Replaced my iPad mount with a Ram Mounts / Proclip combo. Added a small screw to the bottom to make it even more stable.
ProClip 834492
RAM-347U
RAM-201U
RAM-HOL-UN8BCU
Installed a ScanGauge II to show tire pressures and held it in place with a 3D printed adapter. I modified it with a small screw and a notch on the radio hanging button so that the radio can't rotate out of place.
Replaced my RAM phone mounts phone holder with a
sliding clamp that used the same ball size as RAM so I could still use the rest of the RAM components. I didn't like how with the RAM phone mount I needed two hands to put it in place. The sliding clamp was originally too strong so I had to modify it by removing one of the springs. That was very difficult because the bolts are aluminum and loctited into place. I had to use a small heat gun to melt the loctite to remove the bolts without shearing it. I broke one mount before I knew I had to heat it up. I'm really happy with the phone mount now.
