Originally Posted by Brandonium
JBL is an entirely different beast and I would rather keep my options open for OEMaudio later than corner myself into JBL.
A few things to note. You do need an new harness along with the Hazzard switch. It will plug in (odd shape but still clicks in) but your hazzard will just flash non stop. Also, not sure if my conversion harness is 100% correct but I lost USB and I have two spare openings on the Entune 3.0 unit and only one remaining plug on the harness available but it matches none of the two available plugs.
Also, the side pieces next to the AC vents are different also and require trimming to fit. I may just buy those as well. I did not see any of this mentioned prior so I figured it was worth mentioning now.
does the old hazard button fit the new one? Are you able to just slice and play the old hazard wiring into the new one?
Stereo harness , take any pictures to match up to existing wiring? Lost of usb seems unusual.
Side pieces next to AC vents , pictures ?
Overall was it a simple swap besides the mentioned complications? Everything works , any lost features , have you updated the software if needed? Overall thoughts thx
