12-15-2018, 03:33 PM
#181
Originally Posted by LeesO4
So the underlined quote is for the 25’ distance? They did their test based on a 35’ distance. The actual article isn’t very clear. Sounds like they used the SAE guidelines which state 25’ away, but they adjusted the SAE reference points for their 35’ test. Is that your understanding as well?
Hmm, I didn't see their 35 foot distance in the article. I read it for reference but ended up using the Toyota pdf for my final instructions. Someone has it posted up on here. It's a little complicated for a 4Runner because it also mentions left/right aiming as well... Someone correct me if I'm wrong but I believe the 4Runner does not have adjusters for left and right.
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
01-11-2019, 04:12 PM
#182
The fans on my Morimoto 2strokes are really singing. They are much much louder than when I first installed them. Makes me wonder if the fans are going to fail anytime soon.
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
01-11-2019, 08:31 PM
#183
Yeah mine have been pretty loud since day one. I think the limiting factor in these things will be the fan and heat.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
01-11-2019, 09:59 PM
#184
Real Name: Jillian
Real Name: Jillian
I put a set in after work today. I'd say brightness is similar to the H9 halogen I had in. Whiter light allowing me to see the crisp cutoff better. Fan does run loud but the engine is louder on 4Runners anyways (I think). I love them...but I'm not trashing my H9s.
2022 4Runner Trail in Lunar Rock
Sold ’18 TRD Off-Road Nautical Blue
01-14-2019, 02:35 AM
#185
Anyone running morimotos for the DRL/hi beam bulbs? What’s the verdict?
2015 Classic Silver Metallic SR5P 4WD w/ Entune
K&N Drop-In Filter, NoxLuxLED Blackout Kit, N-Fab Nerf Bars
Bilstein 5100, Cooper Discoverer AT3 4S
06-24-2019, 01:42 PM
#186
Real Name: Jason
Real Name: Jason
Can someone confirm if these install with the same turn-to-lock as OEM halogen bulbs? I installed over the weekend and it seemed if I continued to turn they would come out instead of locking into place. Is it possible this is a result of the tighter fitting gasket and I just need to give it even more inward force while twisting into the socket?
06-24-2019, 05:59 PM
#187
Mines don’t lock into place either. I can spin them 360* and they pop out.
06-24-2019, 06:48 PM
#188
Mine stopped. That's strange.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
06-24-2019, 07:26 PM
#189
Real Name: Jason
Real Name: Jason
I initially tried them without the extra o-rings supplied and they didn’t fit well. After adding the o-rings they were snug, but I can spin them freely inside the housing. Does anyone have a schematic of the headlight internals? Is there a physical stop inside that the two of us aren’t contacting?
06-24-2019, 11:49 PM
#190
This does sound unusual. I installed mine (no extra O-rings etc.) and they definitely locked in place, with the chips at 3 and 9 o'clock. You need to make sure they're clocked correctly, otherwise the lamp will not work as designed.
-Tory
06-25-2019, 08:30 PM
#191
Real Name: Jason
Real Name: Jason
Ok, so I had a few minutes to take another look at these. I tried removing the passenger side first to just start over, and the LED separated from the H11 bracket, haha. So clearly the bracket is secure in the housing. Screwed it back in and set the arrows on the bulb housing to 9 and 3, is this correct? Moved on and did the same with the driver’s side. With a 9 month old, I can’t be out tinkering in the garage at 9pm when it’s finally dark, so just hoping tomorrow morning my light output is acceptable.
06-25-2019, 09:47 PM
#192
I've noticed the factory H11 has a little nub just below the widest blade on the mounting flange. The morimoto does not have this nub. Could this be the reason for it not locking in? Had to remove the gaskets to get a better pic. Also is the mounting bracket on the morimoto supposed to spin separately from the led? I noticed this was happening when trying to install them and i can do this by hand too. Thanks for your help
06-25-2019, 11:27 PM
#193
I feel you dude. 1½ year old at home and want to give the wife a break as much as possible, so garage time is nearly zero right now. I'm literally making wiring harnesses with all of the junk in my truck on lunch breaks etc.
-Tory
08-25-2019, 01:16 AM
#194
Has anyone put the 2stroke 2.0 in a 2010-2013 with the reflector headlights? Everything I'm seeing here seems to be in the 2014+ projectors.
2010 Limited
08-30-2019, 06:58 AM
#195
Low beam led installation
Hi, I am trying to install the low beam on my 4 runner 19, and I would like to know if I need to adjust the angle, I can’t see if the bulb is left to right, any idea how can I check?
Thanks
