Old 09-11-2018, 03:47 AM #46
HoustonT4R's Avatar
HoustonT4R HoustonT4R is offline
Real Name: M.N.G
HoustonT4R is on a distinguished road
HoustonT4R's Avatar
Real Name: M.N.G
Does this mean take the spacers off?!?
Engineer by day.
Explorer by night.
HoustonT4R is offline   Reply With QuoteReply With Quote
Old 09-11-2018, 07:40 AM #47
chester4Run chester4Run is offline
chester4Run is on a distinguished road
I take this a reminder to make sure your spacers are properly installed. Spacers are not inherently dangerous in my opinion and experience. There are many vehicles heavier than the 4runner using them safely. If you're into engineering (or want to be) there's a decent paper analyzing them here: https://www.ijert.org/download/16292...f-wheel-spacer If you don't want to dig through the math, read the intro and conclusion.
There are a few other bolts holding your wheels on too. Tire rotations are a good time to check them all, at least visually if not with a wrench. (those two 19mm bolts at the bottom of the knuckle, the four hub/bearing bolts, UCA, sway bar links, etc.
When you allow someone to work on your car, you really are putting your life in their hands to some extent. Do you use the cheapest mechanic you can find, or get to know/trust somebody? I'm not sure whether any state inspections do a decent job checking these things either. The ones I've had experience with seemed more focused on collecting the fee than vehicle safety.
Anyway, off soapbox. Happy Tuesday.
2011 SR5 4wd
2004 SR5 4wd
1994 SR5 4wd (SOLD)
chester4Run is offline   Reply With QuoteReply With Quote
Old 09-11-2018, 07:54 AM #48
HoustonT4R's Avatar
Real Name: M.N.G
HoustonT4R's Avatar
Real Name: M.N.G
At the end of the day, is all this worth it for just looks?
Engineer by day.
Explorer by night.
Old 09-11-2018, 07:54 AM #49
tackleberry1145 tackleberry1145 is offline
tackleberry1145 is on a distinguished road
Originally Posted by DeepSea View Post
User error or not, these just seem unsafe to me personally. They specifically say "OFF-ROAD USE ONLY" in their instructions as a disclaimer. I'd say if you want to widen your stance just get wheels that have them like SCS, Fuel, XD, etc..
LoL. Pretty much every aftermarket accessory you put on your vehicle has that imprinted on it somewhere.
old ride: 2014 Trail, Bilstein/Toytec lift, JBA UCAs, 1.25" Spidertraxxs, 285/70r17 Pro Comp ATs, ARB Flat steel roof rack
new ride: 2020 TRD ORP
tackleberry1145 is offline   Reply With QuoteReply With Quote
Old 09-11-2018, 08:03 AM #50
In order to stick with my oem Trail wheels I needed a tad more space between the tire sidewall and JBA UCAs when going to 285/70s. I'm not a fan of the bling bling aftermarket wheels and prefer stock wheels on my Toyotas.
It always seems like when one of these spacer failure threads pops up that a 3rd party has installed the wheel and or spacer. I personally haven't seen one yet where the OP could verify the proper torque was used and there was a failure.
Old 09-11-2018, 10:26 AM #51
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
Just out of curiosity, for those blaming the impact gun for stretching the lugs......what kind of air pressure are you running on the compressor?
200+ lbs? with the zipgun set to max or what?
nglayton is offline   Reply With QuoteReply With Quote
Old 09-11-2018, 11:04 AM #52
Snackie Snackie is offline
Snackie is on a distinguished road
You picked a fine time to leave me loose wheel.......
Snackie is offline   Reply With QuoteReply With Quote
Old 09-11-2018, 11:11 AM #53
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
Originally Posted by mrblah View Post
Toyota OEM lugs can fail with a pneumatic wrench..happened to my buddy b/c he was a moron and wanted to use his new impact gun, and his front passenger side lost 5 out of 6 lugs on the freeway. He wasn't running spacers.
As for someone who says find the right rims...
Tell me where I can find 17x8.5 and 17x9's with a -40 offset rims that don't look like they come from the douche bag catalog.
I only know of one set of rims that I would buy (SCS f5 -38) that doesn't scream douchebag, and good luck trying to get a set b4 they sell out.
Sometimes, you have to run spacers........
I just tell people if you run spacers do your due diligence, and be careful.
I"ve run spacers on all my vehicles, from stances 350z's to tundras, and now my 4runner.
correct. wheel choices in 17's are terrible for width and backspacing. sometimes spacers are the only option.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 09-11-2018, 12:30 PM #54
ayeyothisiskyle's Avatar
ayeyothisiskyle ayeyothisiskyle is offline
ayeyothisiskyle has a spectacular aura about ayeyothisiskyle has a spectacular aura about
They seem to be in stock right now...
Now if they only came in brushed copper or gold and I'd switch.
I'm not opposed to gloss white either.
2016 Trail + KDSS | Kings 2.5 w. Adj + Ext Travel Front & Rear - JBA High Caster UCA - Icon 3" "Overland" Springs - Proline 4x4 Rear Elite Dual Swingout Bumper - Demello Offroad X-Wing Sliders - SCS Ray 10 - Falken Wildpeak MT01 285/70/17 - Dirty Pants
ayeyothisiskyle is offline   Reply With QuoteReply With Quote
Old 09-11-2018, 12:52 PM #55
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
It comes with rims with the correct offset that dont scream douch
Sent from my SM-G930V using Tapatalk
jhguth is offline   Reply With QuoteReply With Quote
Old 09-11-2018, 01:45 PM #56
brtnstrns brtnstrns is offline
brtnstrns is just really nice brtnstrns is just really nice brtnstrns is just really nice brtnstrns is just really nice brtnstrns is just really nice
The Trail/TRD Off Road rims offset definitely don't scream douche. But they do scream "please push me out further". They make the vehicle look like it has narrow shoulders.
Voodoo Blue 2020 Tacoma TRD Off Road
brtnstrns is offline   Reply With QuoteReply With Quote
Old 09-11-2018, 05:53 PM #57
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
I got the best offset available for the rims I had to have and still had the ''Ford Exploder'' look going on....where the rear track is silly-narrow looking. Spacers fixed it and the track width adds stability! http://www.toyota-4runner.org/attach...1&d=1536702653 Nobody will touch the truck but Me and I'm very methodical and picky so I don't sweat the spacers if installed properly.
Failed Spidertrax spacer, there goes the wheel-20180817_182244-1-jpg
83Mule is offline   Reply With QuoteReply With Quote
Old 09-11-2018, 06:10 PM #58
DeepSea's Avatar
DeepSea DeepSea is offline
Real Name: Nate
DeepSea will become famous soon enough
DeepSea's Avatar
Real Name: Nate
True but this thread is one of several I've seen with failed wheel spacers, and that's guys who actually posted it online. I can't say the same about suspension and/or wheels breaking off. It's probably less than 1% of the guys running them but to me it's something I won't chance because not only are you endangering you & your passengers but others on the road. I went with a wider offset wheel (SCS) because of the possible spacer issues. Also, I work with a large off-road shop here in Hawaii and the majority of guys replacing wheel bearings and ball joints are from running spacers as it adds additional wear to those components. Just my .02
2016 Quicksand TRDP, Eibach 2.0 PRO Kit, 285/70/17 Falken Wildpeak MT, 17x9 SCS F5, Prinsu Roof Rack, Canvas Back, Weathertech
Build: http://www.toyota-4runner.org/5th-ge...ld-hawaii.html
Filmmaker: https://www.youtube.com/user/freedomriding Instagram: https://www.instagram.com/freedomedia/[/SIZE][/SIZE]
DeepSea is offline   Reply With QuoteReply With Quote
Old 09-11-2018, 08:32 PM #59
jmike jmike is offline
jmike is on a distinguished road
Originally Posted by Edwin562 View Post
Rule of thumb I follow is when I'm running spacers (which-ever brand) I have always upgraded wheel lug studs to ARP. Studs are usually the weak point when adding spacers. upgraded studs should be a must when running spacers .5" or more. BUT yet again, why go spacers if choosing proper offseted wheels would of been a much better choice, unless owner is planning to use OEM wheels. Sucks for those who had the studs snap.
I agree but I will admit investing roughly $300 for studs isn't something many like to do. Especially after investing into the Spydertrax which comes with studs that you would think might be similar quality to ARP
jmike is offline   Reply With QuoteReply With Quote
Old 09-13-2018, 12:51 AM #60
Edwin562's Avatar
Edwin562 Edwin562 is offline
Edwin562 is on a distinguished road
Edwin562's Avatar
True, but it comes out almost the same if proper wheels were chosen in the first place.
Edwin562 is offline   Reply With QuoteReply With Quote
spacers , spidertrax , wheel
Spidertrax Wheel spacer questions 04BCT4RLTD 4th Gen T4Rs 40 06-24-2019 08:23 PM
Anyone replace a stud in a Spidertrax wheel spacer? Bandit Runner 3rd gen T4Rs 9 12-30-2015 10:32 PM
Spidertrax wheel spacer quick question Duckman97 3rd gen T4Rs 2 11-06-2015 12:21 AM
FS: spidertrax hub centric wheel spacer. Keemonrunnin For Sale: Non-T4R Items 0 06-17-2014 05:36 PM
