Old 08-22-2019, 01:03 PM #91
Ryan at Eibach's Avatar
Ryan at Eibach Ryan at Eibach is offline
official vendor
Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light
official vendor
A stock Porsche 930 (turbo air cooled 911) had 2" spacers from the factory.
Ryan
2019 TRD Off Road
2007 GT3
1982 911 SC
Ryan at Eibach is offline   Reply With QuoteReply With Quote
Old 08-22-2019, 01:40 PM #92
brtnstrns brtnstrns is offline
brtnstrns is just really nice brtnstrns is just really nice brtnstrns is just really nice brtnstrns is just really nice brtnstrns is just really nice
Ryan
Really? That's pretty wild.
Were they double stacked with studs built into each spacer? Or did they install a single spacer with thru-holes and proper length studs installed on the hubs? The latter is much safer than the former.
Voodoo Blue 2020 Tacoma TRD Off Road
brtnstrns is offline   Reply With QuoteReply With Quote
Old 08-22-2019, 02:00 PM #93
dot_tom's Avatar
dot_tom dot_tom is offline
Real Name: Tom
dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all
dot_tom's Avatar
Real Name: Tom
Ryan
This.
Also, When properly installed and quality materials used there are no issues.
2017 4Runner TRD OR - Progress Thread
295/70/17 BFG KM3, SCS F5 17x9 -38, Front 5100 Rear MT Icon, Dobinson 314 & 701V, Gobi Stealth, RSG Sliders, ECGS 4.56's, Demello Front bumper, Coastal Off Road Rear Bumper
IG: dot_tom
dot_tom is offline   Reply With QuoteReply With Quote
Old 08-22-2019, 02:20 PM #94
official vendor
official vendor
No, they were one piece with proper length studs inserted into the hub. You know the Germans tested it
2019 TRD Off Road
2007 GT3
1982 911 SC
Old 03-27-2020, 12:26 AM #95
bryanbgw's Avatar
bryanbgw bryanbgw is offline
bryanbgw is on a distinguished road
bryanbgw's Avatar
JEEZ. Second guessing getting these. User error is what most people are saying this is caused by, hopefully I can get em done right
bryanbgw is offline   Reply With QuoteReply With Quote
Old 03-27-2020, 11:03 AM #96
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
If you install Spidertrax, do them yourself or have a reputable shop torque them and then your wheel nuts according to the instructions.
They can be a headache once you have them on since many tire shops and some dealers won't mess with them and will refuse to install tires, rotate them, or even fix a puncture if they find out.
Also, those shops who WILL work on a vehicle with them installed may still send the 19 year old kid with an impact gun to torque them to 170 lbs and stretch/destroy the wheel studs.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 03-27-2020, 11:26 AM #97
TRDHULK's Avatar
TRDHULK TRDHULK is offline
TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold
TRDHULK's Avatar
The issue with spacers is when the studs are over torqued, they are stretched and weakened. Tighter is not better. Tighten to spec with a calibrated torque wrench (I prefer name brand like my Matco) and use Loctite. You will never have a failure. I did mine at 90 ft/lbs, used a lot of loctite, and triple checked every lug before the loctite dried.
Another note: Some people recommend to re-torque after a few hundred or a few thousand miles. I don't agree with this; if you use red loctite, you would break the bond if you tried to re-torque. This is the same concept when building engines. The only bolts when building an engine that need re-torquing would be head steads with cast aluminum heads, since loctite is not used, gaskets compress, and cast aluminum may flex under heat. With a wheel spacer, the billet aluminum does not flex or change with heat.
If you want to double check after a few hundred or thousand miles, turn the torque wrench back 5 lbs and check every lug, this way you know its tight without breaking loose the loctite. My 2 cents.
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
TRDHULK is offline   Reply With QuoteReply With Quote
spacers , spidertrax , wheel
Spidertrax Wheel spacer questions 04BCT4RLTD 4th Gen T4Rs 40 06-24-2019 08:23 PM
Anyone replace a stud in a Spidertrax wheel spacer? Bandit Runner 3rd gen T4Rs 9 12-30-2015 10:32 PM
Spidertrax wheel spacer quick question Duckman97 3rd gen T4Rs 2 11-06-2015 12:21 AM
FS: spidertrax hub centric wheel spacer. Keemonrunnin For Sale: Non-T4R Items 0 06-17-2014 05:36 PM
