Old 09-03-2018, 06:36 PM #1
Nick B Nick B is offline
Nick B is on a distinguished road
Replacing Antenna Base
The black rubber antenna base on my 4R is cracked . Anybody replace one of these ? Just wondering what’s involved ?
Thanks in advance .
Nick B is offline   Reply With QuoteReply With Quote
Old 12-11-2018, 03:04 PM #2
HerT4R's Avatar
HerT4R HerT4R is offline
HerT4R will become famous soon enough
HerT4R's Avatar
Thanks in advance .
reviving this! I just searched for a good while and found a whole lot of nothing.
There are a ton of people who break the stud off and leave threads in the piece, but like the OP my black PLASTIC threaded piece is broken. I cant even find a damn OEM PN let alone a writeup on how to get the thing off (if taking the fender liner out is required or not).
I have seen @harper7 pics and info on how he got into there. and that is was pretty terrible and that i may need to have replacement fender clips.
anybody have any information or a part number?
*** EDIT *** found OEM part number Toyota-86392-35040-Antenna-Ornament
Can this be installed WITHOUT having to remove the fender liner piece and breaking the clips?
4RUNHER Owner: October 2014-October 2020
SOLD 2010 MGM TE w/ KDSS SOLD
Consolidated Slider Info Thread :: 5th Gen Features/Models/Differences :: New member? Please read this.
HerT4R is offline   Reply With QuoteReply With Quote
Old 12-11-2018, 03:18 PM #3
rihavens's Avatar
rihavens rihavens is offline
rihavens is on a distinguished road
rihavens's Avatar
I am assuming that 2011 is the same as what you have. I installed mine, no problem. Unscrewed the antenna and used needle nose to break what was left of the old one. Slid it down and kind of twisted it back and forth while applying downward pressure until it was in place. Not sure of procedure, and I likely did it wrong.
rihavens is offline   Reply With QuoteReply With Quote
Old 06-26-2019, 12:26 PM #4
MAXISTYLES's Avatar
MAXISTYLES MAXISTYLES is offline
MAXISTYLES will become famous soon enough
MAXISTYLES's Avatar
Need install help
Has anyone else put this Ornament Antenna rubber piece on successfully? I tried pushing and twisting it on unsuccessfully. Maybe I'm just a weakling. I really don't want to pull the fender liner to do this.
MAXISTYLES is offline   Reply With QuoteReply With Quote
Old 06-26-2019, 12:42 PM #5
STX4Runner's Avatar
STX4Runner STX4Runner is offline
Real Name: Jonathan
STX4Runner has a spectacular aura about STX4Runner has a spectacular aura about
STX4Runner's Avatar
Real Name: Jonathan
I put a new one on a few months ago. It was a huge PITA. The piece did not want to fit in the space allotted. I eventually tore off the rubber lip on the interior at the bottom and installed with only the top interior rubber lip holding it to the fender. It's been fine since then.
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
STX4Runner is offline   Reply With QuoteReply With Quote
Old 06-26-2019, 03:35 PM #6
scrappyirishman scrappyirishman is offline
scrappyirishman is on a distinguished road
I tried to do this last winter. After a few fails I soaked it in near-boiling water first, then put some dish soap on the bottom before I pushed real hard and twisted the base slightly and it went in "most" of the way. I'm waiting for a real hot day here in Houston, hoping it will soften it up again, before I try to push it the rest of the way in.
I think STX4Runner may have the best idea, by just cutting off some of the extra lip on the bottom.
2010 SR5 - Magnetic Grey
Fiamm Horn / Thule Rack / Texas Off-Highway Vehicle Licensed
scrappyirishman is offline   Reply With QuoteReply With Quote
Old 06-26-2019, 11:12 PM #7
STX4Runner's Avatar
Real Name: Jonathan
STX4Runner's Avatar
Real Name: Jonathan
I tried that method too. Soaked it in HOT water, used soapy water to try and got it in, no luck.
Old 06-27-2019, 01:10 PM #8
MAXISTYLES's Avatar
MAXISTYLES's Avatar
Right Way
Looks like the right way of doing it is pulling the fender liner and removing the antenna base inside the fender is needed. I attached install instruction which say (a) install antenna ornament first. (c) Insert the fender antenna into the antenna ornament.
Replacing Antenna Base-antenna2-jpg
Old 09-08-2019, 02:11 PM #9
chester4Run chester4Run is offline
chester4Run is on a distinguished road
I took a similar approach, but removed the top lip and most of the side lips, just leaving the bottom one. This works perfectly. The seal looks tight and the antenna holds the top section very securely while the bottom lip secures the bottom section. Took five minutes.
2011 SR5 4wd
2004 SR5 4wd
1994 SR5 4wd (SOLD)
chester4Run is offline   Reply With QuoteReply With Quote
Old 04-24-2020, 10:15 AM #10
csteranko csteranko is offline
csteranko is on a distinguished road
Hey guys. This thread helped me out while replacing my antenna and antenna ornament yesterday, so I figured I should post another helpful tip. I recommend not removing the fender liner. I thought I was prepared with spare clips, but at least in my 2012, I would have had to remove/break clips behind at least one painted panel. Too much risk for me for an antenna repair. For me, it wasn't the top or bottom of the ornament that needed to be trimmed, but just the sides (the part that goes inside the panel of course). Applied dish soap around hole, heated a bowl of water for a minute and forty seconds and dropped ornament in to soften it up. Then it popped right in, nice and snug.
csteranko is offline   Reply With QuoteReply With Quote
Old 04-24-2020, 10:25 AM #11
While I was fixing the antenna ornament, I decided to replace the whip antenna. The whip is a tired look to begin with and the fact that half of the black paint had worn off didn't help. Instead of painting it, I replaced it with a Stubby Jr antenna, which I really like. My first non OEM part! It only took 8 years and 90,000 miles. As you can see in the first picture, the antenna ornament rubber got so stiff and brittle after 8 years that the front of it ripped off and flew away on the highway. Here is a before and after. The OEM part number that I used for the hood ornament was 86392-35040.
Replacing Antenna Base-antenna-before-jpg  Replacing Antenna Base-antenna-after-jpg
Old 04-25-2020, 11:26 PM #12
clin9383's Avatar
clin9383 clin9383 is offline
clin9383 is on a distinguished road
clin9383's Avatar
How's the reception?
1996 Limited - OME 881/906 w/comfort shox | Deckplate | Hayden 1678 | 265/75R16 Revos | Koyo A1998 bypassed | Husky liners | Optima R34 Red Top | '99 Cupholders | Rear diff breather mod | (Totaled)
2012 Limited - Husky liners | OPOR sliders | 30% Ceramic Huper Optik | AVS seamless | Odyssey 34R-1500T
clin9383 is offline   Reply With QuoteReply With Quote
Replacing head unit: 3 antenna input question & power antenna replacement question Rancho5 3rd gen T4Rs 14 08-24-2018 06:51 PM
Rusted antenna base bergeron37 3rd gen T4Rs 2 07-23-2013 11:49 AM
Replacing retractable antenna with.. normal antenna. Spencer 3rd gen T4Rs 2 08-25-2009 02:39 PM
Replacing Radio Antenna Wire jmrwd3 3rd gen T4Rs 1 01-03-2008 12:42 PM
