09-27-2018, 03:24 PM
No headlight warning buzzer?
I've had my ORP for a week and just noticed that when I removed the key and exited the vehicle with the headlights on, there was no warning buzzer. I only noticed they were on when I went to open the liftgate and saw the license plate lights on.
Should there be a warning buzzer? Is this a programmable option, or a fault that the dealer should repair?
2018 TRD Off Road Premium
Nautical Blue
KDSS / Moonroof / Running Boards
Big Smile
09-27-2018, 03:26 PM
If you lock your car twice.... they will turn off.
2016 White TEP
09-27-2018, 03:32 PM
Theres also a timeout on them. I think its 30 seconds.
2016 Trail + KDSS | Kings 2.5 w. Adj + Ext Travel Front & Rear - JBA High Caster UCA - Icon 3" "Overland" Springs - Proline 4x4 Rear Elite Dual Swingout Bumper - Demello Offroad X-Wing Sliders - SCS Ray 10 - Falken Wildpeak MT01 285/70/17 - Dirty Pants
09-27-2018, 03:35 PM
So, the driver needs to remember to double-click, but if not, they'll automatically go off after 30 seconds. But no warning buzzer, correct? (Edit: I just found the section in the owner's manual...thanks.)
Nautical Blue
Big Smile
09-27-2018, 03:36 PM
correct, and the time to off can be adjusted via techstream or carista app.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
09-27-2018, 03:43 PM
Unless you turn them on without starting the engine, then they will stay on forever. I can’t remeber if I did headlights on then ignition on or the opposite but they never turned off after removing the keys or locking the door.
09-27-2018, 04:17 PM
Real Name: Chris
Real Name: Chris
Nope, no buzzer. They shut off after 60 seconds either way
09-27-2018, 04:54 PM
nothing to worry about.
09-27-2018, 05:17 PM
Tap the lock button twice.. they shut off right away.
2014 4Runner TE w/KDSS. Fox 2.5 FRS/2.0 w/ Toytec Superflex. 285 WILDPEAK M/T. SSO Slimline w/ Stage 2. Smittybilt X20 10K. Shrockworks Sliders. SP-9100. VIAIR 444C On-Board Air. Sprint Booster. DD SS3. BD LP4. Rigid Ditch.
09-27-2018, 05:19 PM
Thanks to all for your replies...a new habit to acquire.
Nautical Blue
Big Smile
12-03-2018, 09:07 PM
Real Name: Jeremy
Real Name: Jeremy
Was raining today on my way home, naturally I had the headlights on..when I got out and came in the house I must not have turned them off all the way, left them in the side marker position..still getting used to not having the auto headlights like my previous car..anyway, I locked the doors with the remote, went in the house. wife came home about an hour later and asked me if I knew the lights were on..I'm scratching my head like no way, sure enough the side markers were on..now I know the other lights will time out, but evidently that's not the case with the side markers..anyone else noticed this??
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
12-03-2018, 09:13 PM
Real Name: Sparky
Real Name: Sparky
If you turn the engine off while the headlights are on, they will turn off on their own, doesn't matter if you lock the truck or not.
If you turn them on while the engine is off, they will stay on.
Old and (c)rusty.
