09-10-2018, 12:58 PM
#31
The reason I ask is that I've got a car with over 300k with the original studs. I guarantee that with all the tires I've bought they have been overtorqued more than I'd like to think about and a wheel has never fallen off. I agree stretching studs weakens them but I don't understand why these are failing withing 100k
Originally Posted by honda250xtitan
I'd argue they are better quality then the OEM studs. The front OEM studs are incredibly short too for whatever reason. They (spidertrax studs) just saw a lot more stress due to shops using impacts on those studs when rotating the tires, doing the recent brake job, etc.
Don't use impacts, use a torque wrench. Check the torque periodically.
2016 4runner SR5 Premium
2007 4runner Limited
1998 Camry (almost 300,000 miles)
09-10-2018, 01:25 PM
#32
Real Name: Todi
Real Name: Todi
Originally Posted by mrblah
arp lexus tire studs but prepare too pay a shiny penny.
I don't think upgrading your fasteners will prevent failure (i.e. overtorquing)
These: https://www.amazon.com/ARP-1007715-W.../dp/B001O09TBQ ?
2018 TRD OR
- SSO Full Rack; Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load – front, Performance Load – rear; M.O.R.E. aluminum full set skid plates; Artec aluminum gas tank skid; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; ReszFab flat sliders; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E;
09-10-2018, 01:27 PM
#33
Real Name: Nate
Real Name: Nate
User error or not, these just seem unsafe to me personally. They specifically say "OFF-ROAD USE ONLY" in their instructions as a disclaimer. I'd say if you want to widen your stance just get wheels that have them like SCS, Fuel, XD, etc..
2016 Quicksand TRDP, Eibach 2.0 PRO Kit, 285/70/17 Falken Wildpeak MT, 17x9 SCS F5, Prinsu Roof Rack, Canvas Back, Weathertech
Build: http://www.toyota-4runner.org/5th-ge...ld-hawaii.html
Filmmaker: https://www.youtube.com/user/freedomriding Instagram: https://www.instagram.com/freedomedia/[/SIZE][/SIZE]
09-10-2018, 01:31 PM
#34
Originally Posted by mtnbiker49
Likely that the mechanic that did your brakes went full out with an impact and ended up stretching them. Just took the right amount of force to shear the lugs. Take the others off immediately.
And always tell your mechanic to fasten the lugnuts on spacers BY HAND and with a torque wrench.
I am sure they will listen to you...especially the stealership lol.
Bottom line: If you do not torque to spec, it is possible the studs will shear off and cause such a failure. Does not matter if the studs are grade 8/10.9/OEM/ARP etc...
2017 TRDORP White | 275 KO2 on Stock Rims | Stock Stereo with JBL GX302/GTO638/938, Kenwood KSC-SW11 | DDM 35W HID Ultra | Shrockworks Step Sliders | FR 5100s @1.75 RR Daystar 1.5 | Victory 4x4 Rack
09-10-2018, 01:41 PM
#35
Originally Posted by decker1
True but the offset doesnt quote give you the push that spacers do. I have -10 offset on these and they dont stick out nearly as much But not worth it after this. Is there a better way to push out the wheels? New UCAs maybe?
If you want to poke out more, get wheels with a larger negative offset, as suggested, SCS F5s come in -38 for 17" wheels. They actually seem to be in stock right now too.
Do you need that poke for clearance issues? I'm not having any problems with -10 offsets and 285 MTs.
2016 Trail + KDSS | Kings 2.5 w. Adj + Ext Travel Front & Rear - JBA High Caster UCA - Icon 3" "Overland" Springs - Proline 4x4 Rear Elite Dual Swingout Bumper - Demello Offroad X-Wing Sliders - SCS Ray 10 - Falken Wildpeak MT01 285/70/17 - Dirty Pants
09-10-2018, 01:48 PM
#36
Real Name: Eric
Real Name: Eric
Yep. Get new wheels that have the desired offset, without the spacers. Not the cheapest route, but definitely the best. Keep in mind that with more offset comes more leverage on suspension parts, and addt'l stress/wear that goes with.
09-10-2018, 02:10 PM
#37
all the suggestions for new/different/proper wheels are great, but it might not prevent this in the future. this was a case of over/under torqued lug
nuts.
that can still happen with just wheels...
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
09-10-2018, 02:20 PM
#38
Real Name: Todi
Real Name: Todi
This is what you have: https://parts.freemantoyota.com/scs-...17?parent=1019 ?
2018 TRD OR
09-10-2018, 02:38 PM
#39
Originally Posted by TodiN
Who knew Toyota sells them....
But yes, they are SCS Ray 10 Brushed Gold. Order from the source.
https://www.stealthcustomseries.com/products/ray10
09-10-2018, 02:53 PM
#40
IN SUPPORT OF SPACERS
Just a reference point, but I use OEM studs, Spidertrax spacers and studs and wheel with 37's pretty aggressively, for past 1.5yrs. Before that I had 35's for 2 years with spacers. No failures (knock on wood). It's a daily driver too.
HOWEVER
Notwithstanding, I do all lug nut tightening myself even after a shop has done a balance or tire change. I probably check my lug nuts every two months. I don't particularly like spacers. I'm going to 40's and solid axle next and will be happy with no more spacers. I admit to feeling a little uneasy especially when up on three (occasionally two) wheels when in the rocks. I'd never jump my truck (at all) but even less so when using spacers.
Mark
04 V8 SE, RST Twin stick conversion. 4x4 Labs rear bumper, SW Sliders & Bullbar, ARB Locked F&R, 5.39’s, Smittybilt 10,000lb winch, 1.5 4Crawler BL, Flowmaster, CB and 2m/70cm Ham, Sat. Radio, CO2 system, Lightforce, African Outback Rack, Budbuilt, Front Runner RTT. Rock Solid Toys Solid axles, Atlas Crawl Case, 40" Cooper STT Pro's on Fuel Anza D116 beadlocks, 5:38 gear set, ADS Coilovers.
09-10-2018, 03:47 PM
#41
Real Name: Paul
Real Name: Paul
I wound up removing my spacers because of a shimmy problem but also because the TRD wheels really no longer needed the look but primarily the shimmy. I rotated the spacers once and still a steering wheel shake. I had the same spacers on my Gen4 too but never slept too well with them on. I loved the look that that was it.
2016 Trail MGM. P265 70/17 Falken Wildpeak AT3W. Matte Black TRD Wheels. Leveled with 2" spacer. Heated Front Seats. All LED interior. Mud flaps deleted. TRD Air & Oil Filter. TRD Oil Cap. FJC Shifter. Subaru Kicker tweeters. Hikari LED Low Beam. Cougar Motor LED DRL/High beam. Hood "scoop" and lower door wrap.
2006 SR5 4WD V6 - Owned from July 2009 with 38,200 miles to March 2017 with 150,100 miles.
09-10-2018, 09:03 PM
#42
Toyota OEM lugs can fail with a pneumatic wrench..happened to my buddy b/c he was a moron and wanted to use his new impact gun, and his front passenger side lost 5 out of 6 lugs on the freeway. He wasn't running spacers.
As for someone who says find the right rims...
Tell me where I can find 17x8.5 and 17x9's with a -40 offset rims that don't look like they come from the douche bag catalog.
I only know of one set of rims that I would buy (SCS f5 -38) that doesn't scream douchebag, and good luck trying to get a set b4 they sell out.
Sometimes, you have to run spacers........
I just tell people if you run spacers do your due diligence, and be careful.
I"ve run spacers on all my vehicles, from stances 350z's to tundras, and now my 4runner.
09-10-2018, 11:41 PM
#43
Offset doesnt quite* sorry this mechanical keyboard takes getting used too.
Interesting, for some reason I thought the widest you could go is -12mm.
I may check out those SCS wheels. Thanks!
What? lol
1.25" = 32mm...SO 32 +10=42. to make your stance the same you need a -40mm or so on a new set of wheels. Assuming all other variables don't change.
SCS has the F5 in a -38 offset.
2014 Toyota 4Runner Trail 4WD - Icon Stage 1 at 1.5" Rear, 2" Front, 1.25" Spidertrax, Coverking Ballstic Tactical Seat Covers, WeatherTech Floor Liners, Raingler Cargo Net, Green LED Bulb door mod, Gobi Stealth Rack w/ Ladder, Yaesu FT2900 Ham Radio w/ 4ft Magnetic Antenna
Build Thread
09-11-2018, 12:10 AM
#44
the more negative you go, the bigger the arc the tire swings...so you need more sawzall skills or smaller tire.
09-11-2018, 01:12 AM
#45
Rule of thumb I follow is when I'm running spacers (which-ever brand) I have always upgraded wheel lug studs to ARP. Studs are usually the weak point when adding spacers. upgraded studs should be a must when running spacers .5" or more. BUT yet again, why go spacers if choosing proper offseted wheels would of been a much better choice, unless owner is planning to use OEM wheels. Sucks for those who had the studs snap.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
