03-25-2020, 11:38 AM
Frame Condition from Factory
Has anyone noticed small patches of frame that appear to have missed being coated/painted? It is mostly along welds. For reference, the truck has 700 miles on it. I bought it new a few weeks ago.
I went to spray down the frame with CRC Corrosion Inhibitor, and was pretty surprised to see spots like the following:
Does anyone know if that's normal? Would you be concerned?
03-25-2020, 11:48 AM
Real Name: Sparky
Real Name: Sparky
Looks like Toyota hired the same drunk FCA MFers that did the welds on the new Wranglers.
That's a real sloppy weld and slag, but if you take it in you'll be told it's "to spec" since everything seems to be holding together.
All that surface rust is nothing to worry about, but looks like ass compared to the welds on my 2013... which have survived six and a half CO winters and salt.
Old and (c)rusty.
03-25-2020, 01:26 PM
I noticed a handful of these small rust spots along the frame on my 17 Pro.
Any one w/ advice on how to DIY treat these spots, et al so they don't get worse? Or is this something best left to an undercarriage coating specialist?
03-25-2020, 01:37 PM
Use a wire brush to remove what you can, and spray over it with rust inhibiting paint or fluid film.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
03-25-2020, 02:01 PM
Banned
Real Name: Mark
Banned
Real Name: Mark
I had those weld rust spots almost since day one on my 2018 ORP when I got it over 2 years ago. Whenever I’m under the truck doing any maintenance and see one I brush it off with a wire brush, then clean it up with a toothbrush and solvent like Coleman fuel, then isopropyl alcohol, then spray it with black enamel. I supposed you could use some spray rust reformer, but this works for me in a mild climate and no road salt. Over time you’ll get scrapes and rock dings that expose bare metal, and rust will form. Just touch them up whenever you see it.
03-25-2020, 04:39 PM
Dang, well I guess I'm glad I'm not the only one? ¯\_(ツ)_/¯
I'm also glad I thought to spray on the CRC Rust Inhibitor right away. Hoping that'll last a good while, and won't be a 2x yearly maintenance item like I was dealing with using Fluid Film (still great stuff, though!).
03-25-2020, 05:10 PM
Real Name: Ron
Real Name: Ron
Keep that picture or take another that shows a lot more of your frame because living in the Midwest it will be the last time it looks that good, unfortunately!
When I look at for sale rigs from California and frame pictures are included I can only drool at 10-12-15 year old frames that have virtually zero rust!
03-25-2020, 08:38 PM
Lol, right? I’m going to do everything I can to keep it in shape. But I know it’ll eventually succumb to the Midwest winters :/
03-26-2020, 08:50 AM
Real Name: Mark
Real Name: Mark
The welding process drives carbon, silicone, etc. to the surface of the weld. Paint, e-coat, etc. does not stick very well on those materials. Those small spots where the paint is missing is normal and you will see that on almost any vehicle. Even where the paint is still covering, the adhesion may not be all that great.
Also, there were no drunk welders welding on your vehicle. It's all done by robots short of an occasional repair weld. For frame welds, yours look fine. They are on seam and seem to have good penetration. The previously mentioned FCA weld fiasco was due to poor fixturing/robotic weld programming and an overall lack of quality control. This was the kind of crap several JL owners had to put up with. Welds with no penetration and almost completely missing the target.
Current: 2004 Land Cruiser Thundercloud Metallic
Former: 2020 ORP Silver. BFG AT KO2s, TRD Skid Plate, added Rear Sliding Deck, Pro LED fogs, Infinity REF-3032CFX dash speakers.
In Between: 2020 Jeep Wrangler Unlimited Rubicon with almost all options. Got tired of worrying about it disintegrating and ending up setting at the dealer for weeks and months.
Former: 2010 TE Silver w/ C4 Fab Rock Sliders, TRD skid plate, ECGS bushing upgrade, Bilstein 5100s, and BFG AT KO2 tires.
03-26-2020, 09:02 AM
Originally Posted by 00Sebby
The welding process drives carbon, silicone, etc. to the surface of the weld. Paint, e-coat, etc. does not stick very well on welds. Those small spots where the paint is missing is normal and you will see that on almost any vehicle. Even where the paint is still covering, the adhesion may not be all that great.
Oh wow, that’s scary on the JLs!
But that’s good to know about the welds being fine! And interesting as to why it happens...had no idea!
Thanks!
03-27-2020, 11:44 AM
Originally Posted by 00sebby
this was the kind of crap several jl owners had to put up with. Welds with no penetration and almost completely missing the target.
wow!!!
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
