Originally Posted by TOYO74
I can see you don't get out of your basement much, otherwise you would know that floor jacks weighing 80-100 pounds are still being made.
I realize there are aluminum jacks that weight much less, but none weigh as little as the Toyota OEM jack, and even the lighter weight floor jacks still have to be tied down for safety reasons you might not understand. Look up Newton's laws--there are some clues there.
I know the moss and mold in the air in Poo-yall-up can affect one's thinking- so I forgive your insult. Now can we get back to the topic?
MY 3 ton floor jack is 78lbs a heavy jack but if you work on vehicles you do the lift mods and other work on vehicles the floor jack I have is solid ..
also bottle jacks are needed to do the vehicle work.. I also used the 20 ton bottle jack to lift up my house in certain areas on the floor joists..
my PDF shows were to jack posts are so now it is how the procedure works with Toyota instructions and the equipment..also how members have had their jacking results with big tires lifts how much lift etc..
he is very smart to go thru this jacking procedure before his trip.. and also check the spare tire air pressure.
or JUST CALL AAA... LOL..
