10-31-2018, 06:40 PM
#31
Originally Posted by Neauxla
Please post pics when you install the 8w3 on your JBL system. I've been wanting to do this for a while but have been waiting for someone else to be the guinea pig.
I did not take pictures but I followed the exact same steps that 97BlackAckCL posted previously. The only difference being the wiring. The stock subwoofer has 2 harnesses in the enclosure. I combined the two positive wires with butt connectors to speaker wire and did the same with the negative. The positive wires were yellow and green. The negatives were black and purple.
I installed the 8w3 today in the stock JBL enclosure and it sounds great but it is definitely underpowered. I’m going to hook up a JL slasher 500/1 this weekend. Hopefully I can get a clean signal from tapping into the rear sub.
2017 Limited 4runner / BFG All Terrain KO2 285/70/17 / 2.5" Front and 1.5" Rear Toytec Spacer Leveling Kit / Race Relation Wheels RR4 / JL Audio C2-350X/C2 690TX/C2 650x / JL Audio 8w3 in JBL Enclosure powered by JL 500/1 / Sound Dampened Interior / Gibson Dual Side Exit Catback
10-31-2018, 09:38 PM
#32
does it still sound better than stock underpowered? If you had to go with stock or JL with no extra amp, what would you do?
2013 LTD 4x4 Magnetic Gray; Weathertech liners, Airlift1000, Camelback Metal Gear roof rack, Interior LEDs, trail rocker panels, Shrockworks step sliders, TRD Pro wheels, Cooper Discoverer AT3s 255/75R17
11-01-2018, 09:38 AM
#33
Real Name: Chris
Real Name: Chris
If you need a line output converter designed for the stock amp let me know, I have one sitting in my closet that I never used
11-01-2018, 10:35 AM
#34
What's this do?
11-01-2018, 10:43 AM
#35
Real Name: Chris
Real Name: Chris
What's this do?
Cleans up the signal from the stock amp and converts it to a signal to the amp with RCA's, I bought it for my 4th gen and never used it
11-01-2018, 06:26 PM
#36
Thank you for offering!. I have an lc6i but I don’t think I want to use that because it takes up a lot of space. So I needed up ordering a cheap scosche LOC-80 and will try that out. I also might splice a pair of RCA’s open and go directly to the amp. I’m just trying to find the cleanest signal possible.
I think the stock jbl with sound dampening might provide a little bit more bass but idk the only bass I really hear are from the front door speakers right now lol hopefully that changes when I hook up an amp tomorrow evening
11-01-2018, 11:35 PM
#37
those 6x9s really putting out some bass?
11-02-2018, 03:05 AM
#38
Nice write up. In queue for next project.
11-02-2018, 09:00 AM
#39
The 6x9’s in the doors are unreal. The bass is very clean and low. Sounds so much better than topping out the stock door speakers every time the bass hits.
11-02-2018, 11:42 AM
#40
I thought you had just replaced the fronts, but your signature shows the C2 650x as well. Did you put those in your rear doors and the hatch? Do they need an adapter kit?
I see that the JL audios are 4ohm. I thought our system was a 2.3 ohm system. Do you have to crank the volume to get the same volume out of the 4ohm speakers? I was leaning towards the JBL GTOs b/c they are 3 ohm. (already bought the GTO329s and they been sitting in box for over a year)
11-06-2018, 11:55 AM
#41
How's it sound w/ the new amp? What amp did you go with and where did you mount it? Did you take pics?
11-06-2018, 02:29 PM
#42
Sounds great with the amp addition. I did not take pictures but I used velcro to mount the amp underneath the driver seat as many other individuals have done the same. I am using a JL audio 500/1 amp to power the sub.
11-09-2018, 03:26 PM
#43
Do you think removing the seat and installing the sub and putting it all back together can be done in 1 day?
I’ve already ran my wires and just have a sub in a box in the cargo area. Thanks to this write up, I have a new mod bug! 😁
Took me 4 days, Friday - Monday but I took my time and was battling the heat and sun in my driveway. If I would have been able to use my garage I would have probably gotten it done in 2-3 days, but the heat was so oppressive I was only able to do a couple hours at a time, and probably lost 9-10 lbs of sweat in 4 days, but all in all it was definitely worth it!
I don't know what the cubic volume of the enclosure is, sorry
Click to see my art feed—> Instagram.com/Aus10m
11-09-2018, 04:02 PM
#44
Real Name: Chris
Real Name: Chris
Absolutely, I spent 3 days but it was 95 degrees and incredibly hot and humid and I was working in direct sun in my driveway. I also had to rip out my stereo and run all the wires, etc. If the wiring and everything is there, removing the seat and panels shouldn't take more than a few hours. Just take your time to ensure that you don't break any clips or lose any screws.
11-11-2018, 09:49 AM
#45
Thank you for the response! Ill probably go to junk yards to find the box so it may be a while before I can do it.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
