10-26-2018, 11:42 AM
#76
I read the first few pages and what I gathered, since i'm in the market for some spacers, is that you need red loctite on the nuts that secure the spacer to the hub. And they should be torqued to the specs in the instructions. How often should they be checked?
10-26-2018, 12:09 PM
#77
if you use Loctite, do not re-torque them. you will break the Loctite, and then you risk them coming loose.
ive done it both ways, with Loctite, and without. doing it without means re-torqueing them. I do it 3 times. with 10-20 miles between each time.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
10-26-2018, 02:00 PM
#78
This thread is misleading, I've run spacers since I started driving on the road, on track cars and now my 4x4 (usually hit up off road parks etc) and drive all over the states. I also work on my own vehicles, my first Toyota service they cross threaded my skid plate bolts and I never went back, gave them once chance and they screwed up quite literally.
Never assume that your run of the mill tire shop has a clue what they are doing, some car dealer employees don't nor do they care. When I have tires changed I watch them and tell them what I want them to do after all I'm a paying customer.
In all my years of modifying cars the saying 'Ignorance is bliss' is everyones downfall, some guy on IG dropped 5k on a SC and then took his truck for a $20 oil change and 5miles later it dumped oil all over the road. Blows my mind
bit of a mini rant lol!
I used to go fast round corners....
10-26-2018, 03:06 PM
#79
Real Name: Todi
Real Name: Todi
Per installation instructions, you need to torque the nuts to 90 then, after 50-60 miles, set the torque wrench to 80 and check if the nuts are moving - you need to use red loctite. If the nuts are moving you have to re-do it.
2018 TRD OR
- SSO Full Rack; Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load – front, Performance Load – rear; M.O.R.E. aluminum full set skid plates; Artec aluminum gas tank skid; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; ReszFab flat sliders; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E;
10-26-2018, 05:14 PM
#80
10-26-2018, 05:36 PM
#81
Wait wait wait...while this makes sense to me, Spidertrax's instructions very clearly state to use the included loctite on the initial install, and then re-check them with a torque wrench set slightly lower after X amount of miles.
Are they saying to check with the lower torque settings so you don't break the loctite?
2004 Sport Edition V8. 3" OME lift. 5th Gen Brakes. 285/70 Duratracs. JBA UCAs. SCS Ray10s. DT Headers.
1997 4-Runner Limited w/ factory locker. Totaled in February 2018. Still miss it.
10-26-2018, 06:54 PM
#82
I would assume so. I have never seen those instructions. but yes, you don't want to break the Loctite loose once it has set.
the only ones I have seen I mentioned above. either use Loctite, torque them, and don't touch them again, or don't use it, and re-torque several times.
I have used both of these methods with great results.
10-26-2018, 07:00 PM
#83
Roger that. I just had a Hunter Road Force balance done at the dealership (with great results for some pesky Duratrac vibrations) but that was the first time someone other than me touched my wheels since I installed spidertrax in the spring. Guess I'm going to be re-installing them this weekend. Hah.
10-26-2018, 07:31 PM
#84
A little dab of paint or nail polish on critical fasteners will let you see at a glance if something has moved.
08-21-2019, 01:35 PM
#85
Originally Posted by Snackie
You picked a fine time to leave me loose wheel.......
"but now them spacers don't seem like a deal...
You picked a fine time to leave me loose wheel"
thought i'd help out....
2018 SR5 Premium - Eibach Pro Truck Lift Kit - TRD Wheels - Falken Wildpeak AT/3 - Tyger Armor Step Bars - Clear Bra - Kenwood DMX706s head unit - PowerBass 6.5" coaxial & 6x9" component speakers (tweeters replaced by JBL 3.5" coax) - Kenwood Excelon 5 Channel Amp - Pioneer 12" Shallow Mount Subwoofer - RAV4 Convex Mirrors - LED Headlights - Lexus LED Fog Lights (clones)
08-21-2019, 08:48 PM
#86
I used extended reach nuts, loc-tite and then witness marks on all of them......I just look at the nut and stud when the wheel is off and can see if any of them have moved. And in 40K not one HAS!
08-21-2019, 11:20 PM
#87
what about these spacers? lol
YouTube
08-22-2019, 07:31 AM
#88
i had my spacers on for 4 years, zero issues. They also see some pretty harsh winter and lots a salt (not sure if it matters).
Taking them off actually was kind of a PITA due to the corrosion.
here you go, even when you spend all that money on a RWB conversion... you still get them spacers!
Jealousy is ugly... Don't be ugly.
Tirdy5's w/ -70 F5's
08-22-2019, 09:37 AM
#89
For the money you kids spend on tire shops and stealerships to do your work, invest in a good floor jack and a really good torque wrench. A spot of logic and the ability to read instructions can go a long way. Spidertrax has been selling a lot of wheel spacers for a long time, I'm pretty sure the red loctite that comes in the box isn't for weight balance during shipping. Use it, torque to 90, 50 miles re-torque at 80, another 100 miles, check it again. If it is loose at all...even 1 loose nut, go back to step #1 and start again.
Carry on.
2016 Trail Premium Magnetic Grey, Toytec Boss 3" HD lift, Yokohamas on Walker Evans Legends, Spidertrax, 285/70 17, Victory4x4 Stuff, Baja Designs and some KC Cyclones, SwitchPros/Powertrays, Rig'd Swing, Black Rifle Coffee stains in the cup holders.
J. Branson
"What you do in life....echoes in Eternity"
08-22-2019, 11:25 AM
#90
Okay, if I've got the money for a custom classic 911, I've got the money to have the axles properly custom built for the stance. No ****ing way would I stack wheel spacers like that. Hopefully they're just doing a mock-up or being funny.
Voodoo Blue 2020 Tacoma TRD Off Road
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
