Old 08-28-2018, 08:34 PM #1
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Fridge Run-times / Small Dual Battery Build
For all you fridge/freezer people… Have you metered the power to see the true amount consumed?
For the ARB 50, the spec sheet shows 7 amps as it’s max load, but it’s generally closer to 4-5 amps at fridge temps and can be lower (3.5 to 4 amps) after reaching temp. It also does not run 100% duty cycle (continuous) so whatever power its consuming needs to be averaged across its off-cycles. I think it’s worth mentioning that at 24 volts it’s about 15% more efficient than at 12.
Generally when I am camping it’s about half a day until the truck gets turned on again, I would like to build the smallest dual battery setup that would last about half a day… if I really needed more, I could supplement charge via alternator or solar.
Even for running this thing in the city for grocery shopping and errands the requirements for time would be even less. I generally turn it on right before I leave and it gets to temp by the time I need it...
How long do you guys generally run your fridges without throwing charge back into them?
Old 08-29-2018, 12:36 AM #2
Jeremy556's Avatar
Jeremy556's Avatar
For half a day, the stock battery will be fine.
It is all highly dependant upon contents, ambient temp, etc. but my Odyssey group 24 will keep my ARB at 31c half full of beer and water for about 2 days in 100f ambient temps in blazing sun. My old 31 would last about 3 days under the same conditions.
Day to day, I have a shore power cord I plug in that powers the 110v circuit of the ARB and a 12v charger for the battery that keeps the AGM happy.
Old 08-29-2018, 01:31 AM #3
Isais101 Isais101 is offline
Isais101 is on a distinguished road
I had the same question a few weeks ago that have a dometic 35 L and wanted to see what was an alternative to a dual battery did some research and came up with upgrading battery I ended up with a NorthStar 27f got it in the mail yesterday installing it last night hooked the fridge last night been connected 24 hours with SoCal temps and I just went to check if battery was dead by starting truck and nope started right up
Fridge Run-times / Small Dual Battery Build-54852a92-002a-4606-a1ff-b7c0507c63ea-jpg
Isais101 is offline   Reply With QuoteReply With Quote
Old 08-29-2018, 02:04 AM #4
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
You may have to test at home. You listed some variables. Are the groceries going into the cooler already cold? How often accessed? Ambient temp?
I run the freezer at 20deg F or colder. This makes the fridge area around 38deg F. Again, varies depending on what's inside. If it's going to be off for a bit I run the freezer at 0deg F. Also coat the freezer area with blue ice. This allows it to last a bit longer without power. I have an older ARB. I place a cheap wireless thermometer remote sensor inside.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 08-29-2018, 08:48 AM #5
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
1A is a good rule of thumb average for fridge with duty cycle factored in, most good fridges are 0.7-1A average
I run my fridge 24/7, i keep stuff for lunch and drinks and use it to go grocery shopping at lunch
I have not trended amperage (i want to get a shunt to monitor all this but they aren't cheap), but my cheap battery monitor trends voltage and i can see when the fridge turns on and off from the voltage change due to the load when the engine is off.
For half a day you really don't need a dual battery, but replacing your battery with an AGM is a good idea simply for the health of the battery (stock battery isn't intended to deep cycle). If this is a rare occasion thing the stock battery will be fine though. Running my fridge 24/7 I started seeing poor performance on my stock battery after about 6 months.
Just replace your battery with a 24m battery, it will fit in the stock location (stock is group 24) without any changes and a 24m battery will typically have about a 75Ah capacity which will more than meet your half day requirement (probably good for a day and a half in good conditions). You can get a voltage booster diode on ebay for about $15, that will help it charge properly
My 31m battery lasts about 3 days in good conditions (temps not too crazy, full fridge) and into day 2 in poor conditions (hot temps, half full fridge) on the highest voltage shutoff setting
jhguth is offline   Reply With QuoteReply With Quote
Old 08-29-2018, 08:50 AM #6
Also, I'm using this cheap wireless thermometer to monitor temps. I have one sensor in the fridge part, one on the little tray thing above the compressor, and it also monitors vehicle interior temps. It records the max and min temp so I can check if the fridge got too warm.
$18:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 08-29-2018, 09:00 AM #7
SlickTRD SlickTRD is offline
SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about
Did you need to do anything to make the 27F fit?
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
SlickTRD is offline   Reply With QuoteReply With Quote
Old 08-29-2018, 09:10 AM #8
31m is basically the same footprint as 27 just taller and 110ish Ah vs 90ish Ah. You might want to get a metal tray since they are longer than stock.
Old 08-29-2018, 11:01 AM #9
Tuc4R's Avatar
Tuc4R Tuc4R is offline
Tuc4R is on a distinguished road
Tuc4R's Avatar
You have to get a new battery tray. I got this one.
https://www.makariosrv.com/noco-grou...SABEgJuSfD_BwE
2018 TRD ORP W/KDSS & Sunroof - ADS C/O's and rear RR, TC UCA's, Icon 2' springs, SSO bumper, Smitty X20, Nitto RG, FX PRO wheels, AVID sliders, RCI Alum skids, Bussmann RTMR, Canvas backs, Accessorides remote start, Rago Molle’s, HID low's, LED high's, Morimoto XB fogs, Ceramic window tint, Ecotechne roof rack, ARB diff breather, Indel B TB51, Ellis shift knobs, Plastics Guy bump stops, ARB twin comp., Pedal Comm, X2 Power G27
Tuc4R is offline   Reply With QuoteReply With Quote
Old 08-29-2018, 11:05 AM #10
Tuc4R's Avatar
Tuc4R's Avatar
If you do go with an AGM, you will need to do some battery maintenance. The stock alternator will not charge an AGM battery all the way. You will need to charge it at home with a proper charger.
This is the one I got.
https://www.amazon.com/NOCO-G7200-Ul...+charger&psc=1
Old 08-29-2018, 11:08 AM #11
Thanks! Does the factory J-hook and battery tie down work with this tray or did you use the provided straps?
Old 08-29-2018, 11:28 AM #12
Tuc4R's Avatar
Tuc4R's Avatar
That I don't know yet, I just ordered it yesterday. lol I was just going to figure it out when it comes in.
Old 08-29-2018, 12:18 PM #13
Just a bigger battery tray even the stock j hooks work for this battery
And wires is plug a play
Old 08-29-2018, 12:21 PM #14
This are items I used for NorthStar 27f and 12v plug I installed in rear of truck
I ordered the battery from GP audio website I got the NorthStar 27f for $280 delivered to front door
Fridge Run-times / Small Dual Battery Build-c1e26edf-20b8-4f47-8349-4b55e61b9bea-jpg  Fridge Run-times / Small Dual Battery Build-9d58532d-72e5-41fe-a0cc-df5ab929409d-jpg
Old 08-29-2018, 02:36 PM #15
puckitpuck's Avatar
puckitpuck puckitpuck is offline
puckitpuck will become famous soon enough
puckitpuck's Avatar
What do you call that component next to the Aircomp? fuse tray? Electrical panel? I think I need that. Your seems very clean.
Your air comp is use for airlocker and tire inflation?
I got REDARC BCDC1225D in the box ready to install. I need to figure out the wiring, type and size of 2nd battery to connect with 100W solar panel and starter battery/alternator.
Planning to power Dometic 65 and other small stuffs.
IG @ BAJA4RN 2015 4runner TPE, Grey, 285/70/17 BFG KM3, Method 105 17x9 3.50" BS 6x139.7, Magnuson SC, FrontRunner Slimline II, ARB Summit front bumper, Bruteforce Rear, Safari Snorkel, Autohome Columbus RTT, Alu Cab Shadow Awning,Quick Pitch Ensuite, King Shocks OME 2.5", Dometic CFX 65W, REDARC Multi-Stage charger, 100W solar panel, 80ah 2nd AGM battery, BAMF sliders
puckitpuck is offline   Reply With QuoteReply With Quote
4th Gen V-8 Dual Battery Build SunPilot 4th Gen T4Rs 24 03-16-2023 11:26 AM
Yeti 400 to power fridge? alternative to dual battery e60ral 5th gen T4Rs 45 07-01-2019 06:46 PM
Portable "dual battery" for fridge Bumbo General Discussions 12 09-24-2018 12:03 PM
FS: Ironman Fridge and Dual Battery Kit $500/$150 - Austin, TX Landy For Sale: Non-T4R Items 2 02-10-2016 03:17 AM
mid dual battery build..stupid question.. theizzardking 3rd gen T4Rs 8 12-08-2012 10:53 PM
