Old 09-07-2018, 12:27 PM #1
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
Lower Control Arm & Tie Rod End Replacement
Well it looks like the hard off road miles and extra weight have finally taken their toll on my front suspension. At 110,000 miles my driver side lower ball joint and outer tie rod are leaking grease with popping and clunking coming from the front. As preventative maintenance I'm also going to be replacing the passenger side components too.
A few questions to those who have gone through this procedure:
1. Did the OEM lower control arms come with bushings pressed in? They look like a separate line item however I've heard otherwise.
2. Did you have problems removing the cam bolts? I've had my truck aligned twice this year and the tech never said they were seized. Hoping that I won't have to cut them out but planning to anyways.
3. Any tips on making this job easier?
If it helps others I can also do a writeup of the procedure as I suspect most of you who take your trucks on dirt will probably face this around the same mileage.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 09-07-2018, 01:05 PM #2
Lucky Runner Lucky Runner is offline
Lucky Runner is on a distinguished road
1) come with bushing
2) I had some problems - but before that I never twisted them. I think you will not have problems
Lucky Runner is offline   Reply With QuoteReply With Quote
Old 09-07-2018, 02:26 PM #3
WhiteBoomer04's Avatar
WhiteBoomer04 WhiteBoomer04 is offline
WhiteBoomer04 will become famous soon enough
Mostly a straightforward job. Replace my LCAs twice now.
The ball joints are pressed in and some people have attempted (some successfully) to have them pressed out and new ones pressed in but for the hassle, new stock LCA's aren't too expensive.
The bushing are also pressed in. I have seen threads of people trying to remove them. Usually burning them out is the easiest way if you don't have access to a decent press. Again, new LCA's are pretty expensive compared to the hassle..
WD40 the cam bolts for a few days prior should ensure them come out easily. I did not have a problem with these however.
Tie rods are an easy maintenance job.
If you can't find info on these issues, check toyota120.com. I'm fairly certain there are threads there on the process.
Mark
04 V8 SE, RST Twin stick conversion. 4x4 Labs rear bumper, SW Sliders & Bullbar, ARB Locked F&R, 5.39’s, Smittybilt 10,000lb winch, 1.5 4Crawler BL, Flowmaster, CB and 2m/70cm Ham, Sat. Radio, CO2 system, Lightforce, African Outback Rack, Budbuilt, Front Runner RTT. Rock Solid Toys Solid axles, Atlas Crawl Case, 40" Cooper STT Pro's on Fuel Anza D116 beadlocks, 5:38 gear set, ADS Coilovers.
WhiteBoomer04 is offline   Reply With QuoteReply With Quote
Old 09-07-2018, 04:07 PM #4
DesertCanyons's Avatar
DesertCanyons DesertCanyons is offline
Real Name: Dave
DesertCanyons will become famous soon enough
Real Name: Dave
Total Chaos and Dirt King
Total Chaos and Dirt King both make lower control arms for the 4Runner. Have you looked at those? Some of them provide mounts for a secondary shock. I think they both offer an option that's compatible with KDSS. The bushings and ball joints are serviceable on these.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
DesertCanyons is offline   Reply With QuoteReply With Quote
Old 09-07-2018, 04:29 PM #5
Xtremluck's Avatar
Xtremluck's Avatar
I was considering going that route but can't justify the extra cost (4xOEM) and I'm not so hot about dealing with Uniballs. My upper UCAs are already howling after only a year of use.
Old 09-18-2018, 10:11 AM #6
Xtremluck's Avatar
Xtremluck's Avatar
So I completed this job over the weekend and it was pretty straight forward albeit time consuming. My cam bolts came off easily (Thank California truck!) but they were definitely rusted. I had a hell of a hard time separating the lower ball joint from the steering knuckle attachment. Even with a ball joint separator it took a lot of time and PB Blaster.
Pro Tip: When making CAM marks make sure they are super clear. When I put anti seize on my driver side cam bolts it obscured my markings. So I had to do a "best guess" on positioning. Lets just say my truck didn't drive very straight after I was done Luckily the alignment shop was right next door.
Anyways, here are the steps I followed in case someone else needs to do this in the future (Follow all of this at your own risk):
Lower Control Arm Removal
1.Remove Wheel
2.Remove lower shock bolt
3.Remove (2) bolts holding the lower A-Arm sub assembly to steering knuckle
4.Place match marks on camber adjustment cam
5.Place match marks on toe adjustment cam
6.Remove toe/camber adjustment bolts and plates
7.Remove lower ball joint castle nut
8.Using a ball joint separator remove the lower ball joint attachment
Lower Control Arm Installation
1.Temporarily install the lower suspension arm with toe and camber hardware aligning match marks
2.Install the front lower ball joint attachment with nut and cotter pin (103 ft lb torque)
3.Connect the front lower ball joint attachment with two bolts (118ft lb torque)
4.Temporary install the lower shock bolt
5.Install Wheel (83 ft lb torque)
6.Lower truck and stabilize suspension
7.Tighten the toe and camber bolts (129 ft lb torque)
8.Tighten the lower shock bolt (70 ft lb torque)
9.Get a wheel alignment
Tie Rod End Removal & Installation
1.Disconnect tie rod end castle nut from steering knuckle using a ball joint separator
2.Put match marks on tie rod end and steering rack end
3.Loosen tie rod end nut
4.Remove tie rod end (Count how many rotations to remove)
5.Connect new tie rod end (install using the # of rotations from step 4)
6.Connect new tie rod end into steering knuckle (67 ft lb torque)
7.Install Cotter Pin
Old 03-15-2024, 01:45 PM #7
jvan08 jvan08 is offline
jvan08 is on a distinguished road
New to the 4runner.
Question on this.
I have a 2014 4runner sr5 2wd, w/o the kdss (not sure that's even an option on the 2wd sr5)
But looking at the parts online. On rockauto I found lower control arms by Dorman w/o KDSS and all of the upper control arms just state "upper control arm". Do you have to worry about different upper control arms with/without KDSS? Or does it not matter with the uppers?
Just want to make sure, although I have had good luck with rockauto with other vehicles in the past, their return policy has always been a pain in the ***.
jvan08 is offline   Reply With QuoteReply With Quote
Old 03-17-2024, 11:04 AM #8
T4R_Canuck T4R_Canuck is offline
T4R_Canuck has a spectacular aura about T4R_Canuck has a spectacular aura about
Originally Posted by jvan08 View Post
New to the 4runner.
Question on this.
Upper control arms are universal with or without KDSS.
2014 Trail Premium w/ KDSS. OME 3" Lift w/ medium springs, Greenlane Diff Drop, SPC UCA, LT285/70R17 Falken Wildpeak AT3W E Load, Level 8 MK6 17" x 8, 0 offset, Element by RA Automotive Engine Skid, Prinsu Full Length No Drill Rack, ICS Dash mount.
T4R_Canuck is offline   Reply With QuoteReply With Quote
Lower Control Arm replacement experience hrod79 5th gen T4Rs 20 02-06-2024 09:53 PM
Rear Lower Control Arm Bushing Replacement mtbtim 3rd gen T4Rs 77 08-08-2019 01:50 PM
Replacement Lower Control Arm? Tigertater 5th gen T4Rs 1 07-17-2017 11:11 AM
2003 Lower Control Arm/Lower Ball Joint replacement Wahoo96 4th Gen T4Rs 5 01-30-2015 02:16 PM
99 4runner lower control arm replacement Imperial4runner Engines / Suspension / Wheels / Tires / Audio / Accessories 2 01-05-2013 10:11 PM
