08-20-2018, 04:10 PM
Smittybilt compressor on board air
Has anyone successfully mounted a smittybilt 2781 compressor on board under your hood? Any insight would be great. If so are there any mounting brackets available? I haven’t been able to find anything on this. Thanks
08-20-2018, 07:02 PM
The underhood locations depend on what year you have, there was a delta in I believe 2012 with the addition of the secondary air pump. Did you search? I searched “5th Gen on board air” and came up with a ton of hits for the different brackets available.
08-20-2018, 11:01 PM
Real Name: Neal
Real Name: Neal
Try a
@ bandi
Mount - Click Here
08-21-2018, 12:28 AM
I have a 2018 and it seems like the only place would be in the top left where people usually mount the viair 400 compressors however the smittybilt one I think is too big. 😬 thanks for the replies though. I’ll check out the bandi Mount
08-21-2018, 08:18 AM
I have a 2018 and it seems like the only place would be in the top left where people usually mount the viair 400 compressors however the smittybilt one I think is too big. thanks for the replies though. I’ll check out the bandi Mount
I have done similar setup already for the Viair 400p. I use my standard ARB twin compressor mount and add some bolt on brackets to allow for the compressor of your choosing, which in the future, you could go to the ARB.... plus this allows for the optional tank and/ormanifolds too....
08-21-2018, 09:10 AM
OP, please post up what you decide to do when you install it. I'm interested to see what you do.
Will you be adding a pressure switch to your 2781?
I installed a flow-through euro-style (clip on) chuck this year, and it's been great. I keep the compressor running the entire time I do 4 or 8 tires. It's as hot as a cannon when I'm through though.... which makes it a pain to load back in that tiny bag. So it has moved to a larger duffel bag, which takes up even more space in the back.
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
08-21-2018, 10:29 AM
Does this setup allow installation of a small tank under the bracket?
TRD OFFROAD PREMIUM WITH SOME STUFF BOLTED TO IT
My Fuelly Log
08-21-2018, 10:48 AM
Yep, either a ARB or Viair 1 gallon (similar to below).
http://www.toyota-4runner.org/sale-t...15-%24150.html
08-21-2018, 11:32 AM
Perfect to see this! I think I’m gonna do that option with the smittybilt it should count perfectly it seems like. My only concern was the smittybilt was 5 inches longer or so.
08-21-2018, 11:34 AM
Yeah I’m going to rig it up at work with a pressure switch probably and also switch out all the fittings on the smitty because it comes with those lame ones anyway so I’ll make it more universal that way
08-21-2018, 02:19 PM
Real Name: Duan
Real Name: Duan
I've been looking to switch out the forms as well. Do you have a lead on what you're looking at?
Sent from my Pixel 2 using Tapatalk
2018 TRD Off Road Premium
Rotiform SIX-OR | Toyo Open Country RT 285/70/17 | Bilstein 6612/5160 OME 2895 | Rhino Rack | Valentine One | Rexing Dashcam
IG: @daohaus
08-21-2018, 02:39 PM
I mounted mine under the hood. It works great. I made a bracket that attached in 3 places. I used 2 existing screw holes and added a rivnut. It was still shaking around a bit so I later added an aluminum brace that attached to the top of the compressor and it’s been solid. the air connection comes out in the passenger wheel well.
'17 MGM SR5, Falken Wildpeak 285, Method Roost, Bilstein 6112/5100, OME 2895e, Camburg UCAs, RSG Sliders, ARB Fridge, ARB Awning
08-21-2018, 05:06 PM
That is a monster !.... Maybe I was thingin' the smittybuilt 2780 would fit and not the 2781'...
Can anyone provided actual dimensions a (see sheet below)? I ask that as the net' listed 16.1", however image Dontkicktrees' posted shows it in an area that's has only 15" total clearance and it has a little room to spare even.
Thank You,
Leroy (bandI)
A =
B =
C (mount holes) =
D =
E (mount holes) =
F =
G =
H =
I =
08-21-2018, 05:22 PM
Not sure yet, I have a lot of options at work but I’m going to post up the details once I get it in
08-21-2018, 05:23 PM
Badass bro. I really like that! I think I’m gonna go with the
@ bandi
mount because I am too lazy to make a bracket haha
