10-23-2018, 03:26 PM
#16
Originally Posted by 97BlackAckCL
Under the front passenger seat
I fished all the wires under the carpet too so it's nice and hidden
With the seat back you can't see it at all
Damn ok. My amps too big to fit under the seat. Do you know anywhere else it might be able to be hidden away?
10-23-2018, 03:48 PM
#17
Real Name: Chris
Real Name: Chris
Depends on how big, there's a good bit of room where the stock sub enclosure goes, but really depends on the amp size. I bought my amp with going under the seat in mind
10-23-2018, 04:07 PM
#18
This is exactly what I was looking for!
Do you have the part number to this JBL enclosure?
10-23-2018, 04:14 PM
#19
Real Name: Chris
Real Name: Chris
Sure do, it's 861500W120
10-23-2018, 04:34 PM
#20
Mines an AQ1200D which is the SQ1200.2. It's pretty big but not crazy big.
10-28-2018, 09:25 PM
#21
dang that enclosure isn't cheap, I was expecting more in the $200 range. My JL Audio 500/1 and 8w3 will have to wait
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
10-28-2018, 10:08 PM
#22
Do you think it would be possible to cut the 8” hole a little larger to squeeze a JL audio 10TW5 in the JBL enclosure?
2017 Limited 4runner / BFG All Terrain KO2 285/70/17 / 2.5" Front and 1.5" Rear Toytec Spacer Leveling Kit / Race Relation Wheels RR4 / JL Audio C2-350X/C2 690TX/C2 650x / JL Audio 8w3 in JBL Enclosure powered by JL 500/1 / Sound Dampened Interior / Gibson Dual Side Exit Catback
10-28-2018, 11:09 PM
#23
Real Name: Chris
Real Name: Chris
Originally Posted by Akkording
dang that enclosure isn't cheap, I was expecting more in the $200 range. My JL Audio 300/1 and 8w3 will have to wait
I believe that you can order the box without the subwoofer separately. I'm not sure since I got mine from a member on here.
Possibly, but I'm not sure. It's designed for an 8" so I'm not sure how much extra plastic you would need to cut but I would doubt it would work, especially with the depth issue. My 8w3v3 barely fit but it sounds amazing
10-28-2018, 11:25 PM
#24
My mistake, it’s actually a 10tw3. It’s the shallow mount sub so i was hoping itd be thinner than the 8w3. I have a digital design 8 inch sub but that magnet is far too large for the jbl enclosure.
10-29-2018, 12:04 PM
#25
Real Name: Chris
Real Name: Chris
It's hard to say, that enclosure is pretty tight, another 2" in diameter is asking a lot
I could try and measure for you if you'd like
10-29-2018, 03:11 PM
#26
Yeah I just took out the third row and checked out the enclosure space. I don't think it is going to work.... lol so I guess I will throw in a 8w3 in there as well. Did you run the 8w3 with the stock JBL amp at all? This is definitely a noob question but I see that there are 2 harnesses in the JBL sub and the 8w3 only has one positive and one negative terminal. Am I supposed to combine the two negatives and positives together from the harnesses and hook them up to the 8w3?
10-29-2018, 03:25 PM
#27
Real Name: Chris
Real Name: Chris
I didn't because my truck didn't come with the JBL system, I added the sub enclosure and amp to my stock "premium" radio
For the stock amp yes, I would combine the 2 positive and negative connections together to power the 8w3
10-29-2018, 03:44 PM
#28
I'm going to amazon prime an 8w3, maybe some rear door speakers and run it off the stock amp for awhile to see how it is. I have a 500/1 that I will throw in eventually but do not want to if i don't have to. Thank you very much for all of your help!!
10-30-2018, 09:15 AM
#29
Real Name: Chris
Real Name: Chris
No problem, happy to help
10-30-2018, 10:48 AM
#30
Please post pics when you install the 8w3 on your JBL system. I've been wanting to do this for a while but have been waiting for someone else to be the guinea pig.
2013 LTD 4x4 Magnetic Gray; Weathertech liners, Airlift1000, Camelback Metal Gear roof rack, Interior LEDs, trail rocker panels, Shrockworks step sliders, TRD Pro wheels, Cooper Discoverer AT3s 255/75R17
