Old 09-09-2018, 05:02 PM #1
decker1's Avatar
decker1 decker1 is offline
decker1 is on a distinguished road
decker1's Avatar
Failed Spidertrax spacer, there goes the wheel
I thought I would share my experience with spidertrax spacers for anyone who might be considering them. On my way back from camping going through a downward S-curve, the front driver-side spidertrax decided to loose the lugs and my wheel came right off; Good news is that (with removing the spacers) I was able to put my wheel back on and continue the 5 hour drive home. Aside from a bent fender does anyone have any recommendations on what to replace or fix? I dont feel too much of a difference driving. However I do notice a slight creaking/folding sound that I can only relate to a ball joint, which comes out on a turn or bump at high speed (like when getting off a highway).
Rotors will probably go, although I dont feel a difference in those either. All in all I got extremely lucky!
2014 Toyota 4Runner Trail 4WD - Icon Stage 1 at 1.5" Rear, 2" Front, 1.25" Spidertrax, Coverking Ballstic Tactical Seat Covers, WeatherTech Floor Liners, Raingler Cargo Net, Green LED Bulb door mod, Gobi Stealth Rack w/ Ladder, Yaesu FT2900 Ham Radio w/ 4ft Magnetic Antenna
Build Thread
decker1 is offline   Reply With QuoteReply With Quote
Old 09-09-2018, 05:49 PM #2
WandaRunner's Avatar
WandaRunner WandaRunner is offline
Real Name: J
WandaRunner is on a distinguished road
Real Name: J
Had the same thing happen to me. Except on freeway and it was passenger side. Apart from body damage: new rotor, lugs, re-alignment and was good to go.
WandaRunner is offline   Reply With QuoteReply With Quote
Old 09-09-2018, 06:10 PM #3
unsub1 unsub1 is offline
unsub1 will become famous soon enough unsub1 will become famous soon enough
Whoa.
unsub1 is offline   Reply With QuoteReply With Quote
Old 09-09-2018, 06:10 PM #4
Vermilion's Avatar
Vermilion Vermilion is offline
Vermilion is on a distinguished road
Vermilion's Avatar
Damn! These two posts make me want to consider taking mine off. The fact that the lugs just sheared off instead of the actual spacer coming off the hub is worrying.
Vermilion is offline   Reply With QuoteReply With Quote
Old 09-09-2018, 06:22 PM #5
raycje5 raycje5 is offline
raycje5 is on a distinguished road
Of course I’m literally dropping my truck off at 10:30 tomorrow to get wheels,these spacers and lift. Dang.
raycje5 is offline   Reply With QuoteReply With Quote
Old 09-09-2018, 06:23 PM #6
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
Consider that it isn't a ''Spacer'' issue........but a lug nut and stud issue. Likely something was loose and it cascaded into shearing the studs as the spacer is otherwise secure and undamaged. Even without spacers this same failure happens and it's from a loose lug or stretched stud. I would repair the spacer with fresh, quality studs and nuts and torque to 80lbs.
83Mule is offline   Reply With QuoteReply With Quote
Old 09-09-2018, 06:36 PM #7
snow junky's Avatar
snow junky snow junky is offline
snow junky is on a distinguished road
snow junky's Avatar
Looks like it wasn’t the spacer at all. Looks like the studs snapped. What did you torque them to? I use cheap 2 in ebay spacer and never had a problem.
97 4runner 3rzfe 5speed
D44 sky mfg sas
Dual transfer cases
toyo 37s 5.29 locked F&R
York OBA compressor
snow junky is offline   Reply With QuoteReply With Quote
Old 09-09-2018, 06:39 PM #8
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
99.9% of the time these failures are user error. Overtightening the lugs causing them to snap. SpiderTrax makes a quality product. This happens all the time with cheap ebay junk but not SpiderTrax. Torque properly, check regularly, they will last forever.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 09-09-2018, 06:40 PM #9
daxone daxone is offline
daxone is on a distinguished road
All this sounds scary. Glad the rigs aren’t too badly damaged.
’14 White Trail,Ecotechne rack,XenonDepot HIDS,RSG sliders,6112,RCI skids
daxone is offline   Reply With QuoteReply With Quote
Old 09-09-2018, 07:37 PM #10
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
factory studs are easy to stretch, there are failures even without spacers. a lot of FJ people upgrade their studs as a preventative measure.
jhguth is offline   Reply With QuoteReply With Quote
Old 09-09-2018, 07:50 PM #11
Real Name: Chris
Real Name: Chris
What studs are they using? Sounds like a worth while upgrade for those of us running bigger heavier tires.
Old 09-09-2018, 07:57 PM #12
Busabos77 Busabos77 is offline
Busabos77 will become famous soon enough
Like what other members said. Possibly bolts were over torqued. Sorry to see the damage but glad you are safe.
Busabos77 is offline   Reply With QuoteReply With Quote
Old 09-09-2018, 08:18 PM #13
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
arp lexus tire studs but prepare too pay a shiny penny.
I don't think upgrading your fasteners will prevent failure (i.e. overtorquing)
Old 09-09-2018, 08:24 PM #14
Real Name: Chris
Real Name: Chris
I remove by hand and torque by hand every time. 86 foot pounds
Old 09-09-2018, 09:16 PM #15
adio3x's Avatar
adio3x adio3x is offline
adio3x will become famous soon enough
adio3x's Avatar
I had my spidertrax spacers on for literally 8 years, never took them off or had to re-torque anything. Did you use red loctite & torque them to proper specs?
Andrew
2010 Battleship Grey SR5 4x4
Sweet mod list.
adio3x is offline   Reply With QuoteReply With Quote
spacers , spidertrax , wheel
Spidertrax Wheel spacer questions 04BCT4RLTD 4th Gen T4Rs 40 06-24-2019 08:23 PM
Anyone replace a stud in a Spidertrax wheel spacer? Bandit Runner 3rd gen T4Rs 9 12-30-2015 10:32 PM
Spidertrax wheel spacer quick question Duckman97 3rd gen T4Rs 2 11-06-2015 12:21 AM
FS: spidertrax hub centric wheel spacer. Keemonrunnin For Sale: Non-T4R Items 0 06-17-2014 05:36 PM
