08-31-2018, 10:10 AM
Real Name: Jeremy
Real Name: Jeremy
Installing a Gentex w/homelink on a 5th gen
one of the things I regretted after my purchase was not getting the homelink..my wife parks in the garage, but I still like to be able to open from my vehicle..came across this on Amazon for the '16-'18 Tacos. will it work on our rigs?
https://www.amazon.com/gp/product/B0...k_ql_qh_dp_hza
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
08-31-2018, 12:48 PM
It will fit fine. That one is pretty expensive, you can fins used ones on ebay a lot cheaper.
Gentex/Mito makes just about every rear view mirror out there, including OEM. There is only 2 different wiring connector types also.
The mount on the 4runner is a standard wedge puck style
2016 4Runner Limited
Reason: edit
08-31-2018, 02:16 PM
Yea check eBay, I bought one for $60 brand new. Wiring is pretty easy. ran the wires down the driver side pillar and tapped into an accessory wire or add-a-fuse to the fuse panel.
09-02-2018, 03:01 PM
Real Name: Jeremy
Real Name: Jeremy
was also looking at this..
https://www.cheapestfactoryparts.com...bC12Ni1nYXM%3D
I can get the overhead console that came factory for about $152 with the home link..
09-02-2018, 09:48 PM
Real Name: Todi
Real Name: Todi
Originally Posted by JAXJeremy
Description:
2014-18, 4wd, without sunroof, with homelink, gray, without offroad.
Does not work if you have off-road
2018 TRD OR
- SSO Full Rack; Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load – front, Performance Load – rear; M.O.R.E. aluminum full set skid plates; Artec aluminum gas tank skid; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; ReszFab flat sliders; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E;
09-03-2018, 10:27 AM
Real Name: Jeremy
Real Name: Jeremy
Originally Posted by TodiN
Description:
I've got an SR5 with just the plain 4wd..no offroad, so I think it should work.
09-03-2018, 11:25 AM
I have the OEM one in the console. No need to press and hold, just tap the button.
09-03-2018, 02:54 PM
Real Name: Todi
Real Name: Todi
Looks like it will, good luck
2018 TRD OR
09-03-2018, 03:25 PM
I just used a small piece of velcro to attach my opener to the side of the console. No extra cost, not attached to my visor and it works great.
09-04-2018, 08:41 AM
Real Name: Jeremy
Real Name: Jeremy
great suggestion..a lot less expensive that's for sure.
02-02-2023, 06:12 PM
i'm trying to do the same thing. can you tell me the amp and slots you used?
2016 4Runner Trail w/KDSS / Dobinsons 3/2" / Camburg UCAs/ KO2 275/7017 / Light Bar / Raptor Lights / Rockford Fosgate amp/ Rockford Fosgate P3 subwoofer / Thule 60" Aerobars
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
