dumped factory rear diff oil at 2200 miles and it looked dark gray and had a good amount of metal shavings. For me its cheep insurance!
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 01-20-2021, 01:12 PM #40
engeeoh01 engeeoh01 is offline
engeeoh01 is on a distinguished road
I drained my rear diff from new every 10K
1) first drain at 10k was very dirty. Thick and grey
2) second drain at 20k was also grey and thick
3) third drain and 30k came out clear, not much grey at all
I plan to service the rear every 30k from now on.
engeeoh01 is offline   Reply With QuoteReply With Quote
Metal-Tech 4x4 Father's Day Sale 2018 | Great Gift Ideas For Dad! MT4X4 Metal-tech 4x4 2 06-15-2018 06:03 PM
FS: Full set factory speakers for 2018 non-JBL; $250 San Diego 18Runner For Sale: T4R Items 1 06-05-2018 05:53 PM
Both rear hub bearing out... drained diff and see metal. Should I be worried? boostedprozac 4th Gen T4Rs 6 04-28-2017 05:33 PM
Rear diff "clicking" with full droop? Fochps 3rd gen T4Rs 4 04-17-2013 12:00 PM
